Hyundai
86
176,834
Toyota LandCruiser 70 Series 2014-2017 Service and Repair Manual
Format: HTML
Brand: Toyota
Type of Machine: Automotive
Type of Manual: Service and Repair Manual, Wiring Diagram
Model: Toyota LandCruiser 70 Series
Engine: 1GR-FE, 1HZ, 1VD-FTV
Model Code:
GRJ7#(GRJ71,GRJ76,GRJ78,GRJ79)
HZJ7#(HZJ71,HZJ76,HZJ78,HZJ79)
VDJ7#(VDJ76,VDJ78,VDJ79)
Region: General, Australia, GCC
Date:
2017.09
2017.01
2016.08
2014.08
Repair Manual
General
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1GR-FE (ENGINE CONTROL)
1HZ (ENGINE CONTROL)
1VD-FTV (ENGINE CONTROL)
1GR-FE (ENGINE MECHANICAL)
1HZ (ENGINE MECHANICAL)
1VD-FTV (ENGINE MECHANICAL)
1GR-FE (FUEL)
1HZ (FUEL)
1VD-FTV (FUEL)
1GR-FE (EMISSION CONTROL)
1HZ (EMISSION CONTROL)
1VD-FTV (EMISSION CONTROL)
1GR-FE (INTAKE / EXHAUST)
1HZ INTAKE / EXHAUST
1VD-FTV (INTAKE / EXHAUST)
1GR-FE (COOLING)
1HZ (COOLING)
1VD-FTV (COOLING)
1GR-FE (LUBRICATION)
1HZ (LUBRICATION)
1VD-FTV (LUBRICATION)
1GR-FE (STARTING)
1HZ (STARTING)
1VD-FTV (STARTING)
CRUISE CONTROL
Drivetrain
CLUTCH
H150F (MANUAL TRANSMISSION / TRANSAXLE)
H152F (MANUAL TRANSMISSION / TRANSAXLE)
R151F (MANUAL TRANSMISSION / TRANSAXLE)
BF1B (TRANSFER / 4WD / AWD)
HF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
Suspension
ALIGNMENT / HANDLING DIAGNOSIS
FRONT SUSPENSION
REAR SUSPENSION
TIRE PRESSURE MONITORING
TIRE / WHEEL
Brake
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
POWER ASSIST SYSTEMS
STEERING COLUMN
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
Power Source / Network
1GR-FE (BATTERY / CHARGING)
1HZ (BATTERY / CHARGING)
1VD-FTV (BATTERY / CHARGING)
NETWORKING
Vehicle Interior
DOOR LOCK
THEFT DETERRENT / KEYLESS ENTRY
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SUPPLEMENTAL RESTRAINT SYSTEMS
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
SLIDING ROOF / CONVERTIBLE
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
WINCH
New Car Features
General
INTRODUCTION
SPECIFICATIONS
1HZ ENGINE MECHANICAL
1GR-FE (FUEL)
1HZ FUEL
1VD-FTV FUEL
1GR-FE EMISSION CONTROL
1HZ EMISSION CONTROL
1GR-FE INTAKE / EXHAUST
1GR-FE (COOLING)
1HZ COOLING
1VD-FTV (COOLING)
1GR-FE LUBRICATION
1HZ LUBRICATION
1VD-FTV LUBRICATION
1GR-FE STARTING
1HZ STARTING
1VD-FTV STARTING
CRUISE CONTROL
Drivetrain
CLUTCH
H150F MANUAL TRANSMISSION / TRANSAXLE
H152F MANUAL TRANSMISSION / TRANSAXLE
R151F MANUAL TRANSMISSION / TRANSAXLE
BF1B TRANSFER / 4WD / AWD
HF1A TRANSFER / 4WD / AWD
Suspension
FRONT SUSPENSION
REAR SUSPENSION
TIRE / WHEEL
Brake
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
STEERING COLUMN
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
WINCH
Electrical Wiring Diagram
Introduction
INTRODUCTION
ABBREVIATIONS
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Suspension
Brake
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Suspension
Brake
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
General
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
