Terex Backhoe Loader TLB990 Tier 3 Interim Stage 3B Parts Catalog
Brand: Terex
Model: Terex TLB990 Tier 3 Interim Stage 3B Backhoe Loader
Publication Date: 2013
Number of Pages: 1354 Pages
Chassis - Sideshift 4 Wheel Steer
Chassis - Centremount 4 Wheel Steer
Bonnet - White
Bonnet - White
Bonnet - Yellow
Bonnet - Yellow
Bonnet - White
Bonnet - Yellow
Wheels & Tyres - Mitas - 24F 24R - White
Wheels & Tyres - Mitas - 24F 24R - Yellow
Wheels & Tyres - Continental - 24F 24R - White
Wheels & Tyres - Continental - 24F 24R - Yellow
Wheels & Tyres - Nokian - 24F 24R - White
Wheels & Tyres - Nokian - 24F 24R - Yellow
Wheels & Tyres - Goodyear - 24F 24R - Yellow
Front Axle
Steering System - Gear Pump
Steering System - Gear Pump - Hoses
Steering System - Piston Pump
Steering System - Piston Pump - Hoses
Hard Nose - White
Hard Nose - Yellow
Engine - 100HP
Fuel System - Fuel Tank
Fuel System - Fuel Pipes
Exhaust System
Exhaust System
Induction Air Cleaner
Cooling System - Radiator Assembly
Cooling System - Charge Air Tubes
Cooling System - With Air Con - Radiator Assembly
Cooling System - With Air Con - Charge Air Tubes
Torque Converter
Driveline Bolting
Driveline Bolting
Transmission - Servo Power Synchro - 4WS
Transmission - Servo Power Synchro - 4WS - Mechanical Park Brake
Transmission - Servo Power Synchro - 4WS - SAHR Park Brake
Consumables - White Paint
Consumables - Yellow Paint
Gearshift - Servo Powered Synchro - 4WS - 4 Speed
Gearshift - Servo Powered Synchro - 4WS - 3 Speed
Rear Axle - 4WS 26.43
Digger Valve - Sideshift - Mechanical - Standard Dipper - without Quick Attach
Digger Valve - Sideshift - Mechanical - Standard Dipper - with Quick Attach
Digger Valve - Sideshift - Mechanical - Extending Dipper - without Quick Attach
Digger Valve - Sideshift - Mechanical - Extending Dipper - with Quick Attach
Digger Valve - Sideshift - Servo - Standard Dipper - without Quick Attach
Digger Valve - Sideshift - Servo - Standard Dipper - with Quick Attach
Digger Valve - Centremount - Servo - Standard Dipper - without Quick Attach
Digger Valve - Centremount - Servo - Standard Dipper - with Quick Attach
Digger Valve - Sideshift - without Digger - Mechanical
Digger Valve - without Digger - Servo
Digger Valve - Sideshift - Servo - Extending Dipper - without Quick Attach
Digger Valve - Sideshift - Servo - Extending Dipper - with Quick Attach
Digger Valve - Centremount - Mechanical - Standard Dipper - without Quick Attach
Digger Valve - Centremount - Mechanical - Standard Dipper - with Quick Attach
Digger Valve - Centremount - Mechanical - Extending Dipper - without Quick Attach
Digger Valve - Centremount - Mechanical - Extending Dipper - with Quick Attach
Digger Valve - Centremount - Servo - Extending Dipper - without Quick Attach
Digger Valve - Centremount - Servo - Extending Dipper - with Quick Attach
Torque Converter Hydrauclics - Powershift Servo Synchro
Torque Converter Hydrauclics - Tank
Main Hydraulics - Piston Pump & Filter
Main Hydraulics - Gear Pump & Filter
Throttle Controls - Mechanical
Service Brakes - 4 Wheel Steer
Service Brakes - Brake Pedal Assembly
Handbrake - Overcentre
Handbrake - Solenoid Operated
Cab - Glazed Structure - Mounts
Cab - Door Assemblies
Cab - Side Windows
Cab - Rear Window
Cab - Front Windows
Cab - Structure
Cab - Roof Liner
Cab - Wipers
Cab - Electrics
Cab - without windscreen - Structure - Mounts
Canopy - without windscreen - Electrics
Canopy - with windscreen - Structure - Mounts
Canopy - with windscreen - Front Windows
Canopy - with windscreen - Electrics
Cab Trim - Front Console
Cab Trim - Side Console - Right Hand
Cab Trim - Side Console - Left Hand
Cab Trim - Floor Plate Seals
Canopy Trim - Front Console
Canopy Trim - Side Console - Right Hand
Canopy Trim - Side Console - Left Hand
Floormat - Cab - Mechnical Controls
Floormat - Cab - Servo Controls
Floormat - Canopy - Anti-slip
Heater - Cab - without Air Con
Heater - Cab - without Air Con - Air Ducts
Heater - Cab - with Air Con
Heater - Cab - with Air Con - Air Ducts
Heater - Cab - with Air Con - Compressor
Heater - HVAC Assy
Heater - Cab - With Air Con - Engine Bay Seals
Heater - Cab - Climate Control
Heater - Cab - Climate Control - Air Ducts
Heater - Cab - Climate Control - Compressor
Heater - Cab - Climate Control - Engine Bay Seals
Heater - Canopy - None
Electrics - Cab - Main Harness
Front Console - without Speedometer
Front Console - with Speedometer
Side Console - Centremount - Cab
Side Console - Sideshift - Cab
Side Console - Sideshift - Canopy
Side Console - Centremount - Canopy
Battery - Single
Battery - Dual
Rear Lights - Sideshift - 4 Work Lights
Rear Lights - Centremount - 4 Work Lights - Low Level
Rear Lights - Centremount - 4 Work Lights - High Level
Headlights - Left Hand Dip
Headlights - Right Hand Dip
Seat - PVC - Mechanical Suspension
Seat - Fabric - Mechanical Suspension
Seat - Fabric - Air Suspension - with Heater
Front Fenders
Ride Control - None
Ride Control - ISO
Ride Control - ANSI
Loader Beam - White
Loader Beam - White
Loader Beam - Links - White
Loader Beam - Return to Dig - White
Loader Beam - Yellow
Loader Beam - Links - Yellow
Loader Beam - Return to Dig - Yellow
Loader Beam - None
Loader Bucket - 1.2 cu M. Standard for Forks
Loader Bucket - 1.2 cu M. MP 7in1 for Forks
Loader Bucket - 1.2 cu M. MP 7in1 for Forks - Pipework
Loader Bucket - 1.2 cu M. MP 7in1 for Forks - Cylinder
Loader Bucket - Less Bucket
Loader Hydraulics - without Hose Burst - Standard Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - Standard Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - Standard Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - Standard Bucket - Lift Cylinder
Loader Hydraulics - without Hose Burst - MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - without Hose Burst - without MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - without Hose Burst - without MP 7in1 Bucket - Lift Cylinder
Loader Hydraulics - with Hose Burst - without MP 7in1 Bucket - Bucket Cylinder
Loader Hydraulics - with Hose Burst - without MP 7in1 Bucket - Lift Cylinder
Loader Controls - Electro - Hydraulic Clam - without Lock
Loader Controls - Electro - Hydraulic Clam - with Lock
Transport Lock - 15ft
Stabilisers - Centremount - White
Stabilisers - Centremount - Yellow
Stabilisers - None
Swing System - Sideshift - 15ft
Swing System - Centremount - 15ft
Swing System - None
Boom - Standard - 15ft - White
Boom - Standard - 15ft - Yellow
Boom - None
Dipper - Standard - 15ft - White
Dipper - Standard - 15ft - Yellow
Dipper - Extending - 15ft - White
Dipper - Outer - 15ft - White
Dipper - Inner - 15ft - White
Dipper - Extending - 15ft - Yellow
Dipper - Outer - 15ft - Yellow
Dipper - Inner - 15ft - Yellow
Dipper - None - 15ft
Digger Bucket Linkage - 15ft
Digger Bucket Linkage - None
Digger Bucket - Standard - 300mm
Digger Bucket - Standard - 450mm
Digger Bucket - Standard - 600mm
Digger Bucket - Standard - 750mm
Digger Bucket - Standard - 900mm
Digger Bucket - Heavy Duty - 300mm
Digger Bucket - Heavy Duty - 450mm
Digger Bucket - Heavy Duty - 600mm
Digger Bucket - Heavy Duty - 750mm
Digger Bucket - Heavy Duty - 900mm
Digger Bucket - Heavy Duty - 12 inch
Digger Bucket - Heavy Duty - 18 inch
Digger Bucket - Heavy Duty - 24 inch
Digger Bucket - Heavy Duty - 30 inch
Digger Bucket - Heavy Duty - 36 inch
Digger Bucket - Ditch - 1500mm
Digger Bucket - Ditch - 1800mm
Digger Bucket - Trapezoidal
Digger Bucket - None
Digger Bucket - None with Slave Link
Digger Hydraulics - None
Digger Hydraulics - Centremount - Standard Dipper - without Hose Burst - 15ft
Digger Hydraulics - Centremount - Extending Dipper - without Hose Burst - 15ft
Digger Hydraulics - Centremount - Standard Dipper - with Hose Burst - 15ft
Digger Hydraulics - Centremount - Extending Dipper - with Hose Burst - 15ft
Digger Hydraulics - Sideshift - Standard Dipper - 15ft - without Hose Burst
Digger Hydraulics - Sideshift - Extending Dipper - 15ft - without Hose Burst
Digger Hydraulics - Sideshift - Standard Dipper - 15ft - with Hose Burst
Digger Hydraulics - Sideshift - Extending Dipper - 15ft - with Hose Burst
Digger Controls - ISO or SAE
Digger Controls - X Pattern
Digger Controls - Servo
Digger Controls - SAE
Stab Controls - Sideshift
Stab Controls - Centremount
Pedal Box - Extending Dipper - Mechanical - without Auxilliary Hydraulics
Pedal Box - Extending Dipper - Mechanical - with Auxilliary Hydraulics
Pedal Box - Standard Dipper - Mechanical - with Auxilliary Hydraulics
Pedal Box - Standard Dipper - Mechanical - without Auxilliary Hydraulics
Pedal Box - Standard Dipper - Servo - without Auxilliary Hydraulics
Loader Valve - Mechanical Controls
Loader Valve - Servo Controls
Rear Fenders - 4 Wheel Steer - Sideshift
Rear Fenders - 4 Wheel Steer - Centremount
Stabiliser Hydraulics - Centremount - with Lock Out
Stabiliser Hydraulics - Sideshift - without Lock Out
Stabiliser Hydraulics - Sideshift - with Lock Out
Extender Hydraulics - Centremount
Extender Hydraulics - Sideshift
Extender Hydraulics - None - Servo
Auxilliary Hydraulics - None
Auxilliary Hydraulics - Centremount - Extending Dipper - 15ft
Auxilliary Hydraulics - Sideshift - Extending Dipper - 15ft
Auxilliary Hydraulics - Centremount - Standard Dipper - 15ft
Auxilliary Hydraulics - Sideshift - Standard Dipper - 15ft
Transport Lock Hydraulics - Centremount
Transport Lock Hydraulics - Sideshift
Transport Lock Hydraulics - None
Swing Hydraulics - Centremount
Swing Hydraulics - Sideshift
Swing Hydraulics - None
Tool Kit - Standard
Digger Quick Attach - Mechanical
Digger Quick Attach - Hydraulic
Digger Quick Attach - Hydraulics Only - No Unit
Digger Quick Attach - None
Digger Quick Attach Hydraulics - Centremount - Standard Dipper
Digger Quick Attach Hydraulics - Centremount - Extending Dipper
Digger Quick Attach Hydraulics - Sideshift - Standard Dipper
Digger Quick Attach Hydraulics - Sideshift - Extending Dipper
Machine Identity Decals - TLB990
Decals - Cab - English - ISO - CE - Instructions
Decals - Cab - English - ISO - CE - Warning
Decals - Cab - English - ISO - CE - Miscellaneous
Decals - Cab - French - ISO - CE - Instructions
Decals - Cab - French - ISO - CE - Warning
Decals - Cab - French - ISO - CE - Miscellaneous
Decals - Cab - German - ISO - CE - Instructions
Decals - Cab - German - ISO - CE - Warning
Decals - Cab - German - ISO - CE - Miscellaneous
Decals - Cab - Italian - ISO - CE - Instructions
Decals - Cab - Italian - ISO - CE - Warning
Decals - Cab - Italian - ISO - CE - Miscellaneous
Decals - Cab - Austrian - ISO - CE - Instructions
Decals - Cab - Austrian - ISO - CE - Warning
Decals - Cab - Austrian - ISO - CE - Miscellaneous
Decals - Cab - German - 4WS - ISO - CE - Instructions
Decals - Cab - German - 4WS - ISO - CE - Warning
Decals - Cab - German - 4WS - ISO - CE - Miscellaneous
Decals - Cab - English - ISO - Non CE - Instructions
Decals - Cab - English - ISO - Non CE - Warning
Decals - Cab - English - ISO - Non CE - Miscellaneous
Decals - Cab - German - 4WS - ISO - Non CE - Instructions
Decals - Cab - German - 4WS - ISO - Non CE - Warning
Decals - Cab - German - 4WS - ISO - Non CE - Miscellaneous
Decals - Cab - Costa Rica - ISO - Non CE - Instructions
Decals - Cab - Costa Rica - ISO - Non CE - Warning
Decals - Cab - Costa Rica - ISO - Non CE - Miscellaneous
Decals - Canopy - English - ISO - CE - Instructions
Decals - Canopy - English - ISO - CE - Warning
Decals - Canopy - English - ISO - CE - Miscellaneous
Decals - Canopy - English - ISO - Non CE - Instructions
Decals - Canopy - English - ISO - Non CE - Warning
Decals - Canopy - English - ISO - Non CE - Miscellaneous
Decals - Canopy - Costa Rica - ISO - Non CE - Instructions
Decals - Canopy - Costa Rica - ISO - Non CE - Warning
Decals - Canopy - Costa Rica - ISO - Non CE - Miscellaneous
Decals - Cab - English - ANSI - Non CE - Instructions
Decals - Cab - English - ANSI - Non CE - Warning
Decals - Cab - English - ANSI - Non CE - Miscellaneous
Decals - Canopy - English - ANSI - Non CE - Instructions
Decals - Canopy - English - ANSI - Non CE - Warning
Decals - Canopy - English - ANSI - Non CE - Miscellaneous
Forks - 1.0 Cubic Metre Loader Bucket
Forks - 1.2 Cubic Metre Loader Bucket
Loader Quick Attach - None
Tooth Guard - Multi-Purpose Bucket - Wide
Tooth Guard - Multi-Purpose Bucket - Narrow
Tooth Guard - Standard Bucket - Narrow
Tooth Guard - Standard Bucket - Wide
Licence Plate Holder - Rear
Wheel Wedge
Transport Chain - Digger
Transport Chain - Loader
Transport Side Plate - Loader Bucket
Fan Guard - Without Air Con
Fan Guard - With Air Con
Seat Belt - 3 inch
Transport Height Decal
Stabiliser Leg Lock Up - Sideshift
Reverse Alarm
Stabiliser Leg Warning - Centremount
Digger Bucket Pin Kit - Single
Digger Bucket Pin Kit - Double
Loader Bucket Tooth Kit - Standard
Loader Bucket Tooth Kit - Multi-Purpose
Blade - MP - Wide
Blade - MP - Narrow
Beacon - Twin
Beacon - Single
Toolkit - Service
Shipping Kit - 4WS
Oil - Biodegradeable Hydraulic
Loader Bucket Pin Kit
Spare Wheel - White
Spare Wheel - Yellow
Blade - Narrow - 3 Piece
Blade - Wide - 3 Piece
Street Pad - Sideshift
CESAR Datatag
Hose Burst - Loader - Bucket Cylinder
Hose Burst - Loader - Lift Cylinder
Digger Bucket Pin Kit - 3 Sets
Digger Bucket Pin Kit - 4 Sets
Guard Kit - Hydraulic Hoses
Manual Quick Coupler - Loader
High Tip Bucket - LC/HD
Pallet Fork - 1200mm
Sweeper Collector - 2500mm - Bucket
Sweeper Collector - 2500mm - Broom
Sweeper Collector - 2500mm - Decals
Dust Suppression Kit
Gutter Brush
Fork & Grapple
Spinnner Knob Kit - Steering Wheel
Fuel Strainer Kit
Bump Stop Kit - Hard Nose
Rear Worklamp Kit - 2 Lamps
Rear Worklamp Kit - 4 Lamps
Anti-Vandal Covers
Counterweight
Hose Burst - Digger - Sideshift - Mechanical
Hose Burst - Digger - Centremount - Servo
Hose Burst - Digger - Sideshift - Servo
Hose Burst - Digger - Centremount - Mechnical
Object Handling Kit - None
Brand: Terex
Bonnet - White
Bonnet - White
Bonnet - Yellow
Bonnet - Yellow
Bonnet - White
Bonnet - Yellow
Front Axle
Hard Nose - White
Hard Nose - Yellow
Engine - 100HP
Exhaust System
Exhaust System
Torque Converter
Driveline Bolting
Driveline Bolting
Cab - Side Windows
Cab - Rear Window
Cab - Front Windows
Cab - Structure
Cab - Roof Liner
Cab - Wipers
Cab - Electrics
Heater - HVAC Assy
Battery - Single
Battery - Dual
Front Fenders
Ride Control - None
Ride Control - ISO
Ride Control - ANSI
Loader Beam - White
Loader Beam - White
Loader Beam - None
Stabilisers - None
Swing System - None
Boom - None
Tool Kit - Standard
Wheel Wedge
Seat Belt - 3 inch
Reverse Alarm
Blade - MP - Wide
Blade - MP - Narrow
Beacon - Twin
Beacon - Single
Toolkit - Service
Shipping Kit - 4WS
Spare Wheel - White
CESAR Datatag
Gutter Brush
Fork & Grapple
Fuel Strainer Kit
Anti-Vandal Covers
Counterweight
- Terex Schaeff HR 11,12,13,14,16,18 Parts Catalog
- Terex Backhoe Loader TX760,860,970,980 Workshop Manual
- Terex Schaeff HML 22,23,31,32,42 Parts Catalog
- Terex Schaeff Mini Excavator HR 1.5, 1.6, 2.0, 3.7 Parts Catalog
- Terex Schaeff HR 20 22 31 32 42 Parts Catalog
- Terex Finlay J-1175 tracked mobile jaw crusher operation manual
- TEREX SERVICE-MANUAL 09.2011
- TEREX Crawler excavator: Model TC75 / HR32 (Schematic)
- Terex Mini and Crawler Excavator TC15-TC125 Spare Part Catalog
- Terex TLB840 Backhoe Loader Service Manual
- Terex Lift TA-64 Electrical Schematic Wiring Diagram Parts Manual
- Terex Pegson 4242SR Operation Installation Parts Maintenance and Service Manual
- Terex TA30 Articulated Dumptruck Maintenance Manual
- Terex SKL 823,833,843,853,863,873 Parts Catalog
- Terex-Pegson Premiertrak 1100x650
