Martin Welker
104
230,310
Toyota Tacoma 1998-2000 Repair Manual and Wiring Diagrams
Format: HTML, PDF
Brand: Toyota
Type of Machine: Automotive
Type of Manual: Service Manual, Repair Manual, Owners Manual, Electrical Wiring Diagrams
Model: Toyota Tacoma 1998-2000
Year: 1998 1999 2000
New Car Features
Appendix
Foreword
New Features
Overdrive
Owners manual
1.0 Foreword
1.1 Operation of Instruments and Controls
1.2 Keys and Doors
1.3 Seats, Belts, Wheel, and Mirrors
1.4 Lights and Wipers
1.5 Gauges and Meters
1.6 Ignition Transmission Parking Brake
1.7 Car Audio System
1.8 Air Conditioning System
1.9 Other Equipment
2.0 Information Before Driving
2.1
2.2 Important Info about this Manual
3.0 Starting and Driving
4.0 In Case of Emergency
5.0 Corrosion Prevention
6.0 Vehicle Maintenance and Care
7.1 Maintenance Introduction
7.2 Maintenance Engine and Chassis
7.3 Maintenance Electrical Components
8.0 Specifications
9.0 Reporting Safety Defects
Scheduled Maintenance Guide
Repair Manual
Air Conditioning
AC Troubleshooting
AC Switch
Inspection
Installation
Removal
Amplifier
Installation
On Vehicle Inspection
Removal
Blower Motor
Inspection
Installation
Removal
Blower Resistor
Inspection
Installation
Removal
Blower Unit
Components
Disassembly
Installation
Reassembly
Removal
Compressor
Components
Disassembly
Installation
Reassembly
Removal
Condenser
Installation
Removal
Cooling Unit
Components
Disassembly
Installation
Reassembly
Removal
Drive Belt
Installation
Removal
Evaporator
Inspection
Installation
Removal
Expansion Valve
Installation
Removal
Heater Control Assembly
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Heater Main Relay
Inspection
Heater Radiator
Inspection
Installation
Removal
Heater Unit
Components
Disassembly
Installation
Reassembly
Removal
Manifold Gauge Set
setoff
Pressure Switch
Installation
Removal
Receiver
Installation
Removal
Refrigerant Line
Location
Replacement
System
Charging
Evacuating
Location
Precaution
Thermistor
Inspection
Installation
Removal
Water Valve
Installation
Removal
Auto Trans A340E F
A340E Removal
A340F Removal
AT A340E Components
AT A340F Components
AT Temp Sense On Vehicle Inspection
Extension Housing Oil Seal On Vehicle Repair
Inspection
Installation
Operation
Park Neutral Switch On Vehicle Repair
Parking Pawl On Vehicle Repair
Precaution
Sensor Rotor On Vehicle Repair
Shift Lock System Location
Throttle Cable On Vehicle Repair
Torque Converter Clutch and Driveplate Inspection
Valve Body Assembly On Vehicle Repair
Vehicle Speed Sensor On Vehicle Repair
Auto Trans A43D
Components
Inspection
insp2
Installation
Location
Operation
ovr
ovr2
ovr3
ovr4
ovr5
ovr6
ovr7
Removal
Troubleshooting
Body
Back Window Glass
Components
Disassembly
Installation
Reassembly
Removal
Clip
Replacement
Front Bumper
Components
Front Door
Adjustment
Components
Disassembly
Reassembly
Front Seat (Separate Type)
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Front Seat (Split Bench Type)
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Front Seat (Sport Type)
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Front Wiper Washer
Adjustment
Components
Inspection
Installation
Removal
Hood
Adjustment
Instrument Panel
Components
Disassembly
Installation
Reassembly
Removal
Quarter Window Glass
Components
Installation
Removal
Rear Seats
Components
Disassembly
Installation
Reassembly
Removal
Roof Headliner
Components
Installation
Removal
Seat Belt
Components
Inspection
Seat Belt Pretensioner
Disposal
Inspection
Installation
Removal
Replacement
Tail Gate
Components
Installation
Removal
Wheel Arch Moulding
Components
Installation
Removal
Wheel Opening Moulding
Components
Installation
Removal
Windshield
Components
Installation
Removal
Body Electrical
Location
Precaution
Problem Symptoms Table
Antenna
Inspection
Replacement
Audio
Description
Location
Troubleshooting
Backup Light
Inspection
Location
Clock
Troubleshooting
Combination Meter
circ
Inspection
Location
Headlight Taillight
Adjustment
Components
Inspection
Location
Ignition Switch
Inspection
Location
Interior Light
Inspection
Location
Power Door Lock
Inspection
Location
Power Window
Inspection
Location
Stop Light
Inspection
Location
Turn signal Hazard
Inspection
Location
Wiper Washer
Inspection
Location
Brakes
Precaution
ABS Actuator
Components
Disassembly
Installation
Reassembly
Removal
Brake Booster
Components
Installation
Removal
Brake Fluid
Bleeding
Front Brake Caliper
Components
Disassembly
Inspection
Installation
Reassembly
Front Brake Pad
Components
Replacement
Front Speed Sensor
Installation
Removal
LSPV
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Master Cylinder
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Parking brake
Rear Drum Brake
Components
Inspection
Installation
Removal
Rear Speed Sensor
Components
Installation
Removal
Charging
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Replacement
Cooling
Coolant
Inspection
Replacement
Components
Disassembly
Installation
On Vehicle Cleaning
Reassembly
Removal
Thermostat
Components
Inspection
Installation
Removal
Components
Inspection
Installation
Removal
Diagnostics
ABS
Customer Problem Analysis Check
Diagnostic Trouble Code Chart
How To Proceed with Troubleshooting
Parts Location
Pre-Check
Terminals of ECU
Circuit Inspection
ci11
ci21
ci313233
ci37
ci41
ci44
ci48
ci49
ci51
ciabswar
cialways
citcterm
citsterm
Automatic Transmission
Parts Location
Pre-Check
Terminals of ECM
Circuit Inspection
ciatpind
ciodcanc
ciodmain
cip0500
cip0710
cip0750p
cip0753p
cip0770
cip0773
cip1520
cip1700
cip1780
cipatter
Circuit Inspection
ciecmpow
cifuelpu
cip01
cip0100
cip0101
cip0110
cip0115
cip0116
cip0120
cip0121
cip0125c
cip0125e
cip0130
cip0133
cip0135p
cip0136
cip0171p
cip0300p
cip0325p
cip0335
cip0340
cip0420c
cip0420e
cip0440
cip0441p
cip0450p
cip0500
cip0505
cip1130
cip1133
cip1135
cip1300
cip1335
cip1520
cip1600
cip1780
cistarte
Cruise Control (Ford)
ci12
Parts Location
Pre-Check
Terminals of ECU
Circuit Inspection
ci12
ci14
ci21
ci23
ci32
cicable
ciclutch
ciect
ciecupow
ciidlesw
ciindica
cimainsw
cipnpsw
cistopli
citc
Cruise Control (Denso)
Parts Location
Pre-Check
Terminals of ECU
Circuit Inspection
ci11
ci12
ci14
ci21
ci23
ci32
cibackup
cicable
ciclutch
ciect
ciecupow
ciidlesw
ciindica
cimainsw
cipnpsw
cistopli
citc
Parts Location
Pre-Check
Terminals of ECM
SRS
Parts Location
Pre-Check
Terminals of ECU
Circuit Inspection
cialways
cib01001
cib01011
cib01021
cib01031
cib01055
cib01065
cib01075
cib01085
cib01306
cib01316
cib01326
cib01336
cib01357
cib01367
cib01377
cib01387
cib11003
cib1156b
cib1158b
cidoesno
cinormal
citcterm
Emission Control
Components
draw
Inspection
insp2
Location
Purpose
Engine Mechanical
Components
comp2
comp3
comp4
comp5
Disassembly
Disassembly2
ins2p
Inspection
insp3
insp4
insp5
insp6
insp7
insp8
Installation
inst2
inst3
Reassembly
reas2
Removal
Removal2
Removal3
rep2
Replacement
Fuel Injection
EFI Main Relay Inspection
Fuel Cut RPM
Fuel System Precautions
AF Sensor
Components
Inspection
Circuit Opening Relay
Components
Inspection
ECM
Components
Inspection
Engine Coolant Temp Sensor
Components
Inspection
Fuel Pressure Regulator
Components
Installation
Removal
Fuel Pump
Components
Disassembly
Installation
Reassembly
Removal
Fuel Tank and Line
Components
Inspection
Idle Air Control Valve
Components
Inspection
Installation
Removal
Injectors
Components
Inspection
Installation
Removal
Knock Sensor
Components
Inspection
Mass Air Flow
Inspection
Installation
Removal
O2 Sensor
Components
Inspection
Throttle Body
Components
Inspection
Installation
Removal
Vapor Pressure Sensor
Inspection
VSV
Inspection
insp2
Ignition
Cam Position Sensor
Components
Replacement
Crank Position Sensor
Replacement
Ignition Coil
Components
Replacement
Introduction
Abbreviations Used in this Manual
geninf2
Glossary of SAE and Toyota Terms
How to use the Diagnostic Chart and Inspection Procedure
Precaution
troubleshoot ECU
Vehicle Identification and Engine Serial Number
Vehicle Lift and Support Locations
Lubrication
Components
Inspection
Installation
Removal
Oil n Filter
Inspection
Replacement
Oil Pump
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Replacement
Maintenance
Brake Inspection
Chassis Inspection
Engine Inspection
Inside Vehicle General Maintenance
Outside Vehicle General Maintenance
Underhood General Maintenance
Preparation
cool
equ11i
equ12i
equ14i
equ15i
equ17i
equi
equi10
equi13
equi14
equi15
equi16
equi17
equi18
equi2
equi3
equi4
equi5
equi6
equi7
equi8
equi9
lubr
lubr2
lubr3
lubr4
lubr5
lubr6
lubr7
lubr8
lubr9
rectoo
rectoo10
rectoo11
rectoo12
rectoo13
rectoo14
rectoo15
rectoo16
rectoo17
rectoo2
rectoo3
rectoo4
rectoo5
rectoo6
rectoo7
rectoo8
rectoo9
ss7t
ssm
ssm2
ssm3
sst
sst10
sst11
sst12
sst13
sst14
sst15
sst16
sst17
sst18
sst19
sst2
sst3
sst4
sst5
sst6
sst8
sst9
Propeller Shaft
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Replacement
SRS
Operation
Precaution
Airbag Sensor Assembly
Components
Inspection
Installation
Removal
Replacement
Front Airbag Sensor
Components
Inspection
Installation
Removal
Replacement
Front Passenger Airbag assembly
Components
Disposal
Inspection
Installation
Removal
Replacement
Pass Airbag Switch
Inspection
Steering Wheel Pad and Spiral Cable
Components
Disposal
Inspection
Installation
Removal
Replacement
Wire Harness and Connector
Inspection
Location
Replacement
Starter
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Replacement
Starter Relay Inspection
test
Steering
Inspection
Precaution
Air control valve
Inspection
Drive belt
Inspection
Fluid
Bleeding
Inspection
Power Steering Gear
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Power Steering Vane Pump
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Steering Column (NAstech)
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Steering Wheel
Inspection
Tilt steering column
Components
Disassembly
Inspection
Installation
Reassembly
Removal
Suspension and Axle
Inspection
insp2
Replacement
Free Wheel Hub
Components
Inspection
Installation
Removal
Front Axle Hub
Components
Disassembly
Installation
Reassembly
Removal
Front Diff Carrier
Components
Disassembly
Installation
Reassembly
Removal
Replacement
Front Diff Rear Oil Seal
Components
Replacement
Front Driveshaft
Components
Disassembly
Installation
Reassembly
Removal
Front Lower Ball Joint
Components
Inspection
Installation
Removal
Front Lower Suspension Arm
Components
Installation
Removal
Front Shock Absorber
Components
Disassembly
Disposal
Inspection
Installation
Reassembly
Removal
Replacement
Front Stab Bar
Components
Inspection
Installation
Removal
Front Upper Ball Joint
Components
Inspection
Installation
Removal
Replacement
Front Upper Suspension Arm
Components
Installation
Removal
Rear Axle Shaft
Components
Inspection
Installation
Removal
Rear Diff Carrier
Components
Disassembly
Installation
Reassembly
Removal
Replacement
Rear Diff Front Oil Seal
Components
Replacement
Rear Leaf Springs
Components
Installation
Removal
Replacement
Rear Shocks
Components
Disposal
Inspection
Installation
Removal
Rear Wheel Hub
Replacement
Transfer Case
Assembly
Components
Disassembly
Reassembly
Driven Sprocket
Components
Replacement
Input Shaft
Components
Inspection
Oil Pump Body
Components
Inspection
Oil Seal
Components
Replacement
Planetary Gear
Components
Inspection
Rear Output Shaft
Components
Disassembly
Inspection
Reassembly
Transfer Unit
Components
Installation
Precaution
Removal
Service Bulletins
0124tsb Trim Garnish Loose
ac00200t AC Compressor Mtx for Stored Vehicles
ac009t Sensor Inspection for AC
ax001t00 Toyota DINGHY Towing Guide
ax006t02 Trailer Wire Harness
ax007t02 Tailgate Lock Torque Change
bo001t00 Rear Quarter Panel Paint Chip Protection
bo002t00 Seat Belt Extender
bo00397k Wind Noise Repair Kit
bo010t02 Child Restraint Seat Top Bracket Connection
bo011t0s New Seat Belt Tongue Plate Stopper Plate
bo013t0a Door Mirror Glass Service Parts
bo01900 Front Mud Guards
bo019t01 Shoulder Belt Anchor Tape Set
bo020t00 Seat Belt Extender
bo023tis Seat Belt Extender
bo026t00 Water Leak Field Fix Repair
bo030t01 Windshield Wiper Blade Repair and Cleaning
br004t00 Brake Pad Clicking Noise
dl001t99 Propeller Shaft Joint Grease
dl002 Rear Axle Seal Design Change
eg0030 Sulfur Odor from Exhaust
eg003t0x Readiness Monitor Drive Patterns
eg00400t Exhaust Manifold Heat Shield Rattle Noise
eg005t01 Evap System Operation Info
eg007t02 General Maintenance Tip
eg037t04 Engine Bank and Cyl Ident
el006t99 Engine Immobilizer System Precautions
el008t02 Wireless Transmitter and Programming Guide
el011t00 Disable DRL
pa0010 1995 to 2003 Gray Bumper Paint Codes
pa001t00 2000 Model Year Paint Codes
pa003t02 Refinishing Replacement Bumper Covers
pa005t04 Iron Particle Contamination Rust Repair
pg001t00 2000 TSB Information
pg001t03 Repair Manual Correction Index
pg002t00 Repair Manual Correction Index
pg002t0z Repair Manual Correction Index
pg0031 Repair Manual Corrections Index
pg003t04 Repair Manual Correction Index
pg0050 Spare Tire Carrier Operation
pg006t00 Certified Emission Underhood Label Ordering
pg006t01 Replacement Certification Label
pg006t03 Warranty Parts Marking Procedure
pg007t01 Replacement VIN Plates
pg00802t Replacement Certification Labels
pg00902t Replacement VIN Plates
pg021t99 2000 PreDelivery Service
pg027t02 Suspension Ball Joint Inspection
pg031t99 Tire Inflation and Wheel Lug Torque
pg032t99 Y2K Readiness
Seat Belt Extender
ss001t00 Special Service Tools
ss003t00 Evap System Pressure Tester Improvement
st001t01 Steering Wheel Nut Specs
tc001t02 ATF Fluid Requirements
tc0020 ECM Reset Memory Function
tc003t99 ATF Fluids
tc009t04 A340 Solenoid Ident
Service Specifications
AC Service Data
AC Torque Specs
AT A340EF Service Data
AT A340EF Torque Specs
AT A43D Service Data
AT A43D Torque Specs
Body Electrical Service Data
Body Torque Specs
Brake Service Data
Brake Torque Specs
Charging Service Data
Charging Torque Specs
Clutch Service Data
Clutch Torque Specs
Cooling Service Data
Cooling Torque Specs
Emission Control Torque Specs
Engine Mechanical Service Data
Engine Mechanical Torque Specs
Ignition Service Data
Ignition Torque Specs
Lubrication Service Data
Lubrication Torque Specs
Maintenance Torque Specs
Propeller Shaft Service Data
Propeller Shaft Torque Specs
SFI Service Data
SFI Torque Specs
Specified Torque for Standard Bolts
SRS Torque Specs
Standard Bolts
Standard Nuts
Starting Service Data
Starting Torque Specs
Steering Service Data
Steering Torque Specs
Suspension and Axle Service Data
Suspension and Axle Torque Specs
Transfer Service Data
Transfer Torque Specs
Technicians Reference
2000 VIN Number Decode
Customer Interview Sheet
Determining Maintenance Needs
Explanation of Maintenance Items
Fluid Specs
Maintenance Log
Trailer Towing Converter Box Replacement Campaign
Converter Installation Reg Cab
Converter Installation Xtra Cab
Converter Removal
Functional Check
Installation of Bed Harness
Letter to Dealers
Safety Recall Notice
Safety Recall Notice 2
Technical Instructions
Vehicle Inspection
Wiring Diagrams
4 WD
Abbreviations
ABS
Air Conditioning
AT Indicator 2RZFE
Backup Light
Cig Lighter and Clock
Combination Meter with Tach
Connector List
Connectors and Routing
Cruise Control 5VZFE
Door Lock Control
ECT and AT Indicator
ECT California 3RZFE
ECT NonCalif 3RZFE
Electronically Controlled Transmission
Engine Control
Floor Shift Lock
Foreword
Glossary
Ground Point
Headlight with DRL
Headlight wo DRL
Horn
How to Use this Manual
Interior Light
Introduction
Key Reminder and Seat Belt Warning
Light Reminder
Overall Wiring Diagram
Overall Wiring How to read
Parts Position
Power Outlet
Power Source
Power Window
Radio and Player
Relay Locations
SRS
Starting and Ignition
Stop Light
Tail Light and Illumination
Troubleshooting
Turn Signal and Hazard Warning Light
Wiper and Washer
