Tigercat Harvester H822C LH830C Service Manual 29532A
Brand: Tigercat
Type of Machine: Harvester
Type of Manual: Service Manual, Electrical Schematics
Model: Tigercat H822C LH830C Harvester
Serial Number:
H822C: 82231001 To 82231999
LH830C: 83081001 To 83081999
Part Number: 29532A
Publication Date: 2006
Number of Pages: 286 Pages
H822c Lh830c Service Issue 1.0
Introduction
Non-Approved Field Product Changes
Section 1 - Safety
Battery Safety
Cab Exits
Emergency Cab Exits
Engine Doors
Er Boom System Precautions
Exhaust Fumes
Fire Prevention
Fluid Leaks
Harvesting Attachment - General Safety
Hazard Zone
Hydraulic Pressure Hazard
Loose Clothing Hazard
Machine Stability And Traction
Parking Boom
Parking The Machine
Protective Clothing
Safety Interlock Switches On Cab Doors
Safety Precautions, General
Safety Precautions, Operating
Safety Precautions, Servicing
Safety Symbols
Signal Words
Welding, Prior To
Working With Oil
Section 3 - Lubrication & Maintenance
Access Door, Undercarriage, Swivel
Air Conditioning, Checking The System
Air Intake Maintenance
Approved Hydraulic Oils
Checking The Air Conditioning System
Emergency Exits, Check Monthly
Engine Air Cleaner Maintenance
Er Boom System
Filter And Lubrication Schedule
Filters
Filters, Hydraulic Oil
Fire Prevention
General Maintenance
Hydraulic Oil Filters
Hydraulic Oils
Lubrication Points Diagram, Leveller Components
New Machine Maintenance
Oil Lost From Leakage
Parking Boom
Preventive Maintenance Schedule
Scheduled Maintenance
Service Platform (If Equipped)
Swing Drive Gearbox
Torque Chart
Torque Chart, General
Torque, Fluid Connections
Section 4 - Hydraulic System
Hand Fill Pump, Hydraulic Oil
High Pressure Limiting Control Valve
Hydraulic Oil Level Sight Gauges
Hydraulic Oil Tank
Hydraulic Pumps
Hydraulic System Operation
Hydraulic Tank
Load Sensing
Main Control Valve/Manifold
Pilot Filter, High Pressure
Schematic Diagrams
Section 5 - Pilot System
Accumulator
Circuit Description
Circuit Diagram
Electrical Circuit
Pilot System Components
Pressure Settings
Section 6 - Electrical, Gauges, Alarms And Computers
Cab Module
Channels
Computer Control System (Iqan Mdm Display)
Current Out - Troubleshooting For Open Circuits
Downloading Applications From Dealer Website
Electrical Installation - Cab
Electrical Kit - Service And Diagnostics
Engine Module
Error Messages And Alarms
Fault Codes : Error Messages
Fuses And Relays
Get Application
Get Error/Event Log
Id-Tag
Iqan
Iqan Software
Main System Errors
Pda Registration
Rear Electrical Panel
Switch And Sensor Locations
Update Application
Wire Colour Code Chart
Section 7 - Engine Start And Stop
Engine, Restarting After Engine Run Out Of Fuel
Engine, Starting
Engine, Starting, Cold Weather
Engine, Stopping
Schematic Diagram
Starting Engine
Section 9 - Engine Anti-Stall
Control Module In Cab
Control Module Pin Connections
Engine Anti-Stall Curve
Engine Anti-Stall Switch
Fault Finding Procedure ~ Anti-Stall Quick Check
Fault Finding Procedures, Additional
Horsepower Limiting Control
Load Sense; Set Margin Pressure See Section 4
Pump 2 (Main Pump) Controller (Ls Control)
Schematic Diagrams
Set Pilot Pressure See Section 5
Speed Sensor, Adjusting
Speed Sensor On Engine
Verify Anti-Stall Setting See Section 4
Section 10- Oil Cooler And Cooling Fan
Charge Air Cooler
Cooling Assembly - Overall View
Cooling Fan
Cooling Fan Circuit Description
Cooling Fan Circuit Diagram
Fan Drive Control Valve
Fan Motor
Fan Pump (Rotate/Fan Pump)
Fan Speed Checks
Hydraulic Tank
Main Control Valve See Section 4
Main Pump See Section 4
Oil Cooler Bypass/ Return Manifold
Oil Cooler Circuit Description
Oil Cooler Circuit Diagram
Return Manifold/Return Filters
Section 11 - Track Drive
Brake Circuit Description
Circuit Diagram, Drive System
Drive Motor
Drive Motor And Gearbox Assembly
Gearbox And Drive Motor Assembly
Hydrostatic Drive System
Important Track Drive Notes
Left Track Speed Adjustment
Pressure Settings, Drive System
Right Track Speed Adjustment
Schematic Diagrams
Set Straight Travel
Track Components
Track Drive Assembly
Track Speed Set-Up Procedure
Section 12 - Boom Functions
Adjust Oil Flow To Cylinders (Cylinder Cycle Times
Boom Control Valve
Boom System Description
Circuit Diagram
Cylinder Cycle Times, Typical
Engine Anti-Stall
Er Boom System
Load Sensing
Parking Boom
Set Main Boom, Stick And Telescopic Port Relief Va
Telescopic Boom Electronic Adjustment Procedure
Telescopic Cylinder Flow Adjustment
Section 13 - Levelling
Circuit Diagram
Engine Anti-Stall See Also Section 4
Levelling Control Valve See Also Section 4
Levelling System Description
Load Sensing See Section 9
Lubricating Cylinders And Pins See Section 3
Undercarriage Assembly, Levelling
Section 15 - Swing
Adjust Oil Flow To Swing Motor(Swing Motor Speed)
Circuit Diagram
Parking Boom
Set Swing Motor Speed
Swing Drive
Swing Drive Gearbox
Swing Motor Removal From Gearbox
Section 17 - Attachment Drive
Attachment Control Valves
Attachment Head See Original Manufacturers Manual
Circuit Description
Circuit Diagram
Engine Anti-Stall
Load Sensing
Main Control Valve
Pressure Settings
Pump 1 (Attachment Pump)
Pump 2 (Main Pump) See Section 4
Pump 2 Electronic Adjustment Procedure
Set Pump 2 Port Relief Valves
Section 20 - Rotate
Attachment Valve - Rotate Section
Circuit Description
Circuit Diagram
Control Valve
Pressure Settings
Rotate Pump (Rotate/Fan Pump)
Brand: Tigercat
Serial Number:
Part Number: 29532A
Introduction
Section 1 - Safety
Battery Safety
Cab Exits
Emergency Cab Exits
Engine Doors
Exhaust Fumes
Fire Prevention
Fluid Leaks
Hazard Zone
Parking Boom
Parking The Machine
Protective Clothing
Safety Symbols
Signal Words
Welding, Prior To
Working With Oil
Er Boom System
Filters
Fire Prevention
General Maintenance
Hydraulic Oils
Parking Boom
Swing Drive Gearbox
Torque Chart
Hydraulic Oil Tank
Hydraulic Pumps
Hydraulic Tank
Load Sensing
Schematic Diagrams
Accumulator
Circuit Description
Circuit Diagram
Electrical Circuit
Pressure Settings
Cab Module
Channels
Engine Module
Fuses And Relays
Get Application
Get Error/Event Log
Id-Tag
Iqan
Iqan Software
Main System Errors
Pda Registration
Update Application
Engine, Starting
Engine, Stopping
Schematic Diagram
Starting Engine
Schematic Diagrams
Charge Air Cooler
Cooling Fan
Fan Motor
Fan Speed Checks
Hydraulic Tank
Drive Motor
Schematic Diagrams
Set Straight Travel
Track Components
Boom Control Valve
Circuit Diagram
Engine Anti-Stall
Er Boom System
Load Sensing
Parking Boom
Circuit Diagram
Section 15 - Swing
Circuit Diagram
Parking Boom
Swing Drive
Swing Drive Gearbox
Circuit Description
Circuit Diagram
Engine Anti-Stall
Load Sensing
Main Control Valve
Pressure Settings
Section 20 - Rotate
Circuit Description
Circuit Diagram
Control Valve
Pressure Settings
- Tigercat 620D 630D Skidder Operator's & Service Manual
- Tigercat 630 Skidder Operator's & Service Manual
- Tigercat 620E 630E 635E Skidder Operator's Manual
- Tigercat 234 Loader Operator's Manual, Service Manual
- Tigercat 620C Skidder Operator's & Service Manual
- Tigercat 860C 870C L870C Feller Buncher Operator's & Service Manual
- Tigercat 620 Skidder Operator's & Service Manual
- Tigercat NAF Bogie Axle Service & Repair Manual_35979A
- Tigercat Flexxaire Fan Rebuild Manual_01525
- Tigercat 1055B,1075B,1085B Forwarder Service Manual
- Tigercat 720E Feller Buncher Operator's & Service Manual
- Tigercat FPT Tier 4i N45 Fault Codes Chart
- Tigercat 1075C 1085C Forwarder Operator's Manual
- Tigercat 630B Skidder Operator's & Service Manual
- Tigercat Hultdins Super Grip SG Grapple Parts Manual_36249A
