Tigercat Mulcher M726E Operators Manual 29847A
Brand: Tigercat
Type of Machine: Mulcher
Model: Tigercat M726E Mulcher
Serial Number: 726M3501 And Up
Part Number: 29847A
Publication Date: 2010
Number of Pages: 170 Pages
Introduction
S.A.E. Standards
Non-Approved Field Product Changes
Section 1 - Safety
Boom Lift Lock
Cab Exits
Emergency Cab Exits
Engine Access Panels
Fire Prevention
Fluid Injection Injury
Grease Injection Injury
Hazard Zone
Lightning Safety Awareness
Mulching Operation Safety
Parking The Machine
Safety Interlock Switches On Cab Doors
Safety Labels
Safety Precautions, General
Safety Precautions, Operating
Safety Precautions, Servicing
Safety Symbols
Signal Words
Appendix -
Using High Speed Disc Saws Safely
Comments And Instructions
Dangers
Forward
High Angle Wrist Rotation Capability
Saw Head Don'ts
Type Of Housing Makes A Difference
Section 2 - Controls And Operation
Accumulating Arms
Air Cleaner, Engine Air
Air Cleaner Unloader Valve
Air Compressor
Air Compressor - Air Supply
Air Conditioner/Heater
Air Supply
Air Vents
Articulation Lock Bar
Attachment Mode Selection
Auxiliary Power Outlet
Battery Disconnect Switch
Boom Cylinder Lock
Boom Float
Boom Lift
Boom Lift Lock
Brakes
Bulb Test Switch
Center Joint Lock Pin
Changing The Attachment
Cigar Lighter
Clamp Arms
Cleaning A/C Condenser, And Cooler Package
Cleaning Instructions For Glass Windows
Controls - Cab
Cutter Switch
Dome Light
Drive Control
Drive Limiter
Emergency Exit/Skylight
Engine Air Precleaner
Engine, Hot Water Shut Off Valve
Engine, Restarting After Running Out Of Fuel
Engine, Starting
Engine, Starting, Cold Weather
Engine, Stopping
Fan Switch
Filter - Cab Fresh Air
Filter, Recirculating Air - A/C Unit
Fire Detection System
Fire Extinguisher
Foot Control, Center
Foot Control, Left
Foot Control, Right
Fuse And Relay Panel
Gauges
Gear Shift Lever
Head Tilt
Horn Switch
Hot Water Shut Off Valve (Engine)
Hydraulic Hand Fill Pump
Hydraulic Oil Tank
Icons, Pictogram Descriptions
Instrument Panel
Joystick, Left
Joystick, Right
Key Switch
Light - Dome
Lights Switch, Working, Rear
Lights Switch, Working, Front
Machine Preparation
Moving Instructions
Operating Machine
Pilot System Shut Off
Precleaner, Engine Air
Pressurized Water System
Pressurizing The Hydraulic Tank
Radio, Am/Fm Stereo / Cd Player
Saw/Mulcher Multifunction Option
Skylight/Emergency Exit
Speed Control Lever
Starting Engine
Steering
Stereo Radio/Cd Player
Stopping Engine
Throttle Control Switch
Towing Instructions
Transporting Instructions
Vehicle Moving Instructions
Venting The Hydraulic Reservoir
Wait To Start
Warning Lights
Water System, Pressurized
Windows
Section 3 - Lubrication & Maintenance
Air Cleaner Maintenance
Air Conditioning System, Checking
Belt, Engine Serpentine, Replacing
Blink Codes
Center Joint
Drive Shaft Spline Lubrication, Middle And Rear
Emergency Exits, Check Daily
Filters
Fire Prevention
Hydraulic Oils
New Machine Maintenance
Oil Lost From Leakage
Oil Sample Collection Procedures
Oil Sampling Program
Pressure Settings
Pressurized Water System Maintenance
Scheduled Maintenance
Service And Lubrication Points Chart
Speed Control Lever Adjustment
Startup Procedure After Maintenance
Torque Chart
Torque, Fluid Connections
Torque Specifications - General
Weights Of Commercial Wood
Wheels, Installing
