Hyundai
86
176,834
Terex Crane RT700 RT700-1 Parts Catalog 12261-264
Brand: Terex
Model: Terex RT700 TIER 3 EXPORT, RT700-1 TIER 4i Crane
Part Number: 12261-264
Publication Date: 2012
Number of Pages: 326 Pages
6A ENGINE INSTALLATION
6A.1) Engine Installation (Tier 4i)​
6A.6) Engine SubASSY (Tier 4i)​
6A.7) Cooling Package​
(Tier 4i & Non-North America)​
6B ENGINE INSTALLATION​
6B.1) Engine Installation (Non-North America)​
6B.4) Exhaust ASSY (Non-North America)​
6B.5) Engine ASSY (Non-North America)​
7 TRANSMISSION
7.1) Transmission (Dana)​
(Tier 3, 4i & Non-North America)​
7.2) Transmission Converter Group​
7.4) Transmission Converter & Transmission​
Case (Tier 3, 4i & Non-North America)​
7.6) Transmission R, 3rd, F & 2nd Clutch Group​
7.8) Transmission Low 1st Clutch Group​
7.10) Transmission Pressure Valve, Pump & Oil​
Filter (Tier 3, 4i & Non-North America)​
7.12) Transmission Control Valve Assembly​
7.13) Transmission Hi & Low Shift Control​
Assembly (Tier 3, 4i & Non-North America)​
7.14) Transmission Pump Adapter​
7.15) Transmission Pump Disconnect​
7.16) Transmission Drive Plate Group​
9 DRIVE SHAFTS
9.1) Drive Shafts (Tier 3 & 4i)​
10 BRAKES
10.1) Brake Line System (Tier 3)​
10.3) Brake Line System (Tier 4i)​
10.6) Air Supply System (Tier 3)​
10.8) Air Supply System (Tier 4i)​
10.11) Air Brake Kit (Tier 3 & 4i)​
11 STEERING
11.1) Steering System (Tier 3)​
11.2) Steering System (Tier 4i)​
11.3) Steering Control Unit (Tier 3 & 4i)​
11.4) Steering Cylinder (Tier 3 & 4i)​
11.5) Steering Type Selector Valve Hyd (Tier 3)​
11.6) Steering Type Selector Valve Hyd (Tier 4i)​
11.7) Steering Valve (Tier 3 & 4i)​
2 CARRIER FRAME, FUEL TANK
2.1) Frame, Fenders & Deck (Tier 3)​
2.2) Decks & Fenders ASSY (Tier 4i)​
2.5) Frame (Tier 3)​
2.6) Frame (Tier 4i)​
2.7) Rear Axle Assembly (Tier 3 & 4i)​
2.9) Front Axle Assembly (Tier 3 & 4i)​
2.12) Fuel Tank (Tier 3)​
2.13) Fuel Tank (Tier 4i)​
2.14) Axle Lock-Out Assembly (Tier 3)​
2.15) Axle Lock-Out Assembly (Tier 4i)​
2.17) Axle Lock-Out Cylinder (Tier 3 & 4i)​
2.18) Pintle Hook (Tier 3& 4i)​
2.19) Frame W/outriggers (Tier 3)​
2.21) Frame With Outriggers (Tier 4i)​
3 OUTRIGGERS
3.1) Outrigger Assembly (Tier 3 & 4i)​
3.2) Outrigger Jack Cylinder (Tier 3 & 4i)​
3.3) Outrigger Extend Cylinder (Tier 3 & 4i)​
3.4) Outrigger Front/Rear Valve Hydraulics​
(Tier 3)​
3.6) Outtrigger Ext/Ret Valve Hydraulics​
(Tier 3)​
3.8) Outrigger Front/Rear Valve Hydraulics​
(Tier 4i)​
3.9) Outrigger Ext/Ret Valve Hydraulics​
(Tier 4i)​
3.10) Outrigger Valve Selector (Tier 3 & 4i)​
3.11) Outrigger Pads (Tier 3 & 4i)​
3.12) Outrigger Sensor Installation (Tier 3)​
3.14) Sensor Mount Assy (Tier 3)​
5 CARRIER AXLES & WHEELS
5.1) Axle Options(Arvin Meritor) (Tier 3 & 4i)​
5.2) Axle, Front & Rear (Arvin Meritor)​
(Tier 4i)​
5.4) Brake Group (MOX-N5 Planetary​
Wheel End, Front & Rear​
(Arvin Meritor) (Tier 4i)​
5.6) Wheels & Tires ASSY (Tier 3 & 4i)​
6 CARRIER ENGINE
6.1) Engine Installation (Cummins) (Tier 3)​
6.2) Engine Installation (Cummins) (Tier 3)​
6.3) Engine Installation (Cummins) (Tier 3)​
6.5) Engine Installation (Cummins) (Tier 3)​
6.6) Engine Installation (Cummins) (Tier 3)​
6.7) Engine Cooling Package​
275 HP Export (Tier 3)​
30 MARKING
30.1) Marking Decals (Tier 3)​
30.4) Marking Decals (Tier 3)​
30.5) Marking Decals (Tier 4i)​
31) HEATER / AC​
31.1) A/C & Heater Options (Tier 3 & 4i)​
31.2) Hydraulic A/C & L.P Heater(Option 1)​
(Tier 3 & 4i)​
31.5) Hoses & Mounting Kit (Option 1)​
(Tier 3 & 4i)​
31.7) Hose ASSY. EVAP. COMP (Option 1)​
(Tier 3 & 4i)​
31.8) Hose ASSY. Drier to Evap. (Option 1)​
(Tier 3 & 4i)​
31.9) Hose ASSY - 6 Hyd Case Drain​
(Option 1) (Tier 3 & 4i)​
31.10) Kit, MD 9037/47/57 MTG​
31.11) Suburban Assembly Heater​
(Option 2) (Tier 3 & 4i)​
31.13) No Heater Includes Cover (Option 3)​
(Tier 3 & 4i)​
31.14) Deluxe A/C & Flameless Heat​
(Option 4) (Tier 3 & 4i)​
31.15) Kit, CAB ASSY​
31.16) Hydraulic Drive Unit​
31.19) Hose & Drive MTG KIT​
31.20) Thermostat Assembly (Tier 3 & 4i)​
33 ELECTRICAL SYSTEM
33.1) Dash Assembly (Tier 3)​
33.3) Dash Assembly (Tier 4i)​
33.5) Battery Assembly (Tier 3)​
33.6) Battery Assembly​
33.8) Battery Disconnect ASSY (Tier 3 & 4i)​
33.9) Collector Ring (Tier 3 & 4i)​
33.10) Circuit Breaker (Tier 3 & 4i)​
33.11) Electrical System, Lights & Relay​
Panel (Tier 3)​
33.14) Electrical ASSY​
33.17) Axle Centering Light Assembly​
(Tier 3)​
33.18) Optional Lights (Tier 3 & 4i)​
33.20) Optional Lights (Tier 3 & 4i)​
33.21) Fuses​
(Tier 3 & 4i & Non-North America)​
52 RATED CAPACITY INDICATOR (RCI 510)
52.1) Greer RCI 510 RCI Assembly ORPS​
(Tier 3 & 4i)​
52.4) Greer RCI 510 RCI Assembly​
52.7) Greer RCI 510 RCI Assembly​
52.9) Greer RCI 510 (Computer) (Tier 3 & 4i)​
52.10) Greer RCI 510 (Computer) (Tier 3 & 4i)​
52.11) Greer RCI 510 (Reel) (Tier 3 & 4i)​
54 FILTRES
54.1) Filters(Tier 3 & 4i)​
55 RECOMMENDED SPARE PARTS LIST
55.1) Recommended Spare Parts List​
(Tier 3)​
55.2) Recommended Spare Parts List​
(Tier 4i)​
56 OPTIONAL
56.1) 3RD Wrap Indicator (Tier 3 & 4i)​
56.2) Emergency Shutdown Kit (Tier 3 & 4i)​
56.3) Spark Arrestor Muffler (Tier 3 & 4i)​
12 SUPERSTRUCTURE
12.1) Superstructure (Tier 3)​
12.3) Windshield Support (Tier 3)​
12.4) Superstructure (Tier 4i)​
12.6) Windshield Support (Tier 4i)​
12.7) Swing Bearing (Tier 3 & 4i)​
12.8) Cab Mounts (Tier 3 & 4i)​
13 COUNTERWEIGHT
13.1) Counterweight (Tier 3 & 4i)​
22 SWING SYSTEM
22.1) Swing Drive, Braden (Tier 3)​
22.2) Swing Drive ASSY (Tier 4i)​
22.3) Swing Reduction Unit Braden (Tier 3)​
22.4) Swing Motor, Eaton (Tier 3)​
22.5) Swing Drive ASSY (Tier 4i)​
24 PUMP DRIVE CASE
24.1) Hydraulic Pumps (Tier 3)​
24.2) Hydraulic Pump (Winch) (Tier 3)​
24.3) Hydraulic Pump​
(Attachment & Swing) (Tier 3 & 4i)​
24.4) Hydraulic Pumps (Tier 4i)​
24.5) Hydraulic Pump (Winch ) (Tier 4i)​
24.6) Hydraulic Pumps (Non-North America)​
24.7) Hydraulic Pump (Winch)​
24.8) Hydraulic Pump (Attachment & Swings)​
25 HYDRAULIC SYSTEM
25.1) Lower Hydraulics ASSY (Tier 3)​
25.3) Lower Hydraulics, Outrigger Valves (Tier 3)​
25.5) Lower Hydraulics, Diverter Valve (Tier 3)​
25.6) Reservoir Hydraulic ASSY (Tier 3)​
25.7) Hydraulic Tank ASSY (Tier 3)​
25.8) Lower Hydraulics ASSY (Tier 4i)​
25.12) Lower Hydraulic, Outrigger Valve (Tier 4i)​
25.13) Lower Hydraulics, Diverter Valve (Tier 4i)​
25.14) Hydraulic Reservoir ASSY (Tier 4i)​
25.15) Upper Hydraulics (Tier 3 & 4i)​
25.22) Upper Hydraulics, Winch Valve (Tier 3 & 4i)​
25.24) Upper Hydraulics, Boom Valve (Tier 3 & 4i)​
25.26) Upper Hydraulics, Cab (Tier 3 & 4i)​
25.27) Upper Hydraulics, Priority Valve (Tier 3 & 4i)​
25.28) Upper Hydraulics, Swing Drive (Tier 3 & 4i)​
25.29) Upper Hydraulics, Swing Valve (Tier 3 & 4i)​
25.30) Upper Hydraulics, Hold Valve (Tier 3 & 4i)​
25.31) Upper Hydraulics, Relief Valve (Tier 3 & 4i)​
25.32) Upper Hydraulics, Pressure​
Reducer Valve (Tier 3 & 4i)​
33.22) Wire Harnesses (Tier 3)​
33.23) Wire Harnesses (Tier 4i)​
33.24) Work Light ASSY (Tier 3 & 4i)​
39 HYDRAULIC TELESCOPING BOOM
39.1) 126’ Boom (Tier 3 & 4i)​
39.8) 126’ Boom Extend Cylider​
(Tier 3 & 4i)​
39.9) 126’ Boom Hold Valve (Tier 3 & 4i)​
39.10) 126’ Boom Hoist Cylinder​
(Tier 3 & 4i)​
39.11) 126’ Boom Sheave (Tier 3 & 4i)​
39A JIBS​
39A.1) Offsettable Jib Assembly 33’-57’​
(Tier 3 & 4i)​
39A.2) Offsettable Jib Assembly (32’)​
(Tier 3 & 4i)​
39A.3) Jib Stowage Assembly (Tier 3 & 4i)​
39A.5) Anti-Two Block (Jib) (Tier 3 & 4i)​
40 HYDRAULIC WINCH
40.1) Tension Roller Assembly (Tier 3 & 4i)​
40.2) Winch Assembly (Tier 3 & 4i)​
40.4) Winch Motor (9 Piston Rexroth)​
(Tier 3 & 4i)​
44 HOOK BLOCKS, BALLS
44.1) Overhaul Ball, 419#/12 Ton/ 3/4”​
(Tier 3 & 4i)​
44.2) Hook Block, 5 Sheave / 75 Ton​
(Tier 3 & 4i)​
44.3) Hook Block, 5 Sheave / 75 Ton​
(Tier 3 & 4i)​
44.4) Hook Block 5SHV/ 80T (Tier 3 & 4i)​
44.5) Decal, Hook Block, 5 Sheave / 60Ton​
(Tier 3 & 4i)​
44.6) Hook Block, 5 Sheave, 60Ton 3/4 IN,​
1204LB (Tier 3 & 4i)​
45 WIRE ROPE, PENDANTS, REEVING
45.1) Wire Rope & Reeving (Tier 3 & 4i)​
50 ATTACHMENT OPTIONS
50.1) AUX Winch & AUX Sheave​
(Tier 3 & 4i)​
50.2) Auxiliary Boom Head Sheave​
(Tier 3 & 4i)​
50.3) Anti-Two (AUX Sheave) (Tier 3 & 4i)​
25.33) Swivel Assembly (Upper) (Tier 3)​
25.35) Swivel Assembly (Upper) (Tier 4i)​
25.37) Ceter Swivel Assembly (Lower)​
(Tier 3 & 4i)​
25.38) Rotary Manifold (Tier 3 & 4i)​
25.39) Upper Hydraulics, Extend Cylinder​
(Tier 3 & 4i)​
25.40) Remote Transmission Filter​
(Tier 3 & 4i)​
25.41) Frame Hydraulic Tubes (Tier 3 & 4i)​
27 OPERATOR’S CAB & MACHINERY HOUSING
27.1) Operator’s Cab Assembly (Tier 3)​
27.4) Operator’s Cab Assembly (Tier 4i)​
27.7) Operator’s Cab (Tier 3 & 4i)​
27.8) Operator’s Cab (Tier 3 & 4i)​
27.9) Operator’s Cab (Tier 3 & 4i)​
27.10) Operator’s Cab (Tier 3 & 4i)​
27.11) Operator’s Cab (Wipers) (Tier 3 & 4i)​
27.13) Operator’s Cab (Front Wind Shield)​
(Tier 3 & 4i)​
27.14) Operator’s Cab (Roof Hatch)​
(Tier 3 & 4i)​
27.15) Operators Cab (Door)​
(Tier 3 & 4i)​
27.16) Operators Cable Way ASSY (Tier 3)​
27.17) Operator’s Seat (Tier 3 & 4i)​
27.18) Engine Housing Installation (Tier 3)​
27.19) Engine Housing (Tier 3)​
27.20) Engine Housing Installation (Tier 4i)​
27.21) Engine Housing (Tier 4i)​
28 OPERATOR’S CONTROLS
28.1) Directional Signal Control​
(Tier 3 & 4i)​
28.2) Transmission Shifter​
Control ASSY (Tier 3 & 4i)​
28.3) Swing Brake Control (Tier 3 & 4i)​
28.5) Swing Lock Assembly (Tier 3 & 4i)​
28.6) Swing Lock Assembly (Tier 3 & 4i)​
28.7) Boom Angle Indicator (Tier 3 & 4i)​
28.8) Cab Throttle Control (Tier 3)​
28.10) Cab Throttle Control (Tier 4i)​
28.11) Arm Module Assemblies​
(Tier 3 & 4i)​
28.12) Arm Module Assemblies (Tier 3 & 4i)​
28.13) Arm Module Assemblies (Tier 3 & 4i)​
28.14) Arm Module Assemblies (Tier 3 & 4i)​
28.15) Arm Module Assemblies (Tier 3 & 4i)​
28.16) Boom Control (Tier 3 & 4i)​
28.17) Control Module (Tier 3 & 4i)​
SEE PAGE 25.22 FOR HOLD VALVE PLUMBING​
721 0023​
718 0584​
721 0028​
