Hyundai
85
171,303
Tigercat Track Loader T250B Operator Manual
Brand: Tigercat
Type of Machine: Track Loader
Model: Tigercat T250B Track Loader
Publication Date: 2009
Number of Pages: 96 Pages
T250B OPERATOR ISSUE
INTRODUCTION​
NON-APPROVED FIELD PRODUCT CHANGES​
SECTION 1 - SAFETY
battery disconnect switch​
cooling system​
exhaust fumes​
FIRE PREVENTION​
first aid​
FLUID INJECTION INJURY​
Fluid leaks​
GREASE INJECTION INJURY​
LIGHTNING SAFETY AWARENESS​
loose clothing hazard​
protective clothing​
SAFETY PRECAUTIONS, OPERATING​
SAFETY PRECAUTIONS, SERVICING​
SAFETY SYMBOLS​
Signal Words​
SECTION 2 - CONTROLS AND OPERATION
AIR CLEANER​
AIR COMPRESSOR/VACUUM​
AIR CONDITIONER/HEATER​
AIR FILTER​
AIR FILTER RESTRICTION INDICATOR​
AM/FM STEREO RADIO/CD​
ANTISTALL - SWITCH​
AUXILIARY POWER​
BATTERY DISCONNECT SWITCH​
BULB TEST SWITCH​
CAB TILTING​
CARE OF MACHINE​
CASE DRAIN STRAINERS​
CHARGE TANK - SWITCH​
CHECK ENGINE OIL LEVEL​
CLEANING A/C CONDENSER AND COOLER PACKAGE​
CONTROL PANEL​
CONTROLS​
DISPLAY MODULE​
DRIVE SPEED SWITCH​
ENGINE COMPARTMENT​
ENGINE OIL LEVEL​
ENGINE SPEED SWITCH​
ENGINE STARTING​
ENGINE STOPPING​
FAN - VENTILATION​
FAN SPEED​
FILTER​
FILTERS​
FIRE EXTINGUISHER​
FOOT PEDAL​
FUEL TANK AND FILLER​
FUSE AND RELAY PANEL - CAB​
FUSES AND RELAYS - ELECTRICAL BOX​
HAND FILL PUMP​
HORN​
HOT WATER SHUT OFF VALVE​
HYDRAULIC OIL​
HYDRAULIC PRESSURIZATION SYSTEM​
HYDRAULIC RETURN FILTERS​
HYDRAULIC TANK VENT FILTER​
JOYSTICK LEVER​
JOYSTICK SWITCHES​
KEY SWITCH​
LIGHT - DOME​
MACHINE OPERATION​
MACHINE PREPARATION​
OPERATOR'S SEAT​
PILOT SWITCH​
PRE-START CHECKS​
PUMP INLET - RED WARNING LIGHT​
PUMP INLET - WARNING LIGHT​
PUMP INLET PRESSURE​
RADIO 2 WAY​
SEAT​
SERVICE LIGHTS​
STARTING THE ENGINE​
STEERING​
STOPPING THE ENGINE​
THROTTLE CONTROL​
TRACK DRIVE​
TRAVELLING​
WAIT TO START - YELLOW LIGHT​
WARNING LIGHTS​
WINDOWS​
WINDSHIELD WASHER FLUID​
WINDSHIELD WIPER/WASHER​
WORK LIGHTS​
SECTION 3 - LUBRICATION & MAINTENANCE
AIR CLEANER​
AIR CONDITIONING​
APPROVED HYDRAULIC OILS​
CASE DRAIN STRAINER​
ELECTRICAL SCHEMATIC​
HYDRAULIC OIL RETURN FILTERS​
LUBRICATION AND SERVICE POINTS​
NEW MACHINE MAINTENANCE​
OIL LOST FROM LEAKAGE​
OIL SAMPLE COLLECTION PROCEDURES​
OIL SAMPLING PROGRAM​
PAG OIL​
PILOT PRESSURE FILTER​
PRESSURE SETTINGS FOR T250B LOADER ON TRACKS​
PRESSURIZATION​
PREVENTIVE MAINTENANCE SCHEDULE​
REFRIGERANT​
SCHEDULED MAINTENANCE​
TORQUE, FLUID CONNECTIONS​
TORQUE SETTINGS, RECOMMENDED​
TORQUE SPECIFICATIONS - GENERAL​
UNLOADER VALVE​
VACUUM PUMP​
