Forklift
Driver
157
1,644,351
Toyota Flashware V4.2 Download
Download this document, you need 10 Gallons
Using Toyota Flashware V4.2
7BPUE15, 7BNCU15-25, 8HBW30, 8HBE30-40, 8HBC30-40, 8TB50
Table of Contents
Introduction…………..…………………………………..………3
Downloading Flashware and .s19 files………………….……4
Connecting to the truck……….………………………………...5
Truck Setup Screen definitions…………………….………….8
Configuration settings
7BPUE15………………………..………………………..11
Class III…………………………………….….………….14
Option settings…………………………………….…………...15
Learn (Calibrate) function (7BPUE15 only)..…….…………17
Diagnostic function
7BPUE15………………………………….………..…….19
Class III………………….………………………………..22
Clear primary memory function
7BPUE15………………………………………………....24
7BNCU15-25………………………………………..……25
Class III………………………………………….………..27
Vehicle Manager Software function…………….…………...28
Adding Software versions to directory…….…………..30
Uploading Software versions from truck………………32
Deleting Software versions from directory.……………35
Loading truck with software version
7BPUE15, 7BNCU15-25……...…………………..36
Class III……………………………………………..38
Saving truck settings to a file
7BPUE15 and 7BNCU15-25……………………………40
Class III……………………………………………………43
Introduction
Toyota Flashware V4.2 is a program available as a download from the TIS website on the Dealer Portal. It is used on the 7BPUE15 orderpicker, the 7BNCU15-25 counterbalanced end-rider models, and 8-Series AC Powered Class III products. Flashware can be used on these trucks to update the software version of the truck and to turn on/off options. Additionally, on the 7BPUE15 orderpicker and 8-Series AC Powered Class III products, Flashware can be used for configuration setting adjustment, calibration, and diagnostics.
For 7BPUE15 and 7BNCU15-25:
Connecting a computer to the truck requires the use of a 9-pin serial cable (Toyota part number 00590-43591-71). It is also recommended that a surge protector (Toyota part number 00590-43592-71) be placed in series with the 9-pin serial cable to protect your computer from possible voltage surges. In many newer laptops, there is no 9-pin serial port to connect to. In these cases, a USB-to-serial adapter will need to be used. While there are many brands and versions available, feedback from the field has shown the adapter made by IOGEAR (IOGEAR part number G-UC232-A) to be the most reliable in working with Flashware. This adapter is available at most electronics supply stores or at www.iogear.com.
For 8HBW30, 8HBE30-40, 8HBC30-40, 8TB50:
Connecting a computer to the truck requires the use of a special interface cable and a connection cable. The special interface cable is designed to connect to a USB port.
