Hyundai
86
176,834
Toyota LandCruiser 200 Series 2014-2016 Service and Repair Manual
Format: HTML
Brand: Toyota
Type of Machine: Automotive
Type of Manual: Service and Repair Manual, Wiring Diagram
Model: Toyota LandCruiser 200 Series
Engine: 1GR-FE, 1UR-FE, 3UR-FE, 1VD-FTV
Model Code:
URJ20#(URJ200,URJ202)
GRJ200
VDJ200
Region: General, Europe, Australia, GCC, China
Date:
2021.01
2020.06
2019.12
2019.08
2018.08
2017.08
2016.08
2015.08
2014.08
Repair Manual
General
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
Engine / Hybrid System
1GR-FE (ENGINE CONTROL)
1UR-FE (ENGINE CONTROL)
3UR-FE (ENGINE CONTROL)
1VD-FTV (ENGINE CONTROL)
1GR-FE (ENGINE MECHANICAL)
1UR-FE (ENGINE MECHANICAL)
3UR-FE (ENGINE MECHANICAL)
1VD-FTV (ENGINE MECHANICAL)
1GR-FE (FUEL)
1UR-FE (FUEL)
3UR-FE (FUEL)
1VD-FTV (FUEL)
1GR-FE (EMISSION CONTROL)
1UR-FE (EMISSION CONTROL)
3UR-FE (EMISSION CONTROL)
1VD-FTV (EMISSION CONTROL)
1GR-FE (INTAKE / EXHAUST)
1UR-FE (INTAKE / EXHAUST)
3UR-FE (INTAKE / EXHAUST)
1VD-FTV (INTAKE / EXHAUST)
1GR-FE (COOLING)
1UR-FE (COOLING)
3UR-FE (COOLING)
1VD-FTV (COOLING)
1GR-FE (LUBRICATION)
1UR-FE (LUBRICATION)
3UR-FE (LUBRICATION)
1VD-FTV (LUBRICATION)
1GR-FE (STARTING)
1UR-FE (STARTING)
3UR-FE (STARTING)
1VD-FTV (STARTING)
CRUISE CONTROL
Drivetrain
A750F (AUTOMATIC TRANSMISSION / TRANSAXLE)
AB60F (AUTOMATIC TRANSMISSION / TRANSAXLE)
AE80F (AUTOMATIC TRANSMISSION / TRANSAXLE)
CLUTCH
H150F (MANUAL TRANSMISSION / TRANSAXLE)
JF2A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
Suspension
SUSPENSION CONTROL
ALIGNMENT / HANDLING DIAGNOSIS
FRONT SUSPENSION
REAR SUSPENSION
TIRE PRESSURE MONITORING
TIRE / WHEEL
Brake
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
POWER ASSIST SYSTEMS
VARIABLE GEAR RATIO STEERING
STEERING COLUMN
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
NAVIGATION / MULTI INFO DISPLAY
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
1GR-FE (BATTERY / CHARGING)
1UR-FE (BATTERY / CHARGING)
3UR-FE (BATTERY / CHARGING)
1VD-FTV (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
THEFT DETERRENT / KEYLESS ENTRY
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SUPPLEMENTAL RESTRAINT SYSTEMS
PRE-CRASH SAFETY
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
SLIDING ROOF / CONVERTIBLE
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
WINCH
New Car Features
General
NEW MODEL OUTLINE
ENGINE
CHASSIS
BODY
BODY ELECTRICAL
APPENDIX
NEW FEATURES [2015/08 Update]
NEW FEATURES [2016/08 Update]
Electrical Wiring Diagram
Body Repair Manual
General
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
