Terex Demag Crane AC130-5 AC160-5 AC220-5 AC250-5 Service Manual
Brand: Demag
Type of Manual: Service Manual, Pneumatic and Electric Hydraulic Diagrams
Model: Demag AC130-5 AC160-5 AC220-5 AC250-5 Crane
Number of Pages: 2574 Pages
AC 130-5 - AC 250-5
General Technical Data
Brand: Demag
AC 130-5 - AC 250-5
AC 130-5
Data sheet
Contents
Key
Dimensions
Specifications
Equipment
Counterweight
Main Boom
Main Boom Extension
Main Boom Extension variable
MS
Notes to lifting capacity
Technical description
AC 160-5
Data sheet
Contents
Key
Dimensions
Specifications
Equipment
Counterweight
Main Boom
Main Boom Extension
MS
Notes
AC 220-5
Data sheet
Contents
Key
Dimensions
Specifications
Equipment
Counterweight
Main Boom
Main Boom Extension
MS
Notes
AC 250-5
Data sheet
Contents
Key
Dimensions
Specifications
Equipment
Counterweight
Main Boom
Main Boom Extension
MS
Notes
CarrierDrive carrier
Assembly cooling system
Fuel system
Engine Scania DC13
Inspection Instructions
Trouble Shooting
SCR System
Transmission ZF AS- Tronic 12-Gear
Technical Data
Operating Instructions
Repair Manual
Installation Manual
Technical Manual
Steering
Mounting Steering
ME Overview
ME Electrics
EHLA Multi System Documentation
General System Description
Project specific Documentation
Commissioning
List of Alarm Codes
List of Diagnostic Trouble Codes
Safety Angle Transducer
Mounted on top
Mounted underneath
Hydraulic Carrier
AC 130-5
Diagram Carrier 60930012 from 35300
AC 160-5
Diagram Carier 60998012a from 38400
AC 250-5 and AC 220-5
Diagram carrier 60990012 from 82350
Components
Pressure setting main pump P1
Pressure settings P2, P3 and Delta P
Pneumatic
AC 160-5 and AC 130-5
Pneumatic control with and without 2-stage Transfer case 50822512
Brake lines diagram with ABS, with and without Hill holder 50827012
Brake lines diagram without ABS 50773012
Holding brake axle 1 without ABS
Holding brake axle 1 with ABS
Pneum. control without Transfer case neutral valve 50774612
Brake lines diagram with ABS and Hill holder 56989012
Brake lines diagram with ABS and without Hill holder 50824212
Brake lines dagram without ABS 50773012
Electrics Carrier
E-Diagram Carrier 61800012b
E-Diagram Carrier 61800012c
Colour description chart
Location mark
Harness drawings and Wiring list
Central electric
Harness Battery wiring
Harness Cabin
Harness Steering
Harness left
Harness right
Harness middle
Harness engine and gear box
Harness door left
Harness door right
Overview Electr. Interfaces
X 0401
X 4468A
X 4468B
X 4468C
X 4468
X 4257
X 0805
X 0804A
X 0804B
X 4867
X 3717
Control System Carrier
Control Concept Carrier
Actia SPU 70-66
Datasheet SPU 70-66
Actia APU 8-13
Datasheet APU 8-13
Status LED SPU and APU
Actia Multic II
Immobilizer
Outrigger control box
Firmware update Multic II
Multic Masks
Errorlist
Heater
Schema and tubing water circuit
Easy Start R+ Operating instructions
D 10WM Technical desctiption
D 10WM Troubleshooting
Cabin Carrier
SuperstructureMain Boom
AC 130-5
Main Boom
SVE kpl
SVE states
Reeving schematic
AC 160-5
Main Boom
SVE kpl
SVE states
Reeving schematic
AC 220-5
Main Boom
SVE kpl
SVE states
Reeving schematic
AC 250-5
Main Boom
SVE kpl
SVE states
Reeving schematic
SVE Overview
SVE states CAD 3D
1-unlocked and pinned
2-locked and pinned
3-locked and unpinned
Manual Telescoping
Pinning positions
Pinning pin
Hydraulics Superstructure
AC 130-5
H-Diagram Superstructure 60969912 from 35300
H-Diagram Superstructure 60960012c
AC 160-5
H-Diagram Superstructure 60960012 from 38400
H-Diagram Superstructure 60960012e
H-Diagram Superstructure 60960012 from 82350
Overview components
Slewing
Description Slew unit
Pressure settings
CWT detection values
Calibrate pressure transducer luffing
Electrics Superstructure
E-Diagram Superstructure 60530012c
E-Diagram Superstructure 60530012d
Location mark
Harness drawings and wiring list
Central electric
Harness Cabin I
Harness Cabin II
Harness Hydraulic unit
Harness Cabin door
Switchbox Main boom head
X2_SUB-D
X1_SUB-D
X 900
WCAN_Service
Control System Superstructure
Control Concept Superstructure
Actia SPU 70-66
Datasheet SPU 70-66
Actia APU 8-13
Datasheet APU 8-13
Service Interface Superstructure
Motec Camera System
CAN Cockpit
Product manual
Installation Instructions
Software descriptions
System Components, Spare Parts
Errorlist
Software update
Overview crane options
Heater
Schema Water circuit
Tubing Water circuit
Easy Start T Operating instructions
Hydronic 2C Technical description
Hydronic 2C Troubleshooting
Equipment
HAV
Rigging Mechanical HAV
Drawings
AC 130-5, AC 160-5, AC 250-5Drawings AC 220-5
Cabin Superstructure
- Terex Demag CC2800-1 Crawler Crane Operation Manual
- Terex Crane AC40-2 AC40-2L Wiring Diagram
- Terex Cranes RT300-1 Electrical Schematic
- Terex PPM AC35 Transmission Service Manual for Crane
- Terex Demag AC 50-1 Operation and Maintenance Manual
- Terex Crane TC60, TC60L, AC60, 60 Ton_ Workshop Manual CD
- Terex Rough Terrain Crane A600 Workshop Manual
- Terex Demag AC 200-1 Operation and Maintenance Manual
- Terex Crane RT230-1 Electrical and Hydraulic Schematic
- Terex AC55-1,AC55L Electric Schematic
- Terex Crane AC200-1 Global Training
- Terex Demag AC 140 Operation and Maintenance Manual
- Terex ATT400/3L-AC35L Electric Schematic
- Terex Demag PAT-modular PDC 1.4a Service Manual
- Terex PPM AC35 Transmission Service Training
