Tigercat FPT Engine N45 N67 Operation And Maintenance Manual 78254AENG
Brand: Tigercat, FPT
Type of Manual: Operation And Maintenance Manual
Model: Tigercat N45 N67 Engine
STAGE V
TIER 4F
TIER 2
NON-CERTIFIED
Part Number: 78254AENG
Publication Date: 2025
Number of Pages: 54 Pages
Introduction
STAGE V
TIER 4F
TIER 2
NON-CERTIFIED
Introduction
Available Literature
Warranty Certificates
Introduction
Engine Identification
Non-Approved Field Product Changes
SafetySafety Alert Symbol
Signal Words
Personal Protective Equipment (PPE)
Keep Clear of Moving Parts
Prevent Exhaust Build-Up
Hazardous Materials
Handling Hazardous Materials
Disposing of Materials
Working with Diesel Fuel
Working with Oil
Precautions for Starting the Engine
Precautions for Stopping the Engine
Performing Maintenance With the Engine Running
Technical OverviewEngine Technical Data
N45 Component Location Diagram
N67 Component Location Diagram
N45/N67 Electrical Component Locations
Lubrication Circuit
Fuel Circuit
OperationPre-Start Checks
Starting Engine
Cold Weather Starting
Operating the Machine During the Break-In Period
Restarting an Engine That Has Run Out of Fuel
Hot Engine Shutdown Prevention Strategy
Tier 4F Machines
Tier 2/Non-Certified Machines
Temperate Engine Shutdown
Hot Engine Shutdown
Computer Messages
Engine Malfunctions
MaintenanceGuidelines for Performing Engine Maintenance
Moving the Engine
Maintenance Schedule
Engine Break-In Oil Service Schedule
Fluid Capacities
Fuel Specifications
Tier 4f Engines
Tier 2/Non-Certified Engines
Biodiesel
Fuel Additives
Engine Coolant Specifications
Ethylene Glycol Based Coolant (IAT)
Ethylene Glycol Based Coolant (HOAT)
Engine Oil Specifications
Refuelling
Visual Engine Check
Check for Water in the Fuel/Water Separator
Replacement of Fuel/Water Separator Filter
Check the Engine Oil Level
Replacement of Engine Oil and Filter
Replacement of Primary Fuel Filter
Replacement of Crankcase Ventilation Filter (CCV) (Tier 4f and Stage V Only)
Inspection and Replacement of Serpentine Belt
Periodic Inspections
Inspect the Intake Air Filter
Inspect the Turbocharger
Inspect the Electrical Starter System
Adjusting the Valve/Rocker Arm Clearance
Storing the Engine
End of Service Life
Preparing the Engine for Disposal
Disposing of Fluids and Components
- Tigercat 620D 630D Skidder Operator's & Service Manual
- Tigercat 630 Skidder Operator's & Service Manual
- Tigercat 620E 630E 635E Skidder Operator's Manual
- Tigercat 234 Loader Operator's Manual, Service Manual
- Tigercat 620C Skidder Operator's & Service Manual
- Tigercat 860C 870C L870C Feller Buncher Operator's & Service Manual
- Tigercat 620 Skidder Operator's & Service Manual
- Tigercat NAF Bogie Axle Service & Repair Manual_35979A
- Tigercat Flexxaire Fan Rebuild Manual_01525
- Tigercat 1055B,1075B,1085B Forwarder Service Manual
- Tigercat 720E Feller Buncher Operator's & Service Manual
- Tigercat FPT Tier 4i N45 Fault Codes Chart
- Tigercat 1075C 1085C Forwarder Operator's Manual
- Tigercat 630B Skidder Operator's & Service Manual
- Tigercat Hultdins Super Grip SG Grapple Parts Manual_36249A
