Toyota C-HR 2016-2022 Service and Repair Manual
- Download this document, you need 2725 Gallons
Format: HTML
Brand: Toyota
Type of Machine: Automotive
Type of Manual: Service and Repair Manual, Wiring Diagram
Model: Toyota C-HR
Engine: 8NR-FTS, 3ZR-FAE
Model Code: NGX10, NGX50, ZGX10
Region: General, Europe, Russia, Australia
Date:
2022.01
2021.09
2020.12
2020.08
2019.09
2018.05
2016.10
Repair Manual
General
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
8NR-FTS (ENGINE CONTROL)
3ZR-FAE (ENGINE CONTROL)
8NR-FTS (ENGINE MECHANICAL)
3ZR-FAE (ENGINE MECHANICAL)
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS (EMISSION CONTROL)
3ZR-FAE (EMISSION CONTROL)
8NR-FTS (INTAKE / EXHAUST)
3ZR-FAE (INTAKE / EXHAUST)
8NR-FTS (COOLING)
3ZR-FAE (COOLING)
8NR-FTS (LUBRICATION)
3ZR-FAE (LUBRICATION)
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
CRUISE CONTROL
Drivetrain
CLUTCH
EC6A (MANUAL TRANSMISSION / TRANSAXLE)
K114 (MULTIDRIVE / CVT)
K313 (MULTIDRIVE / CVT)
K313F (MULTIDRIVE / CVT)
GF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
Suspension
ALIGNMENT / HANDLING DIAGNOSIS
FRONT SUSPENSION
REAR SUSPENSION
TIRE PRESSURE MONITORING
TIRE / WHEEL
Brake
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
POWER ASSIST SYSTEMS
STEERING COLUMN
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
NAVIGATION / MULTI INFO DISPLAY
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
8NR-FTS (BATTERY / CHARGING)
3ZR-FAE (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
THEFT DETERRENT / KEYLESS ENTRY
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SUPPLEMENTAL RESTRAINT SYSTEMS
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
General
INTRODUCTION
SPECIFICATIONS
3ZR-FAE ENGINE MECHANICAL
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS COOLING
3ZR-FAE COOLING
8NR-FTS LUBRICATION
3ZR-FAE LUBRICATION
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
CRUISE CONTROL
Drivetrain
CLUTCH
Suspension
FRONT SUSPENSION
REAR SUSPENSION
TIRE / WHEEL
Brake
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
STEERING COLUMN
AUDIO / VIDEO
TELEMATICS
3ZR-FAE BATTERY / CHARGING
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
ABBREVIATIONS
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Suspension
Brake
Steering
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Suspension
Brake
Steering
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
General
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
Format: HTML
Brand: Toyota
Model: Toyota C-HR
Date:
2022.01
2021.09
2020.12
2020.08
2019.09
2018.05
2016.10
Repair Manual
General
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS (COOLING)
3ZR-FAE (COOLING)
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
CRUISE CONTROL
Drivetrain
CLUTCH
Suspension
FRONT SUSPENSION
REAR SUSPENSION
TIRE / WHEEL
Brake
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
STEERING COLUMN
AUDIO / VIDEO
TELEMATICS
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
New Car Features
General
INTRODUCTION
SPECIFICATIONS
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS COOLING
3ZR-FAE COOLING
8NR-FTS LUBRICATION
3ZR-FAE LUBRICATION
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
CRUISE CONTROL
Drivetrain
CLUTCH
Suspension
FRONT SUSPENSION
REAR SUSPENSION
TIRE / WHEEL
Brake
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
STEERING COLUMN
AUDIO / VIDEO
TELEMATICS
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Introduction
INTRODUCTION
ABBREVIATIONS
System Circuit
Drivetrain
Suspension
Brake
Steering
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Suspension
Brake
Steering
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
General
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
- Toyota Prius 2010 (ZVW30) Service Repair Manual
- Toyota Hiace 1989-2004 Workshop Manual
- Toyota Fortuner 2011 Workshop Manual
- TOYOTA HIGHLANDER 2014 Workshop Manual
- Toyota Engine 2TR-FE Repair Manual
- Toyota GSIC - Global Service Information Center 2001-2018 Online
- GSIC Toyota Hilux 2005-2013 Workshop Manual
- Toyota Engine 2RZ-FE;3RZ -FE EWD Repair Manual
- Toyota Hiace 2010 Workshop Manual
- Toyota Avensis Verso 2001-2007 Workshop Manual
- Toyota Prado 2014 GSIC GRJ150 TRJ150,155 KDJ150,155 LJ150
- Toyota Innova 2010 Workshop Manual
- TOYOTA CAMRY 2015 Workshop Manual
- GSIC Toyota Avanza F651,F652 2011- Workshop Manual
- Toyota Landcruiser 200 Series Workshop Manual
