Momed80
151
36,345
TCM UniCarriers Forklift Truck FHD20T5V to FHD35T5V Parts Catalog PM5UC-FHDAZD 2016
Brand: TCM UniCarriers
Type of Machine: Forklift Truck
Model: TCM UniCarriers FHD20T5V FHD25T5V FHD30T5V FHD35T5V Forklift Truck
Engine: Advanced Turbo ZD30
Part Number: PM5UC-FHDAZD
Publication Date: 2016
Number of Pages: 481 Pages
Cover
Edition Page
English Front Pages
General Index
Contents
Introduction
Group Symbols And Abbreviations
Model Identification
Classification Of Model
Chassis And Engine Serial Number
Table Of Chassis Numbers
Section Index
Las Portadas Españolas
Índice General
Contenido
Introducción
Grupo Símbolos Y Abreviaturas
Identificación Del Modelo
Modelo De Clasificación
Chasis Y Número De Serie Del Motor
Tabla De Números De Chasis
Índice Sección
Français Pages Avant
Index Général
Contenu
Introduction
Groupe Symboles Et Abréviations
Identification Du Modèle
Classification De Modèle
Châssis Et Le Numéro De Série Du Moteur
Tableau Des Numéros De Châssis
Index De Section
Engine Mechanical Sec. 100-150 & 296
Sec. 100 Engine Assembly (Zd30)
Sec. 110*1 Cylinder Block & Oil Pan (Zd30) Part 1
Sec. 110*2 Cylinder Block & Oil Pan (Zd30) Part 2
Sec. 111 Cylinder Head & Rocker Cover (Zd30)
Sec. 112 Engine & Mounting
Sec. 117 Fan, Compressor & Power Steering Belt (Zd30)
Sec. 120 Piston, Crankshaft & Flywheel (Zd30)
Sec. 130 Camshaft & Valve Mechanism (Zd30)
Sec. 135 Front Cover & Fitting (Zd30)
Sec. 140 Manifold (Zd30)
Sec. 144 Turbo Charger (Zd30)
Sec. 147 Egr Parts (Zd30)
Sec. 150 Lubricating System (Zd30)
Sec. 296 Controller
Fuel & Engine Control Sec. 163-186
Sec. 163 Throttle Body (Zd30)
Sec. 164 Fuel Strainer & Fuel Hose (Zd30)
Sec. 165a Air Cleaner (Zd30)
Sec. 165b Air Cleaner (Zd30 Dusx)
Sec. 173 Fuel Piping (Zd30)
Sec. 180 Accelerator Linkage
Sec. 185 Fuel Supply System (Zd30)
Sec. 186 Fuel Injection Pump (Zd30)
Exhaust & Cooling Sec. 200-216
Sec. 200a Exhaust Tube & Muffler (Zd30 Muf4, Muf6)
Sec. 200b Exhaust Tube & Muffler (Zd30 Muf5/Ohgl, Muf5/Ohgg)
Sec. 208 Catalyst Converter (Zd30)
Sec. 210 Water Pump, Cooling Fan & Thermostat (Zd30)
Sec. 211 Water Hose & Piping (Zd30)
Sec. 213 Oil Cooler (Zd30)
Sec. 214 Radiator, Shroud & Fitting
Sec. 216 Torque Converter Oil Cooler & Piping
Engine Electrical Sec. 220-233
Sec. 220 Ignition System (Zd30)
Sec. 226 Engine Control Module (Zd30)
Sec. 230 Alternator Fitting (Zd30)
Sec. 231a Alternator (Zd30)
Sec. 231b Alternator (Zd30 Dsta)
Sec. 233 Starter Motor (Zd30)
Body Electrical Sec. 240-267
Sec. 240 Wiring Engine Room & Instrument
Sec. 241 Wiring (Body)
Sec. 244 Battery & Battery Mounting
Sec. 248 Instrument Meter & Gauge
Sec. 251 Switch
Sec. 253 Electrical Unit
Sec. 260 Head Lamp
Sec. 261 Front Combination Lamp
Sec. 265 Rear Combination Lamp
Sec. 267 Lamps (Others)
Power Train Sec. 310-380
Sec. 310 Transmission Assembly & Fitting
Sec. 311 Torque Converter Case & Housing
Sec. 313 Oil Pump Parts
Sec. 314 Governor & Gear Parts
Sec. 315 Clutch & Brake Band
Sec. 317 Control Valve
Sec. 370 Propeller Shaft
Sec. 380 Final Drive Assembly
Axle & Suspension Sec. 402-434
Sec. 402a Drive Axle (20+25t)
Sec. 402b Drive Axle (30+35t)
Sec. 403 Steering Axle
Sec. 433a Road Wheel & Tire (Drive Axle) (20+25t Axl%)
Sec. 433b Road Wheel & Tire (Drive Axle) (30+35t Axl%)
Sec. 433c Road Wheel & Tire (Drive Axle) (20+25t Axlb)
Sec. 433d Road Wheel & Tire (Drive Axle) (30+35t Axlb)
Sec. 434a Road Wheel & Tire (Steering Axle) (20~30t)
Sec. 434b Road Wheel & Tire (Steering Axle) (35t)
Brake Sec. 440-470
Sec. 440 Front Brake
Sec. 443 Parking Brake Control
Sec. 460 Brake Master Cylinder
Sec. 462 Brake Piping & Control
Sec. 465 Brake & Clutch Pedal
Steering Sec. 480-497
Sec. 480 Steering Gear
Sec. 484 Steering Wheel
Sec. 485 Steering Linkage
Sec. 488 Steering Column
Sec. 497 Power Steering Piping
Body (Front, Roof & Floor) Sec. 500-740
Sec. 500a Frame (Instrument Fitting Parts)
Sec. 500b Frame (Frame Fitting Parts)
Sec. 580a Lift Cylinder (20+25t 2w)
Sec. 580b Lift Cylinder (30t 2w)
Sec. 580c Lift Cylinder (35t 2w)
Sec. 580d Lift Cylinder (20+25t 2f)
Sec. 580e Lift Cylinder (30t 2f)
Sec. 580f Lift Cylinder (35t 2f)
Sec. 580g Lift Cylinder (20+25t 3f)
Sec. 580h Lift Cylinder (30t 3f)
Sec. 580i Lift Cylinder (35t 3f)
Sec. 585a Chain Wheel Support & Chain (2w)
Sec. 585b Chain Wheel Support & Chain (2f)
Sec. 585c Chain Wheel Support & Chain (3f)
Sec. 586 Tilt Cylinder
Sec. 591a Mast (20~30t 2w)
Sec. 591b Mast (35t 2w)
Sec. 591c Mast (20~30t 2f)
Sec. 591d Mast (35t 2f)
Sec. 591e Mast (20~30t 3f)
Sec. 591f Mast (35t 3f)
Sec. 594 Back Rest & Fork
Sec. 595a Carriage (2w)
Sec. 595b Carriage (2f)
Sec. 595c Carriage (3f)
Sec. 597a Side Shifter (Hang-On)
Sec. 597b Side Shifter (Integral)
Sec. 655 Top Panel, Hinge & Fitting
Sec. 680 Instrument Panel, Pad & Cluster Lid
Sec. 691 Hydraulic Oil Pump & Fitting
Sec. 692 Hydraulic Oil Pump Assembly
Sec. 693 Hydraulic Control Valve
Sec. 694b Hydraulic Control Valve Fitting (Val3)
Sec. 694c Hydraulic Control Valve Fitting (Val4)
Sec. 695b Hyrdaulic Control Lever (Lvrl/Val3)
Sec. 695c Hyrdaulic Control Lever (Lvrl/Val4)
Sec. 695d Hyrdaulic Control Lever (Lvrw/Val3)
Sec. 695e Hyrdaulic Control Lever (Lvrw/Val4)
Sec. 697a Hydraulic Oil Piping (From Tank To Pump & Pump To Valve)
Sec. 697b Hydraulic Oil Piping (From Valve To Lift Cylinder)
Sec. 697c Hydraulic Oil Piping (From Valve To Tilt Cylinder)
Sec. 697d Hydraulic Oil Piping (From Valve To Oil Tank)
Sec. 697e Hydraulic Oil Piping (From Valve To Ps Valve)
Sec. 698a Hydraulic Oil Piping Mast (20+25t 2w)
Sec. 698b Hydraulic Oil Piping Mast (30t 2w)
Sec. 698c Hydraulic Oil Piping Mast (35t 2w)
Sec. 698d Hydraulic Oil Piping Mast (20+25t 2f)
Sec. 698e Hydraulic Oil Piping Mast (30t 2f)
Sec. 698f Hydraulic Oil Piping Mast (35t 2f)
Sec. 698g Hydraulic Oil Piping Mast (20+25t 3f)
Sec. 698h Hydraulic Oil Piping Mast (30t 3f)
Sec. 698i Hydraulic Oil Piping Mast (35t 3f)
Sec. 699a Hydraulic Oil Piping (Attachment) (2w)
Sec. 699b Hydraulic Oil Piping (Attachment) (2w Val3)
Sec. 699c Hydraulic Oil Piping (Attachment) (2w Val4)
Sec. 699d Hydraulic Oil Piping (Attachment) (2f)
Sec. 699e Hydraulic Oil Piping (Attachment) (2f Val3)
Sec. 699f Hydraulic Oil Piping (Attachment) (2f Val4)
Sec. 699g Hydraulic Oil Piping (Attachment) (3f)
Sec. 699h Hydraulic Oil Piping (Attachment) (3f Val3)
Sec. 699i Hydraulic Oil Piping (Attachment) (20~30t 3f Val4)
Sec. 699j Hydraulic Oil Piping (Attachment) (35t 3f Val4)
Sec. 737 Over Head Guard
Sec. 740 Floor Panel
Body (Side, Rear & Seat) Sec. 871
Sec. 871 Seat
Miscellaneous Sec. 991-999
Sec. 991 Caution Plate & Label Car
Sec. 999 Touch Up Paint
Part No. Index
Dealer Suggested Stocking List
