Hyundai
86
176,834
Terex Finlay Mobile Screen 693+ Parts Manual
Brand: Terex Finlay
Type of Machine: Mobile Screen
Model: Terex Finlay 693+ Mobile Screen
Publication Date: 2017
Number of Pages: 483 Pages
693+
Table of Content​
02-01 CHASSIS MAIN​
02-02 FUEL TANK COVER​
02-03 JACK UP FOR SCREENBOX​
02-04 RIGHT SIDE VALVE ON CHASSIS (UPTO SERIAL NO. TRX00693CDGG32066)​
02-04 WALVOIL RIGHT SIDE VALVE ON CHASSIS (FROM SERIAL NO. TRX00693CDGG32067)​
02-05 LEFT SIDE VALVE ON CHASSIS (UPTO SERIAL NO. TRX00693CDGG32066)​
02-05 WALVOIL LEFT SIDE VALVE ON CHASSIS (FROM SERIAL NO.TRX00693CDGG32067)​
02-06 DUAL OVERCENTRE VALVE​
02-07 CHASSIS STEPS TO WALKWAY​
02-08 TRACK SUB FRAME​
03-01 STRICKLAND TRACKS​
03-01 STRICKLAND TRACKS (FROM SERIAL NO. TRX00693KDGF60753)​
04-01-A TIPPING GRID OVERVIEW​
04-01-B TIPPING GRID BREAKDOWN 1​
04-01-C TIPPING GRID BREAKDOWN 2​
04-01-D TIPPING GRID BREAKDOWN 3​
04-02-A SINGLE DECK VIBRATING GRID OVERVIEW (OPTION)​
04-02-B SINGLE DECK VIBRATING GRID (OPTION)​
04-02-C SINGLE DECK VIBRATING GRID SHAFT COMPONENTS 1 (OPTION)​
04-02-D SINGLE DECK VIBRATING GRID SHAFT COMPONENTS 2 (OPTION)​
04-02-E SINGLE DECK WEIGHT 1 (OPTION)​
04-02-F SINGLE DECK BEARING (OPTION)​
04-02-G SINGLE DECK WEIGHT 2 (OPTION)​
04-02-H VIBRATING GRID LIFT RAMS (OPTION)​
04-02-I SINGLE DECK VIBRATING GRID SUBFRAME (OPTION)​
04-02-J DOUBLE DECK VIBRATING GRID OVERVIEW (OPTION)​
04-02-K DOUBLE DECK VIBRATING GRID (OPTION)​
04-02-L DOUBLE DECK VIBRATING GRID SHAFT COMPONENTS 2 (OPTION)​
04-02-N DOUBLE DECK WEIGHT 1 (OPTION)​
04-02-O DOUBLE DECK WEIGHT 2 (OPTION)​
04-02-P DOUBLE DECK VIBRATING GRID SUBFRAME (OPTION)​
04-03-A BELT FEEDER MAIN UNIT​
04-03-B FEEDER UNIT HOPPER & WEARPLATES​
04-03-C ROSTA SCRAPER​
04-03-D HOPPER JACKING LEGS​
04-03-E MOUNTING AREA ELECTRICAL COMPONENTS​
04-04-A BELTFEEDER CASSETTE​
04-04-B BELT FEEDER CONVEYOR GUARDS​
04-04-C BELT FEEDER CONVEYOR BOTTOM SECTION​
04-04-D BELT FEEDER CONVEYOR MIDDLE SECTION​
04-04-E BELT FEEDER CONVEYOR TOP DRIVE SECTION​
04-04-F BELT FEEDER CONVEYOR MOTOR, FITTINGS AND HOSES​
00 ENGINE CONSUMABLE PARTS​
01 TIER 3 PERKINS CONSTANT SPEED POWERUNIT​
05-08-B SINGLE & DOUBLE BATTERY ARRANGEMENT​
05-18-B TIER 3 PERKINS 1104 97KW CONSTANT SPEED FILTERS​
02 TIER 4I CAT 4.4 POWERUNIT​
05-08 TIER 4I POWER UNIT CANOPY LAYOUT​
05-08-A TIER 4I POWER UNIT ROOF​
05-08-D.1 TIER 4I POWERUNIT FRONT DOOR RHS​
05-08-D.2 TIER 4I POWERUNIT FRONT DOOR POST​
05-08-D.3 TIER 4I POWERUNIT FRONT DOOR LHS​
05-08-F TIER 4I POWER UNIT CANOPY MAIN FRAME​
05-08-H TIER 4I POWERUNIT LHS DOOR​
05-09-A TIER 4I CAT 4.4 ENGINE FILTER COMPONENTS​
05-09-B TIER 4I CAT 4.4 ENGINE EXHAUST​
05-09-F TIER 4I CAT 4.4 DONALDSON AIR FILTER BREAKDOWN​
03 TIER 4 FINAL CAT 4.4 POWERUNIT​
05-20 TIER 4 FINAL CAT 4.4 POWERUNIT​
05-21 TIER 4 FINAL CAT 4.4 POWERUNIT ROOF ASM​
05-22 TIER 4 FINAL CAT 4.4 POWERUNIT RHS​
05-23 TIER 4 FINAL CAT 4.4 POWERUNIT BASE​
05-24 TIER 4 FINAL CAT 4.4 POWERUNIT LHS​
05-25 TIER 4 FINAL CAT 4.4 ENGINE ASM​
05-26 TIER 4 FINAL CAT 4.4 POWERUNIT VALVE BLOCK LAYOUT​
05-27 TIER 4 FINAL CAT 4.4 POWERUNIT AIR INLET DOOR ASM​
05-28 TIER 4 FINAL CAT 4.4 POWERUNIT FRONT DOOR POST​
05-29 TIER 4 FINAL CAT 4.4 POWERUNIT RHS FRONT DOOR​
05-30 TIER 4 FINAL UREA TANK​
05-31 TIER 4 FINAL PEU​
04 TIER 3 CAT 4.4 97KW LRC POWERUNIT​
05-40 TIER 3 CAT 4.4 97KW LRC POWERUNIT​
05-41 TIER 3 CAT 4.4 97KW LRC POWERUNIT ROOF​
05-42 TIER 3 CAT 4.4 97KW LRC POWERUNIT RHS​
05-43 TIER 3 CAT 4.4 97KW LRC POWERUNIT BASE​
05-44 TIER 3 CAT 4.4 97KW LRC POWERUNIT LHS​
05-45 TIER 3 CAT 4.4 97KW LRC ENGINE​
05 CAT 4.4 CONSTANT SPEED POWERUNIT​
05-60 CAT 4.4 CONSTANT SPEED POWERUNIT​
05-61 CAT 4.4 CONSTANT SPEED POWERUNIT ROOF​
05-62 CAT 4.4 CONSTANT SPEED POWERUNIT RHS​
05-63 CAT 4.4 CONSTANT SPEED POWERUNIT BASE​
05-64 CAT 4.4 CONSTANT SPEED POWERUNIT LHS​
05-65 CAT 4.4 CONSTANT SPEED ENGINE​
05-66 CAT 4.4 CONSTANT SPEED POWERUNIT VALVE BLOCK LAYOUT​
05-67 CAT 4.4 CONSTANT SPEED POWERUNIT AIR INLET DOOR​
05-68 CAT 4.4 CONSTANT SPEED POWERUNIT FRONT DOOR POST​
05-69 CAT 4.4 CONSTANT SPEED POWERUNIT RHS FRONT DOOR​
10 ELECTRICAL AND DUAL POWER POWERUNIT​
05-11-C ELECTRIC MOTOR GUARD FOR DUAL POWER​
05-11-D ELECTRICAL OPTION TRIPLE PUMP​
05-11-A CONTROL PANEL FOR ELECTRICL DUAL POWER (OPTION)​
05-11-B ELECTRIC MOTORS FOR DUAL POWER​
05-11-E BALLVALVE FOR ELECTRICAL AND DUAL POWER (OPTION)​
06-01-A HYDRAULIC TANK MAIN​
06-01-A.1 TIPPING GRID SOLENOID​
06-01-A.2 VIBRATING GRID SOLENOID​
06-01-A.3 TRACK SOLENOIDS​
06-01-A.4 HYDRAULIC RETURN MANIFOLD​
07-01 FUEL TANK​
07-01B FUEL TANK (OPTION)​
09-01 SCREENBOX MAIN PART 1​
09-02 SCREENBOX MAIN PART 2​
09-03 SCREENBOX TOP DECK MESH FRAME​
09-04 TOP DECK CHUTE​
09-05-A SCREENBOX BOTTOM DECK MESH FRAME​
09-06 SCREENBOX TOP DECK FEEDBOX & WEARPLATE​
09-07-A TENSION BAR ARRANGEMENT​
09-07-B MID TENSIONING BAR​
09-08 HYDRAULIC RAM ARRANGEMENT 1​
09-09 HYDRAULIC RAM ARRANGEMENT 2​
09-10 SPRING​
09-11 SCREENBOX SHAFT DRIVE SIDE​
09-12 SCREENBOX SHAFT HYDRAULIC DRIVE MOTOR​
09-13 SCREENBOX SHAFT NONE DRIVE SIDE​
09-14 SCREEN SHAFT DRIVE SIDE BEARING​
09-15 SCREEN WEIGHT BREAKDOWN​
09-16 SCREEN BEARING NON-DIVE SIDE​
09-17 SCREENBOX RUBBER​
09-15-A SPALECK SCREEN MAIN​
09-15-B SPALECK SCREEN SHAFT​
09-15-C SPALECK SCREEN DECK​
09-15-D SPALECK CHUTES​
MAIN CONVEYOR​
10-01-A MAIN CONVEYOR BOTTOM SECTION 1 MAIN​
10-01-B MAIN CONVEYOR FEED SECTION WEAR PLATES - 693+ FROM TRX00693CDGE58784, 694+ FROM TRX00694EDGE58744​
10-01-C ROLLER SET ON MAIN CONVEYOR BOTTOM SECT 1​
10-01-D MAIN CONVEYOR BOTTOM DRIVE​
10-01-E MAIN CONVEYOR 2ND SECTION HEAD DRIVE SECTION​
10-01-F HYDRAULIC MOTOR FOR MAIN CONVEYOR HEAD DRIVE SECTION​
10-01-G MAIN CONVEYOR 2ND SECTION MAIN​
10-01-I MAIN CONVEYOR HEAD SCRAPER​
10-01-J MAIN CONVEYOR NIP GUARD​
10-01-K ROLLER SET ON MAIN CONVEYOR TOP SECT 2​
10-01-L MAIN CONVEYOR 2ND SECTION DUST SUPRESSION (OPTION)​
10-01-M MAIN CONVEYOR ANTI-ROLLBACK​
10-01-N MAIN CONVEYOR 2ND SECTION RUBBER CURTAIN ASM​
LHS MIDDLE GRADE CONVEYOR​
10-02-A LHS MIDDLEGRADE CONVEYOR FEEDBOOT​
10-02-B LHS MIDDLEGRADE CONVEYOR FEEDBOOT HOPPER​
10-02-C LHS MIDDLEGRADE CONVEYOR PIVOT​
10-02-D LHS MIDDLEGRADE CONVEYOR MOUNT​
10-02-E LHS MIDDLEGRADE CONVEYOR BOTTOM DRIVE DRUM​
10-02-F LHS MIDDLEGRADE CONVEYOR HYDRAULIC JACK UP ARMS​
10-02-G LHS MIDDLEGRADE CONVEYOR TOP SECTION MAIN​
10-02-H LHS MIDDLEGRADE CONVEYOR BELT SLIDE​
10-02-I LHS MIDDLEGRADE CONVEYOR WITH BELT SLIDER AND ROLLER​
10-02-J LHS MIDDLEGRADE CONVEYOR ROLLER WITH BELT HOOP​
10-02-K LHS MIDDLEGRADE CONVEYOR ROLLER STANDARD​
10-02-L LHS MIDDLEGRADE CONVEYOR HEAD DRIVE SECTION​
10-02-M LHS MIDDLEGRADE HYDRAULIC MOTOR HOSSES AND FITTINGS​
RHS CONVEYOR​
10-03-A RHS OVERSIZE MINUS CONVEYOR FEEDBOOT​
10-03-B RHS OVERSIZE MINUS FEEDBOOT HOPPER​
10-03-C RHS OVERSIZE MINUS CONVEYOR PIVOT​
10-03-D RHS OVERSIZE MINUS CONVEYOR MOUNT​
10-03-E RHS OVERSIZE MINUS CONVEYOR BOTTOM DRIVE DRUM​
10-03-F RHS OVERSIZE MINUS CONVEYOR HYDRAULIC JACK UP ARMS​
10-03-G RHS OVERSIZE MINUS CONVEYOR TOP SECTION MAIN​
10-03-H RHS OVERSIZE MINUS CONVEYOR ROLLER QUANTITIES PER ROLLER SET​
10-03-I RHS OVERSIZE MINUS CONVEYOR HEAD DRIVE SECTION​
10-03-J RHS OVERSIZE MINUS HYDRAULIC MOTOR HOSSES AND FITTINGS​
FINES TAIL CONVEYOR​
10-04-A FINES TAIL CONVEYOR HEAD SECTION​
10-04-B HYDRAULIC MOTOR FOR FINES TAIL CONVEYOR HEAD DRIVE SECTION​
10-04-C FINES CONVEYOR PART 1​
10-04-D FINES CONVEYOR PART 2​
10-04-E FINES CONVEYOR BOTTOM DRIVE COMPONENTS​
10-04-F FINES CONVEYOR BACK PARTS​
10-04-G FINES CONVEYOR ROLLER BREAKDOWN​
11-01-A WALKWAY AND SCREEN SUB FRAME​
11-01-B WALKWAY LHS​
11-01-C WALKWAY RHS​
11-01-D WALKWAY FRONT PART & SCRENBOX SUBFRAME​
11-01-E RAM ASM ON SCREEN SUBFRAME​
11-02-A FLOW REGULATOR ON SCREEN SUBFRAME​
11-02-B CONTROL VALVE SCREENBOX SUBFRAME LHS (UPTO SERIAL NO. TRX00693CDGG32066)​
11-02-B 1-BANK WALVOIL CONTROL VALVE SCREENBOX SUBFRAME LHS (FROM SERIAL NO. TRX00693CDGG32067)​
11-02-C CONTROL VALVE SCREENBOX SUBFRAME RHS (UPTO SERIAL NO. TRX00693CDGG32066)​
11-02-C WALVOIL CONTROL VALVE SCREENBOX SUBFRAME RHS (FROM SERIAL NO. TRX00693CDGG32067)​
11-02-C 2-BANK WALVOIL CONTROL VALVE SCREENBOX SUBFRAME LHS (FROM SERIAL NO. TRX00693CDGG32067)​
11-03-A MAIN CONVEYOR TELESCOPIC JACK UP​
11-03-B MAIN CONVEYOR TELESCOPIC JACK UP HYDRAULIC RAM​
12-01-A ELECTRIC COMPONENTS​
05-10-A TIER 4I CAT 4.4 ELECTRICAL CONTROL PANEL INTERNALS​
12-02 CAT 4.4 ELECTRICAL CONTROL PANEL INTERNALS​
12-03 BATTERY ELETRICAL CABLES​
12-04 ELECTRICAL WIRING LOOM​
12-05 ELECTRICAL SENSOR LOOM​
12-06 E-STOP WIRING LOOM​
13-01 OIL COOLER​
13-02 TIER 4I VALVE BLOCK LAYOUT​
13-03 CONTROL VALVE 1​
13-04 CONTROL VALVE 1 (VRIBRATING GRID OPTION)​
13-05 VALVE 2 WITH PROXIMITY​
13-06 CONTROL VALVE 3​
13-07 CONTROL VALVE 4​
13-08 CONTROL VALVE 5​
13-09 BALL VALVE​
13-10 FLOW CONTROL 1​
13-11 FLOW CONTROL 2​
13-12 TIER 4I FINLAY SIDE PUMP​
13-13 TIER 4I CAT 4.4 ENGINE QUAD PUMP (OPTION)​
13-14 TIER 4I CAT 4.4 ENGINE TRIPLE PUMP (OPTION)​
13-15 COOLER DIVERTER VALVE​
Terex Finlay.pdf
Blank Page​
Blank Page
TTTTTTT.pdf
693+​
Table of Content​
02-01 CHASSIS MAIN​
07-01 FUEL TANK​
09-10 SPRING​
MAIN CONVEYOR​
RHS CONVEYOR​
13-01 OIL COOLER​
13-09 BALL VALVE​
