Terex Finlay Mobile Screen 693+ Illustrated Parts Catalog 2017
Brand: Terex Finlay
Type of Machine: Mobile Screen
Type of Manual: Illustrated Parts Catalog
Model: Terex Finlay 693+ Mobile Screen
Serial Number: TRX00693CDGE58784
Publication Date: 2017
Number of Pages: 483 Pages
02-01 Chassis Main
02-02 Fuel Tank Cover
02-03 Jack Up For Screenbox
02-04 Right Side Valve On Chassis (Upto Serial No. Trx00693cdgg32066)
02-04 Walvoil Right Side Valve On Chassis (From Serial No. Trx00693cdgg32067)
02-05 Left Side Valve On Chassis (Upto Serial No. Trx00693cdgg32066)
02-05 Walvoil Left Side Valve On Chassis (From Serial No.Trx00693cdgg32067)
02-06 Dual Overcentre Valve
02-07 Chassis Steps To Walkway
02-08 Track Sub Frame
03-01 Strickland Tracks
03-01 Strickland Tracks (From Serial No. Trx00693kdgf60753)
04-01-A Tipping Grid Overview
04-01-B Tipping Grid Breakdown 1
04-01-C Tipping Grid Breakdown 2
04-01-D Tipping Grid Breakdown 3
04-02-A Single Deck Vibrating Grid Overview (Option)
04-02-B Single Deck Vibrating Grid (Option)
04-02-C Single Deck Vibrating Grid Shaft Components 1 (Option)
04-02-D Single Deck Vibrating Grid Shaft Components 2 (Option)
04-02-E Single Deck Weight 1 (Option)
04-02-F Single Deck Bearing (Option)
04-02-G Single Deck Weight 2 (Option)
04-02-H Vibrating Grid Lift Rams (Option)
04-02-I Single Deck Vibrating Grid Subframe (Option)
04-02-J Double Deck Vibrating Grid Overview (Option)
04-02-K Double Deck Vibrating Grid (Option)
04-02-L Double Deck Vibrating Grid Shaft Components 2 (Option)
04-02-N Double Deck Weight 1 (Option)
04-02-O Double Deck Weight 2 (Option)
04-02-P Double Deck Vibrating Grid Subframe (Option)
04-03-A Belt Feeder Main Unit
04-03-B Feeder Unit Hopper & Wearplates
04-03-C Rosta Scraper
04-03-D Hopper Jacking Legs
04-03-E Mounting Area Electrical Components
04-04-A Beltfeeder Cassette
04-04-B Belt Feeder Conveyor Guards
04-04-C Belt Feeder Conveyor Bottom Section
04-04-D Belt Feeder Conveyor Middle Section
04-04-E Belt Feeder Conveyor Top Drive Section
04-04-F Belt Feeder Conveyor Motor, Fittings And Hoses
00 Engine Consumable Parts
01 Tier 3 Perkins Constant Speed Powerunit
05-08-B Single & Double Battery Arrangement
05-18-B Tier 3 Perkins 1104 97kw Constant Speed Filters
02 Tier 4i Cat 4.4 Powerunit
05-08 Tier 4i Power Unit Canopy Layout
05-08-A Tier 4i Power Unit Roof
05-08-D.1 Tier 4i Powerunit Front Door Rhs
05-08-D.2 Tier 4i Powerunit Front Door Post
05-08-D.3 Tier 4i Powerunit Front Door Lhs
05-08-F Tier 4i Power Unit Canopy Main Frame
05-08-H Tier 4i Powerunit Lhs Door
05-09-A Tier 4i Cat 4.4 Engine Filter Components
05-09-B Tier 4i Cat 4.4 Engine Exhaust
05-09-F Tier 4i Cat 4.4 Donaldson Air Filter Breakdown
03 Tier 4 Final Cat 4.4 Powerunit
05-20 Tier 4 Final Cat 4.4 Powerunit
05-21 Tier 4 Final Cat 4.4 Powerunit Roof Asm
05-22 Tier 4 Final Cat 4.4 Powerunit Rhs
05-23 Tier 4 Final Cat 4.4 Powerunit Base
05-24 Tier 4 Final Cat 4.4 Powerunit Lhs
05-25 Tier 4 Final Cat 4.4 Engine Asm
05-26 Tier 4 Final Cat 4.4 Powerunit Valve Block Layout
05-27 Tier 4 Final Cat 4.4 Powerunit Air Inlet Door Asm
05-28 Tier 4 Final Cat 4.4 Powerunit Front Door Post
05-29 Tier 4 Final Cat 4.4 Powerunit Rhs Front Door
05-30 Tier 4 Final Urea Tank
05-31 Tier 4 Final Peu
04 Tier 3 Cat 4.4 97kw Lrc Powerunit
05-40 Tier 3 Cat 4.4 97kw Lrc Powerunit
05-41 Tier 3 Cat 4.4 97kw Lrc Powerunit Roof
05-42 Tier 3 Cat 4.4 97kw Lrc Powerunit Rhs
05-43 Tier 3 Cat 4.4 97kw Lrc Powerunit Base
05-44 Tier 3 Cat 4.4 97kw Lrc Powerunit Lhs
05-45 Tier 3 Cat 4.4 97kw Lrc Engine
05 Cat 4.4 Constant Speed Powerunit
05-60 Cat 4.4 Constant Speed Powerunit
05-61 Cat 4.4 Constant Speed Powerunit Roof
05-62 Cat 4.4 Constant Speed Powerunit Rhs
05-63 Cat 4.4 Constant Speed Powerunit Base
05-64 Cat 4.4 Constant Speed Powerunit Lhs
05-65 Cat 4.4 Constant Speed Engine
05-66 Cat 4.4 Constant Speed Powerunit Valve Block Layout
05-67 Cat 4.4 Constant Speed Powerunit Air Inlet Door
05-68 Cat 4.4 Constant Speed Powerunit Front Door Post
05-69 Cat 4.4 Constant Speed Powerunit Rhs Front Door
10 Electrical And Dual Power Powerunit
05-11-C Electric Motor Guard For Dual Power
05-11-D Electrical Option Triple Pump
05-11-A Control Panel For Electricl Dual Power (Option)
05-11-B Electric Motors For Dual Power
05-11-E Ballvalve For Electrical And Dual Power (Option)
06-01-A Hydraulic Tank Main
06-01-A.1 Tipping Grid Solenoid
06-01-A.2 Vibrating Grid Solenoid
06-01-A.3 Track Solenoids
06-01-A.4 Hydraulic Return Manifold
07-01 Fuel Tank
07-01b Fuel Tank (Option)
09-01 Screenbox Main Part 1
09-02 Screenbox Main Part 2
09-03 Screenbox Top Deck Mesh Frame
09-04 Top Deck Chute
09-05-A Screenbox Bottom Deck Mesh Frame
09-06 Screenbox Top Deck Feedbox & Wearplate
09-07-A Tension Bar Arrangement
09-07-B Mid Tensioning Bar
09-08 Hydraulic Ram Arrangement 1
09-09 Hydraulic Ram Arrangement 2
09-10 Spring
09-11 Screenbox Shaft Drive Side
09-12 Screenbox Shaft Hydraulic Drive Motor
09-13 Screenbox Shaft None Drive Side
09-14 Screen Shaft Drive Side Bearing
09-15 Screen Weight Breakdown
09-16 Screen Bearing Non-Dive Side
09-17 Screenbox Rubber
09-15-A Spaleck Screen Main
09-15-B Spaleck Screen Shaft
09-15-C Spaleck Screen Deck
09-15-D Spaleck Chutes
Main Conveyor
10-01-A Main Conveyor Bottom Section 1 Main
10-01-B Main Conveyor Feed Section Wear Plates - 693+ From Trx00693cdge58784, 694+ From Trx00694edge58744
10-01-C Roller Set On Main Conveyor Bottom Sect 1
10-01-D Main Conveyor Bottom Drive
10-01-E Main Conveyor 2nd Section Head Drive Section
10-01-F Hydraulic Motor For Main Conveyor Head Drive Section
10-01-G Main Conveyor 2nd Section Main
10-01-I Main Conveyor Head Scraper
10-01-J Main Conveyor Nip Guard
10-01-K Roller Set On Main Conveyor Top Sect 2
10-01-L Main Conveyor 2nd Section Dust Supression (Option)
10-01-M Main Conveyor Anti-Rollback
10-01-N Main Conveyor 2nd Section Rubber Curtain Asm
Lhs Middle Grade Conveyor
10-02-A Lhs Middlegrade Conveyor Feedboot
10-02-B Lhs Middlegrade Conveyor Feedboot Hopper
10-02-C Lhs Middlegrade Conveyor Pivot
10-02-D Lhs Middlegrade Conveyor Mount
10-02-E Lhs Middlegrade Conveyor Bottom Drive Drum
10-02-F Lhs Middlegrade Conveyor Hydraulic Jack Up Arms
10-02-G Lhs Middlegrade Conveyor Top Section Main
10-02-H Lhs Middlegrade Conveyor Belt Slide
10-02-I Lhs Middlegrade Conveyor With Belt Slider And Roller
10-02-J Lhs Middlegrade Conveyor Roller With Belt Hoop
10-02-K Lhs Middlegrade Conveyor Roller Standard
10-02-L Lhs Middlegrade Conveyor Head Drive Section
10-02-M Lhs Middlegrade Hydraulic Motor Hosses And Fittings
Rhs Conveyor
10-03-A Rhs Oversize Minus Conveyor Feedboot
10-03-B Rhs Oversize Minus Feedboot Hopper
10-03-C Rhs Oversize Minus Conveyor Pivot
10-03-D Rhs Oversize Minus Conveyor Mount
10-03-E Rhs Oversize Minus Conveyor Bottom Drive Drum
10-03-F Rhs Oversize Minus Conveyor Hydraulic Jack Up Arms
10-03-G Rhs Oversize Minus Conveyor Top Section Main
10-03-H Rhs Oversize Minus Conveyor Roller Quantities Per Roller Set
10-03-I Rhs Oversize Minus Conveyor Head Drive Section
10-03-J Rhs Oversize Minus Hydraulic Motor Hosses And Fittings
Fines Tail Conveyor
10-04-A Fines Tail Conveyor Head Section
10-04-B Hydraulic Motor For Fines Tail Conveyor Head Drive Section
10-04-C Fines Conveyor Part 1
10-04-D Fines Conveyor Part 2
10-04-E Fines Conveyor Bottom Drive Components
10-04-F Fines Conveyor Back Parts
10-04-G Fines Conveyor Roller Breakdown
11-01-A Walkway And Screen Sub Frame
11-01-B Walkway Lhs
11-01-C Walkway Rhs
11-01-D Walkway Front Part & Screnbox Subframe
11-01-E Ram Asm On Screen Subframe
11-02-A Flow Regulator On Screen Subframe
11-02-B Control Valve Screenbox Subframe Lhs (Upto Serial No. Trx00693cdgg32066)
11-02-B 1-Bank Walvoil Control Valve Screenbox Subframe Lhs (From Serial No. Trx00693cdgg32067)
11-02-C Control Valve Screenbox Subframe Rhs (Upto Serial No. Trx00693cdgg32066)
11-02-C Walvoil Control Valve Screenbox Subframe Rhs (From Serial No. Trx00693cdgg32067)
11-02-C 2-Bank Walvoil Control Valve Screenbox Subframe Lhs (From Serial No. Trx00693cdgg32067)
11-03-A Main Conveyor Telescopic Jack Up
11-03-B Main Conveyor Telescopic Jack Up Hydraulic Ram
12-01-A Electric Components
05-10-A Tier 4i Cat 4.4 Electrical Control Panel Internals
12-02 Cat 4.4 Electrical Control Panel Internals
12-03 Battery Eletrical Cables
12-04 Electrical Wiring Loom
12-05 Electrical Sensor Loom
12-06 E-Stop Wiring Loom
13-01 Oil Cooler
13-02 Tier 4i Valve Block Layout
13-03 Control Valve 1
13-04 Control Valve 1 (Vribrating Grid Option)
13-05 Valve 2 With Proximity
13-06 Control Valve 3
13-07 Control Valve 4
13-08 Control Valve 5
13-09 Ball Valve
13-10 Flow Control 1
13-11 Flow Control 2
13-12 Tier 4i Finlay Side Pump
13-13 Tier 4i Cat 4.4 Engine Quad Pump (Option)
13-14 Tier 4i Cat 4.4 Engine Triple Pump (Option)
13-15 Cooler Diverter Valve
Brand: Terex Finlay
02-01 Chassis Main
07-01 Fuel Tank
09-10 Spring
Main Conveyor
Rhs Conveyor
Fines Tail Conveyor
11-01-B Walkway Lhs
11-01-C Walkway Rhs
13-01 Oil Cooler
13-09 Ball Valve
- Terex Schaeff HR 11,12,13,14,16,18 Parts Catalog
- Terex Backhoe Loader TX760,860,970,980 Workshop Manual
- Terex Schaeff HML 22,23,31,32,42 Parts Catalog
- Terex Schaeff Mini Excavator HR 1.5, 1.6, 2.0, 3.7 Parts Catalog
- Terex Schaeff HR 20 22 31 32 42 Parts Catalog
- Terex Finlay J-1175 tracked mobile jaw crusher operation manual
- TEREX SERVICE-MANUAL 09.2011
- TEREX Crawler excavator: Model TC75 / HR32 (Schematic)
- Terex Mini and Crawler Excavator TC15-TC125 Spare Part Catalog
- Terex TLB840 Backhoe Loader Service Manual
- Terex Lift TA-64 Electrical Schematic Wiring Diagram Parts Manual
- Terex Pegson 4242SR Operation Installation Parts Maintenance and Service Manual
- Terex TA30 Articulated Dumptruck Maintenance Manual
- Terex SKL 823,833,843,853,863,873 Parts Catalog
- Terex-Pegson Premiertrak 1100x650
