702,019
Terragator TG9300C Chassis & Systems Parts Catalog 652377
Brand: Challenge Terragator
Type of Machine: Applicators
Type of Manual: (Chassis & Systems) Parts Catalog
Model: Challenge TG9300C Terragator Chassis & Systems (2019-2021)
Serial Number: ..KXXX1001-..MXXX9999
Part Number: 652377
Number of Pages: 2675 Pages
C Series
Fuel Filters
Electronic Engine Management
Exhaust Aftertreatment
Engine Overhaul Parts
Air Intake Group
Air Cleaner, Psd12
Standard
With Fuel Water Separator
Fuel Filter, Complete
Transmission, Cvt, Ml260
Filter
Lube Oil Pump
Vario
Valve Block Assembly
Air Dryer, Single Canister
Tank Assembly
Hydraulic Filter Assembly
Heating, Ventilation And Air Conditioning Group
System Plumbing Assembly, With Hydraulic And Pressure Washer
Pressure Washer Pump And Motor Assembly
Reel Assembly
Pressure Washer
Engine V835477814 98 Awf-Hla
Engine Assemblies
Hydraulic Lash Adjustment
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Valve Rocker Cover
Intake Manifold
M12 Turbo Mounting Stud Bolts
Oil Pump And Sump
Up To Engine Serial Number D60550
Starting From Engine Serial Number D60551 Jld291001
Up To Engine Serial Number D79632
Starting From Engine Serial Number D79633
Coolant Pump And Thermostat
Fuel Injection System
Fan Drive
Air Compressor
Special Overhaul Parts
Engine Acw6767720 98 Awf-Hla
Oil Cooler And Filter
Coolant Piping
Engine Installation
9.8 Liter
Cooler Assembly
Def System Installation
Def Tank Group
Driveline Cover Group
Driveline Cover
Engine Group
Engine Mount Group
Exhaust Group
Tier 4, Final Compliant
Fuel Tank Installation, Locking Cap
Locking Cap
Fuel Tank Installation, Standard Cap
Fuel Tank Assembly, 100 Gallon, Left Hand
Fuel Tank Assembly, 100 Gallon, Right Hand
19.8 1
9300
Tag Axle Installation
Hydraulic Installation
Hydraulic Hose Clamp Installation
Hydraulic Hose Installation
Hydraulic Block Installation
Mechanical Installation
Wheel Assembly
Hydraulic Block Assembly
Assisted Steering
Assisted Steering Unit Installation
Short Extension Adapter Kit
Steering Control
Steering Column Assembly
Tilt And Telescoping Box Kit
Steering Pump Group, Eaton
Steering Pump, 62cc
Priority Valve Assembly
Driveline Installation
Cvt Transmission Group
Adjusting Device
Valves
Engine P.T.O.
Front Drive Input Assembly
Output
Gear
Interior
Gear Box Lubrication
Gearbox-Housing
Group Gear Shifting
Oil Level Indicator
Pump Drive
Pump Installation
Shifting
Suspension
Installation
Brake Valve Installation
Brake Actuator Assembly
Brake Valve Assembly
Brake Valve Assembly, E-6
Airline And Fitting Installation, Park Brake
Air System
Hose Clamp Installation, Air System
Governor And Air Dryer Installation
Governor And Air Dryer Assembly
Air Governor
Reservoir Tank Assembly, Left Hand
Reservoir Tank Assembly, Right Hand
Tg9300
Control Box Installation, Air Electrical
Air Valve Box Assembly, 7 Section, With End Row
Air System Installation, Quick Exhaust, Endrow
7 Section
Quick Exhaust Valve Assembly
Air Plumbing Installation, Quick Stop, End Row, 60 80 Foot
Quick Stop Valve, 1.00npt X 0.75npt
Air Plumbing Installation, Quick Stop, 30 Inch, 60 80 Foot
Air Plumbing Installation, Quick Stop, 60 Inch, 60 80 Foot
Air Spreader
Granular
Manifold Assembly
Airline Installation, Air Spreader
Multibin
Circulator Pump Installation
Gear Pump, 25cc, Tang
Hose Installation
Steering Cylinder Installation
Steering Cylinder Assembly, Left Hand
Steering Cylinder Assembly, Right Hand
Cap
Adapter, 3.00 Flange X 4.00 Hose Barb
Boom Hoist Cylinder Assembly
Large Tree
Boom Tilt Cylinder Assembly, Left Hand
Boom Tilt Cylinder Assembly, Right Hand
Boom Tilt Cylinder, With Autoboom, Left Hand
Norac
Boom Tilt Cylinder, With Autoboom, Right Hand
Boom Tip Fold Cylinder Assembly
Auto
Autoboom
Valve Block Assembly, Autoboom, Raven
Norac, Passive
Low Volume
Mid High Volume, 2400 Gallon
Hydraulic Charge Filter Installation
Hydraulic Cooler Installation
60 80
60 80 Auto
60 80 Norac
60 80 Norac, Auto
80 Auto
80 Foot
Hydraulic Damper Cylinder Installation, Norac, Large Boom
Passive
Hydraulic Hose Installation, Terragator Boom Norac
1800 Gallon
Hydraulic Pump, 45cc Ep Control
2400 Gallon
1800 Liquid
Low Volume, 2400
Hydraulic Tank Installation
Hydraulic Hose Installation, Airmax Precision
Hydraulic Component Installation
Low Pressure Hydraulic Filter Assembly
Sequence Valve Assembly, Air Max
Hydraulic Filter Assembly, High Pressure, 4000 Psi, Amp
Hydraulic Reservoir Assembly
Hydraulic Valve Assembly, Fan
Hydraulic Component Installation, Pwm Valve Amp 1
Hydraulic Valve Assembly, Conveyor, Amp 1
Hydraulic Valve, Pwm 15gpm, Air Max Precision 1
Hydraulic Component Installation, Pwm Valve Amp 2
Hydraulic Valve Assembly, Conveyor, Amp 2
Hydraulic Valve, Pwm 15gpm, Air Max Precision 2
Tg7300c Tg8300c Tg8400c
Hydraulic Valve
Air Max Precision
Hydraulic Pump Installation, Amp, Bosch
Hydraulic Pump Assembly, Air Max Precision, Bosch
Piston Pump, 90cc, Right Hand
Tg9300c
Hydraulic Pump Installation, Air Max Precision, 9300
Hydraulic Hose Installation, Air Max Precision 2
Hydraulic Tank Heater Installation, 120 Volt
Hydraulic Cap And Plug Installation
Hydraulic Hose Installation, Twin Bin
Hydraulic Routing Accessories
Bulkhead Assembly, Fan Motor
Fan Speed Servo Valve Installation
Fan Speed Servo Valve Assembly
Gauge Installation, Fan Auger
High Pressure Filter Assembly
Hydraulic Filter Assembly, Twin Bin And 4 Bin
Hydraulic Plumbing Assembly, Valve
Hydraulic Pump Tee Installation
Hydraulic Tank Assembly
Hydraulic Tank Mount
Hydraulic Valve Assembly, Auger Control
Hydraulic Valve Assembly, Conveyor Speed
Hydraulic Valve Assembly, Flow Control
Hydraulic Valve Installation, Twin Bin Boom Block
Tg8300 Tg8400
Hydraulic Motor Assembly, Metering, Mechanical
Hydraulic Motor, 26 Cid
Oil Tank Heater Installation, 110 Volt
Piston Pump, 60 Cc, Right Hand
Hydraulic Hose Installation, Four Bin
Hydraulic Assembly, Main System
Tube Assembly
Hydraulic Valve Block Assembly
40 Gpm
Hydraulic Tank And Cooler Assembly
New Leader G4 Edge
Return Filter
Cooler Assembly, Hydac Eld4.5
Hydraulic Assembly, Main System, Hp Multapplier Ready, 14 Foot
High Performance
40 20 Gpm
Hydraulic Assembly, Main System, Hp Multapplier Ready, 15 Foot
Hydraulic Assembly, Main System, Multapplier Ready, 14 Foot
With Relief
Valve Assembly, Sfp 5gpm
Load Sense
New Leader
Hydraulic Hose Installation, L4000g4hp
Hydraulic Pump Installation, L4000g4hp
L4500g4 Edge
Hydraulic Installation, L4500g4 Edge, 73xx 83xx
Hydraulic Hose Installation, L4500g4 Edge, 73 83xx
Hydraulic Pump Installation, L4000g4 Edge
Hydraulic Installation, L4500g4, 93xx
Hydraulic Hose Installation, L4500g4, 93xx
Hydraulic Installation, L4500g4ma, 73xx 83xx
Hydraulic Hose Installation, L4500g4ma
Hydraulic Pump Installation, L4500g4ma
Hydraulic Installation, L4500g4ma, 93xx
Hydraulic Hose Installation, L4500g4ma, 93xx
Hydraulic Installation, L4500g4mb, 73xx 83xx
Hydraulic Hose Installation, L4500g4mb
Hydraulic Installation, L4500g4mb, 93xx
Hydraulic Installation, L4500hpg4
Hydraulic Hose Installation, L4500g4hp
Hydraulic Tank And Cooler Group, High Performance
30 Gpm
Loose System Only
Cartridge, 40gpm Servo
Cartridge, T, 9gpm Servo
Chain Oiler Assembly
Left Hand
Right Hand
Tank
Pump Assembly With Connector
Cover Cylinder Assembly
Lid Valve Group
Valve Assembly
Suction Fittings, 20jic
Suction Fittings, 32jic
Valve Assembly, Sfp 9gpm
73xx 8xxx
93xx
Load Sense, Rexroth
Hydraulic Hose Installation, L5000g4ma, 93xx
Hydraulic Assembly, Main System, 14 Foot, G5
Single Bin
Spreader Control Valve
G5
Multi Product, 14 Foot
Cylinder Control Valve
7 Foot
Hydraulic Group, Multapplier, 14 Foot
14 Foot
Fitting Group -20 Orfs
Piston Pump, 100 Cc, Right Hand
Speed Sensor
5 Gpm-A, Spf
5 Gpm-B, Spf
Valve Assembly, Sfp 10gpm
Beacon Group
Terragator
Cab Fuse Installation
Electric Horn Installation
Starter
Housing Assembly, Power Port
No Remote Throttle Installation
Powerstrip Assembly
Plug Assembly
Radio Installation, Cd, Xm ,Blue Tooth, Usb
Assembly
Reverse Alarm Installation
Wheel Angle Sensor Installation
Support Installation, Amber Flashing Warning Light Worklight
Support Assembly, Turn Signal, Left Hand
Support Assembly, Turn Signal, Right Hand
Halogen
Led
Bare Chassis
Amber Warning Flashing Light Installation
Autoboom Harness Installation
Liquid System
Electrical Box Cover
Electric Installation, Norac, Passive
Uc7
2019
2021
Node Installation
Raven
Reload
Rotating Beacon Lamp Assembly
Fender
Taillight Installation, Liquid System
Clamp
#3
Worklight, Dual Beam
Air Max 1000
Clamping Installation
Air Max 2000
Air Max Precision 1
Raven Controller
Electrical Installation, Roll Tarp
Electrical Group
Electrical Box Assembly
Granular, Power Distribution Box Assembly
Fuse Installation
Motor, Electrical, Twin Output
Airmax Precision
Bumper
No Worklight
Twin Bin
Electrical Installation, Control Box
Common Electrical Box Assembly
Bracket Assembly
Air Spreader, Terragator
No Beacon Option
Tgc
Granular, Power Harness Installation, Air Spreader
Rework Electrical Assembly Pickup
Speed Reducer
Motor Electrical 12 Volt Dc
Worklight Installation, Halogen
Worklight Installation, Hid
Worklight Installation, Led
Four Bin
15 Foot
Electric Roll Tarp Installation
No Roll Tarp Installation, New Leader
Module Group, Body Control
Reverse Camera Installation
Taillight Installation, Euro
Multapplier
Dual Micro Multibin Assembly
Antenna
Antenna Base Assembly
Arm Rest
Virtual Terminal Installation
Camera Cables
Terminal Support
Armrest Adjust Mechanism, Right Hand
Cab Assembly, Terragator
Cab Glass
Glass
Cab Floor Mats And Covers
Cab Floormat Installation
Cab Support Installation, With Air Ride
Metric
Controls, Front
Dash Panel Assembly
Dome Housing Bracket Installation
Glass Hammer Assembly
Inner Roof Arrangement
Interior Trim Arrangement
Interior Trim
Limp Home Control Group
Mirror Installation-Cab
Mirror Mounting Group
Electric
Outer Roof
Pedal Installation
Inching
Audio Group
Radio Accessory Kit
Air
A2000 Passive Suspension Service Kit
Passive Seat Suspension Kit
Knobs Assembly Kit
Seat Assembly, Cloth, Heated, Air Suspension
Trainer Seat, Cloth
Trainer Seat, Leather
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Wiper Motor
Hvac Group
Auto Control
Air Conditioning High Pressure Switch Assembly
Air Dryer Box And Step Installation
Air Dryer Box Assembly
Battery Box Assembly
Boom Rest Installation, Wide Mount
Cabinet And Step Installation
Front
Mud Flap Installation
Rinse Tank Installation
Step Installation, Cab, Entrance
Step Assembly
Steps
Chassis Frame
Tag Axle
Fork Assembly
Frame Bolt Installation, Without Boom
Hood Installation
Hood Brace Support
Headlight Installation
Hood Cowling Assembly
Hood Panel, Front, Left Hand
Hood Panel, Front, Right Hand
Ppe Box Installation, Step
Storage Cabinet
Cab Decal Installation, Inside
Model
Left Side
Right Side
International
Decal Installation, 1800 Gallon
Decal Installation, 2400 Gallon
Decal Installation, Air Max Precision
Decal Installation, Air Max Precision 2
Air Max
Lift Eye Decal Installation , Airmax Precision
Eame
Decal Installation, Box
Decal Installation, Twin Bin
Decal Installation, Reflective, Dot
Edge Liner And Tread Installation
Lift Eye Decal Installation , 2 Bin 4 Bin
Decal Installation, Four Bin
L4500
Nl4500g4 Edge, 409ss, 14 Foot, #4 Belt Over Chain, Full Flare
Safety
Nl5000 G5
Decal Group, Safety Multapplier
Body
1wheels
Tire And Wheel, Front, 1050 50r32 Goodyear
Tire And Wheel, Front, 1050 50r32 Michelin
Trelleborg
Rim Assembly, 1050x50-32, Rear
1controller System
Vd03
Antenna Installation, Phoenix 300, Gps
Option
Without Gps, Viper 4, Raven, Ag
Controller Installation, Raven V4
Controller-Vd0x W Gyro 3g, Modem
Controller-Vd0x W Gyro Cdma, Modem
Control Installation, Raven, Viper 4
Weather Station
Flowmeter Installation, Raven, 3 Inch, Add On
Flowmeter Assembly-Raven, 3.00 Flange
3 Inch, 3x3
3 Inch, 4x4
Flowmeter Assembly, Raven, Magnetic, 3.00 Inch, Flanged
Flowmeter Plumbing Installation, Raven, 3.00 Inch
Sensor Installation, Norac, Boom
Roll Sensor Installation, Norac, Large Boom
Sensor Assembly, Center, Norac, Large Boom
Ultrasonic Sensor
Boom Sensor Arm Assembly
Valve Installation
Sensor Installation, Autoboom
Ultrasonic Sensor, Digital, Left Hand
Ultrasonic Sensor, Digital, Right Hand
Sensor Installation, Rate, Air Max 1
Sensor Installation, Rate, Air Max 2
15-16 Foot
Mount Assembly
Module
Encoder, Dickey-John 360, With 12 Inch Cable
Multapplier Multibin
Bin Level Sensor Assembly
Duel Spinner Speed
Hydraulic Tank
Master Module Group
Sensor
Rate Sensor Mount Installation, Dickey John
1precision Farming Systems
Camera Installation
Camera Installation, 9 Inch Monitor
Camera Kit, Agcam
Single
Nt01
Camera Ready System
9 Inch Display
Gateway Assembly
Gateway, Mid Spec, Gsm
Gateway, Mid Spec, Lte
Smart 6
Smart 7
Camera (Agcam)
Lightbar
Agcontrol
Cable Installation, Rgl 600, Agcontrol
Cable Installation, Rgl 600, Raven
Slingshot Installation, Verizon
Slingshot Installation, Ready, Raven
Slingshot Installation, 2.0, Verizon
Slingshot Installation, No Gps, Cab
Gps Ready Installation
Receiver
1product Containment
1800 2400 Liquid
Holddown Installation, 3 Wheel, Liquid System
Holddown Installation, 4 Wheel, Liquid System
License Plate Bracket Installation
1800 2400 Gallon
Tank Assembly, 1800 Gallon
Tank Assembly, 2400 Gallon
Butterfly Valve Assembly, 2.00, Electrical, 7 Section
Top Tank Assembly, 135 Gallon
Air Max Precision, Tgc
Installation Arrangement, Air Max Precision 1
V-Hood Installation, Air Max 1000
Conveyor Cover
Amp1
Bypass Valve
Hydraulic Motor, 9.9 Cid
Installation Arrangement, Air Max Precision 2
Flip Panel Installation
V-Hood Installation, Air Max 2000
Amp2
Bumper Installation, Rear
Dual Bin Divider Installation
Riser
No Granular Bin
Fender Installation, Air Max
Airmax 1000 2000
Ladder Installation, Rear
Granular Metering Housing Installation
Hardware Group, Granular
Lift Eye Installtion, Airmax Precision
Hardware Group, No Lift Eye
Housing Installation-Metering, Granular
Spacer Installation, 2.25 Wheel
No Spraymax Option
Bulkhead Cover Installation, Front
Screen Installation, Front, Without Tank
Auxiliary
Unloading Chute Installation
Window Installation, Hopper
Twin Bin 4 Bin
Box Assembly, Twin Bin
Cage Assembly
Conveyor Assembly
Cover Assembly, Rear Bulkhead
V-Hood Assembly
Ladder To Distributor
Ladder Lower, Rear
Lift Eye Installation , Soilection
Lube System Installation, Twin Bin
Metering Mechanism Installation, Chain, Twin Bin
Metering Chain Installation
Mud Guard Assembly
Riser Installation, 4.00 Inch, With Granular, Twin Bin
Riser Installation, 4.00 Inch, Without Granular, Twin Bin
Riser Installation, 8.00 Inch, With Granular, Twin Bin
Bolt Installation-Dummy, Twin Bin, 8.00
Riser Installation, 8.00 Inch, Without Granular, Twin Bin
Sleeper Installation
Box Assembly, 4 Bin
Metering Mechanism Installation, Chain, 4 Bin
Riser Installation, 8.00 Inch, Soil, With Granular
Riser Installation, 8.00 Inch, Soil, Without Granular
Nl4500g4 Edge
Multapplier Ready
Full Flare
Nl4500g4 Edge, Multapplier, 14 5 Foot
Endgate Hardware Kit
Feedgate, Front
Foot Mount Group
Multapplier, 5 Foot
Multapplier Wiper
Nl4500g4 Edge, Multapplier, 14 7 Foot
Conveyor Assembly, #4 Belt Over Chain, 75 Links
Multapplier, 7 Foot
Edge
Dual Bin Panel Group
Dual Bottom Micro Group, 360 Encoder
Bed Sheet Installation, New Leader
Conveyor And Shield Assembly, 409ss, 14 Foot, #3
Conveyor And Shield Assembly, 409ss, 14 Foot, #4
Conveyor And Shield Assembly, 409ss, 15 Foot, #3
Conveyor And Shield Assembly, 409ss, 15 Foot, #4
Deflector Group
14-16 Foot 132 Inch, 304ss
14-16 Foot 132 Inch, Full Flare
14-16 Foot 132 Inch
Drive Idler Group
Idler Shaft Assembly, 30 Inch Conveyor
