Hyundai
86
176,684
Terex Cone Crusher C-1540 Parts Manual 2018
Brand: Terex
Type of Machine: Cone Crusher
Model: Terex C-1540 Cone Crusher
From Serial: TRX1540SLOMFC1559
Publication Date: 2018
Number of Pages: 619 Pages
C-1540 (FROM SERIAL NO. TRX1540SLOMFC1559 - DECEMBER 2015)
Table of Content​
01-01 CRUSHER OVERVIEW​
02-01 CHASSIS BREAKDOWN ASM​
02-02 CHASSIS ASM 1​
02-03 CHASSIS ASM 2​
02-04 LUBE TANK ASM 1​
02-05 LUBE TANK ASM 2​
03-01 TRACK ASM​
03-02 STRICKLAND TRACKS BREAKDOWN UPTO SERIAL NO.TRX1540SEOMH44206​
03-02 STRICKLAND TRACKS BREAKDOWN FROM SERIAL NO.TRX1540SEOMH44207​
04 HOPPER AND FEEDER ASM UPTO SERIAL NO. TRX1540SHOMH54331​
04-01 HOPPER AND FEED CONVEYOR OVERVIEW (VGF)​
04-02 HOPPER ASM​
04-10 FEED CONVEYOR ASM (VGF)​
04-11 FEED CONVEYOR LHS FRONT SKIRT SECTION​
04-12 FEED CONVEYOR RHS FRONT SKIRT SECTION​
04-13 FEED CONVEYOR IDLER ARRANGEMENT​
04-14 FEED CONVEYOR IDLER DRUM ASM​
04-15 FEED CONVEYOR MAIN COMPONENTS ASM​
04-16 FEED CONVEYOR ROLLERS MOUNTS AND BELT SLIDES ASM​
04-17 FEED CONVEYOR MAIN COMPONENTS ASM 1​
04-18 FEED CONVEYOR MAIN COMPONENTS ASM 2​
04-19 FEED CONVEYOR SCRAPER ASM​
04-20 FEED CONVEYOR TELESCOPIC FRAME ASM​
04-21 FEED CONVEYOR HEAD SECTION ASM​
04 HOPPER AND FEEDER ASM FROM SERIAL NO. TRX1540SHOMH54332​
04-30 HOPPER AND FEED CONVEYOR ASM​
04-31 HOPPER ASM OVERVIEW​
04-32 HOPPER COMPONENTS​
04-33 HOPPER RHS ASM​
04-34 HOPPER LHS ASM​
04-35 HOPPER REAR ASM​
04-40 FEED CONVEYOR ASM​
04-41 FEED CONVEYOR LHS FRONT SKIRT SECTION​
04-42 FEED CONVEYOR RHS FRONT SKIRT SECTION​
04-43 FEED CONVEYOR IDLER ARRANGEMENT​
04-44 FEED CONVEYOR IDLER DRUM ASM​
04-45 FEED CONVEYOR MAIN COMPONENTS ASM​
04-46 FEED CONVEYOR ROLLERS MOUNTS AND BELT SLIDES ASM​
04-47 FEED CONVEYOR MAIN COMPONENTS ASM 1​
04-48 FEED CONVEYOR MAIN COMPONENTS ASM 2​
04-49 FEED CONVEYOR SCRAPER ASM​
04-50 FEED CONVEYOR TELESCOPIC FRAME ASM​
04-51 FEED CONVEYOR HEAD SECTION ASM​
05 TIER 4 FINAL SCANIA DC09 POWERUNIT​
05-01 TIER 4 FINAL SCANIA DC09 POWERUNIT OVERVIEW​
05-02 TIER 4 SCANIA DC09 ENGINE AND CONSTANT SPEED ENGINE POWERUNIT SUBFRAME ASM​
05-03 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT OVERVIEW​
05-04 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT ROOF ASM​
05-05 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT EXHAUST GUARD ASM 1​
05-06 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT EXHAUST GUARD ASM 2​
05-07 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT FRONT ASM​
05-08 TIER 4 FINAL SCANIA DC09 ENGINE AND CONSTANT SPEED ENGINE COMPARTMENT BASE ASM UPTO SERIAL NO. TRX1540SLOMG82772​
05-08 TIER 4 FINAL SCANIA DC09 ENGINE AND CONSTANT SPEED ENGINE COMPARTMENT BASE ASM FROM SERIAL NO. TRX1540SLOMG82773​
05-09 TIER 4 SCANIA DC09 ENGINE AND CONSTANT SPEED ENGINE RHS PANEL ASM​
05-10 TIER 4 FINAL SCANIA DC09 ENGINE COMPARTMENT BACK ASM​
05-11 TIER 4 FINAL SCANIA DC09 ENGINE ASM​
05-12 TIER 4 FINAL SCANIA DC09 EXHAUST ASM​
05-13 TIER 4 FINAL SCANIA DC09 ENGINE AND CONSTANT SPEED ENGINE HYDRAULICS​
05-14 TIER 4 FINAL AND CONSTANT SPEED PT TECH CLUTCH ASM UPTO SERIAL NO. TRX1540SHOMI26344​
05-14 PT TECH CLUTCH ASM FROM SERIAL NO. TRX1540SHOMI26345​
05-15 OUTER DUAL SEAL KIT EXCLUDING END PLATE (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-15 OUTER DUAL SEAL KIT EXCLUDING END PLATE (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-15 OUTER DUAL SEAL KIT INCL END PLATE (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-16 FRICTION DISC KIT (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-16 FRICTION DISC KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-17 BEARING AND SEAL KIT (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-17 BEARING AND SEAL KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-18 END PLATE KIT (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-18 END PLATE KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-19 COMPLETE REBUILD KIT (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-19 COMPLETE REBUILD KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-20 SHAFT KIT (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-20 SHAFT KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-21 SEAL KIT - UNIVERSAL (PT TECH CLUTCH) UPTO SERIAL NO. TRX1540SHOMI26344​
05-21 SEAL KIT UNIVERSAL(PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-22 INNER SEAL KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05-23 PISTON SEAL KIT (PT TECH CLUTCH) FROM SERIAL NO. TRX1540SHOMI26345​
05 TIER 3 CAT C9 POWERUNIT​
05-30 TIER 3 CAT C9 POWERUNIT OVERVIEW​
05-31 TIER 3 CAT C9 ENGINE COMPARTMENT OVERVIEW​
05-32 TIER 3 CAT C9 ENGINE COMPARTMENT ROOF ASM​
05-33 TIER 3 CAT C9 ENGINE COMPARTMENT LHS AND RHS PANEL ASM​
05-34 TIER 3 CAT C9 ENGINE COMPARTMENT FRONT ASM​
05-35 TIER 3 CAT C9 ENGINE COMPARTMENT BASE ASM​
05-36 TIER 3 CAT C9 ENGINE COMPARTMENT BACK ASM​
05-37 TIER 3 CAT C9 ENGINE ENGINE ASM​
05-38 TIER 3 CAT C9 ENGINE AIR FILTER UPTO SERIAL NO. TRX1540STOMHC5797​
05-38 TIER 3 CAT C9 ENGINE AIR FILTER FROM SERIAL NO. TRX1540STOMHC5798​
05-40 TIER 3 CAT C9 PT TECH CLUTCH ASM UPTO SERIAL NO. TRX1540SHOMI26344​
05-40 PT TECH CLUTCH ASM FROM SERIAL NO. TRX1540SHOMI26345​
05-41 TIER 3 CAT C9 PULLY GUARD ASM​
05 SCANIA DC09 CONSTANT SPEED POWERUNIT​
05-60 SCANIA DC09 CONSTANT SPEED POWERUNIT OVERVIEW​
05-61 SCANIA DC09 CONSTANT SPEED ENGINE COMPARTMENT OVERVIEW​
05-62 SCANIA DC09 CONSTANT SPEED ENGINE COMPARTMENT ROOF ASM​
05-63 SCANIA DC09 CONSTANT SPEED ENGINE COMPARTMENT EXHAUST GUARD ASM​
05-64 SCANIA DC09 CONSTANT SPEED ENGINE COMPARTMENT FRONT ASM​
05-65 SCANIA DC09 CONSTANT SPEED ENGINE COMPARTMENT BACK ASM​
05-66 SCANIA DC09 CONSTANT SPEED ENGINE ASM​
05-67 SCANIA DC09 CONSTANT SPEED ENGINE EXHAUST AND AIR FILTER ARRANGEMENT​
06-01 HYDRAULIC TANK ASM 1​
06-02 HYDRAULIC TANK ASM 2​
07-01 FUEL TANK ASM​
08-01 CONE OVERVIEW​
08-02 CONE GENERAL ASM​
08-03 MAINFRAME ASM​
08-04 MAINFRAME ASM (SPARES)​
08-05 UPPER FRAME ASM​
08-06 CONE HEAD ASM​
08-07 ECCENTRIC ASM​
08-08 COUNTERSHAFT ASM​
08-09 CONE CONTROL BLOCK​
08-10 DUMPY JACK HOSE ASM​
08-11 CONE FEEDBOX ASM​
08-12 HYDRAULIC CYLINDER CIRCUIT​
10-01 MAIN CONVEYOR​
10-02 MAIN CONVEYOR TAIL SECTION ASM 1​
10-03 MAIN CONVEYOR TAIL SECTION ASM 2​
10-04 MAIN CONVEYOR IDLER DRUM AND BEARINGS ASM​
10-05 MAIN CONVEYOR MIDDLE SECTION ASM 1​
10-06 MAIN CONVEYOR MIDDLE SECTION ASM 2​
10-07 MAIN CONVEYOR HEAD SECTION ASM​
10-08 MAIN CONVEYOR SCS SCRAPER ASM​
10-09 MAIN CONVEYOR DUST COVER ASM​
10-10 MAIN CONVEYOR SPRAYBAR ASM​
10-11 MAIN CONVEYOR LEVEL SENSOR ASM​
10-12 MAIN CONVEYOR ROLLER ASM​
10-13 MAIN CONVEYOR DUST HOOD ASM​
11-01 CATWALK OVERVIEW​
11-02 RHS CATWALK ASM 1​
11-03 RHS CATWALK ASM 2​
11-04 RHS CATWALK LADDER ASM​
11-05 LHS CATWALK ASM 1​
11-06 LHS CATWALK ASM 2​
11-07 LHS CATWALK LADDER ASM​
11-08 FEEDER CATWALK ASM​
11-09 CENTRE CATWALK ASM​
12-01 ELECTRICAL COMPONENTS​
12-02 PANEL LAYOUT, INTERNAL/EXTERNAL​
12-03 PANEL CIRCUIT BREAKERS​
12-04 PANEL CONTACTORS​
12-05 PANEL PLC, NODE AND MISC​
12-06 FUSE BOX​
12-10 TIER 3 ENGINE HARNESS​
12-11 TIER 3 STARTER MOTOR CABLE​
12-12 TIER 4 ENGINE HARNESS​
12-13 TIER 4 STARTER MOTOR CABLE​
12-14 CLUTCH HARNESS​
12-15 TIER 4 UREA PUMP CABLE​
12-16 REAR RIGHT HARNESS​
12-17 REAR LEFT HARNESS​
12-18 CHASSIS KIT​
12-19 HYDRAULIC CABINET HARNESS​
12-20 CONE CONTROL CAB HARNESS​
12-21 BATTERY CABLE​
12-22 WATER PUMP HARNESS​
12-23 LED LIGHT TOWER ELECTRIC KIT​
12-24 METAL DETECTOR COMPONENTS​
13-01 CHASSIS HYDRAULICS​
13-01-01 CHASSIS SPRAY BAR ASM​
13-01-02 LUBE OIL COOLER ASM​
13-01-03 RETURN MANIFOLD ASM​
13-01-04A CONTROL VALVE, FITTINGS AND HOSES UPTO SERIAL NO. TRX1540SVOMG72692​
13-01-04B CONTROL VALVE, FITTINGS AND HOSES FROM SERIAL NO. TRX1540SVOMG72693 AND UPTO SERIAL NO. TRX1540SHOMH54331​
13-01-04C CONTROL VALVE, FITTINGS AND HOSES FROM SERIAL NO. TRX1540SHOMH54332​
13-01-05 SOLENOID VALVE, FITTINGS AND HOSES​
13-01-06 LUBE TANK MOTOR, FITTINGS AND HOSES​
13-01-07 LUBE TANK PUMP ASM, FITTINGS AND HOSES​
13-01-08 LUBE TANK SOLENOID VALVE AND PRESSURE RELIEF VALVE,FITTINGS AND HOSES​
13-01-09 RAM( 373 CLOSED- 160 STROKE), HOSES AND FITTINGS​
13-01-10 HOT CLIMATE LUBE OIL COOLER ASM​
13-01-11 BALL VALVE, FITTINGS AND HOSES FROM SERIAL NO. TRX1540SAOMI16153​
13-02 TRACK HYDRAULICS​
13-02-01 TRACK HYDRAULIC FITTINGS AND HOSES UPTO SERIAL NO.TRX1540SEOMH44206​
13-02-01 TRACK HYDRAULIC FITTINGS AND HOSES FROM SERIAL NO.TRX1540SEOMH44207​
13-03 HOPPER / FEEDER HYDRAULICS​
13-03-01 FEED CONVEYOR PUMP, FITTINGS AND HYDRAULIC HOSES UPTO SERIAL NO. TRX1540SHOMH54331, ECO19721​
13-03-01 FEED CONVEYOR PUMP, FITTINGS AND HYDRAULIC HOSES FROM SERIAL NO. TRX1540SHOMH54332, ECO19721​
13-03-02 FEEDER CONVEYOR SLIDER ARMS HYDRAULIC RAM AND FITTINGS UPTO SERIAL NO. TRX1540SHOMH54331, ECO19721​
13-03-02 FEEDER CONVEYOR SLIDER ARMS HYDRAULIC RAM AND FITTINGS FROM SERIAL NO. TRX1540SHOMH54332, ECO19721​
13-03-03 FEED CONVEYOR TELESCOPIC RAM, FITTINGS AND HYDRAULIC HOSES​
13-03-04 HOPPER RAM, FITTINGS AND HYDRAULIC HOSES FROM SERIAL NO. TRX1540SHOMH54332, ECO19721​
13-04 POWERUNIT HYDRAULICS​
13-04-01 SOLENOID VALVE ,FITTINGS AND HOSES​
13-04-02 WATERTRAP BREAKDOWN, FITTINGS AND HOSES​
13-04-03 MOTOR BREAKDOWN, FITTINGS AND HOSES​
13-04-04A CONTROL VALVE, FITTINGS AND HOSES UPTO SERIAL NO. TRX1540SVOMG72692​
13-04-04B CONTROL VALVE, FITTINGS AND HOSES FROM SERIAL NO. TRX1540SVOMG72693​
13-04-05 SUCTION MANIFOLD, FITTINGS AND HOSES​
13-04-06 PUMP ASM 1​
13-04-07 PUMP ASM 2​
13-04-08 PUMP ASM 3​
13-04-09 LUBE PRESSURE FILTER ASM FITTINGS AND HOSES​
13-04-10 PVG 1, FITTINGS AND HOSES​
13-04-11 PVG 2, FITTINGS AND HOSES​
13-04-12 PVG 1 BREAKDOWN​
13-04-13 PVG 2 BREAKDOWN​
13-04-14 PRESSURE FILTER, FITTINGS AND HOSES​
13-04-15 SUN PRESSURE REDUCING VALVE, FITTINGS AND HOSES​
13-04-16 PRV VALVE, FITTINGS AND HOSES​
13-04-17 OIL COOLER, FITTINGS AND HOSES​
13-04-18 PVG VALVE 1 BREAKDOWN​
13-04-19 PVG VALVE 2 BREAKDOWN​
13-04-20 SUCTION MANIFOLD, FITTINGS AND HOSES​
13-04-21 TIER 3 CAT C9 PUMP ASM 1​
13-04-22 TIER 3 CAT C9 PUMP ASM 2​
13-04-23 TIER 3 CAT C9 PUMP ASM 3​
13-05 HYDRAULIC TANK HYDRAULICS​
13-05-01 HYDRAULIC TANK, FITTINGS AND HOSES 1​
13-05-02 HYDRAULIC TANK, FITTINGS AND HOSES 1​
13-07 CONE HYDRAULICS​
13-07-01 CONE HYDRAULICS,FITTINGS AND HOSES​
13-07-02 CONE FEED CHUTE SPRAYBAR,FITTINGS AND HOSES​
13-09 CONVEYOR HYDRAULICS​
13-09-01 MAIN CONVEYOR MOTOR, FITTINGS AND HOSES​
14-01 TOP DRIVE GUARD ASM UPTO SERIAL NO. TRX1540SLOMG82772​
14-01 TOP DRIVE GUARD ASM FROM SERIAL NO. TRX1540SLOMG82773​
14-02 BOTTOM DRIVE GUARD ASM UPTO SERIAL NO. TRX1540SLOMG82772​
14-02 BOTTOM DRIVE GUARD ASM FROM SERIAL NO. TRX1540SLOMG82773​
14-03 CONTROL CABINET ASM 1​
14-04 CONTROL CABINET ASM 2​
14-06 WATER MANIFOLD ASM​
14-07 WATER PUMP, FITTINGS AND HOSESA​
14-08 HYDRAULIC CABINET ASM 1​
14-09 HYDRAULIC CABINET ASM 2​
14-10 UREA TANK OVERVIEW​
14-11 RETURN MANIFOLD ASM​
14-12 CONTAMINATION CHUTE ASM​
14-13 FEED CONVEYOR TELESCOPIC ASM​
14-14 TOP METAL DETECTOR ASM UPTO SERIAL NO. TRX1540SHOMH54331, ECO19721​
14-14 TOP METAL DETECTOR ASM FROM SERIAL NO. TRX1540SHOMH54332, ECO19721​
14-15 COOLER CABINET ASM​
14-16 UNDER CRUSHER FEEDBOOT ASM 1​
14-17 UNDER CRUSHER FEEDBOOT ASM 2​
14-18 TIER 4 SCANIA DC13 UREA TANK ASM​
15-01 REFUELING PUMP ASM​
15-02 STOCKPILER DRIVE BLOCK, FITTINGS AND HOSES​
15-03 LED LIGHT TOWER ASM​
