TCM FB-7 Series Forklift Truck Service Manual SEB-81BBE
Brand: TCM
Type of Machine: Forklift Truck
Model: FB10-7 FB15-7 FB18-7 FB20-7 FB25-7 FB30-7 FB25-7LB FB25-7V FB30-7V FB35-7S
Part Number: SEB-81BBE
Number of Pages: 179 Pages
1. BATTERY AND CHARGER
1.1 General Description
1.1.1 Battery
1.1.2 Charger
1.1.3 Charging Procedures
1.1.4 Charger Operation
2. MOTORS
2.1 General Discription
2.1.1 Drive Motor
2.1.2 Pump Motor
2.2 Maintenance
2.2.1 Drive Motor
2.2.2 Pump Motor
3. CONTROL SYSTEM
3.1 General Description
3.1.1 Inverter
3.1.2 Accelerator Pedal
3.1.3 Interlock System
3.1.4 Back-Down Alarm System
3.2 Maintenance
3.2.1 Troubleshooting Guide
4. DRIVE UNIT AND DRIVE AXLE
4.1 General Description
4.1.1 Drive Unit
4.1.2 Drive Axle
5. BRAKE SYSTEM
5.1 General Description
5.1.1 Brake Pedal
5.1.2 Master Cylinder
5.1.3 Wheel Brake
5.1.4 Parking Brake Lever
5.2 Maintenance
5.2.1 Disassembling Wheel Brake
5.2.2 Inspection
5.2.3 Reassembling Wheel Brake
5.2.4 Operation Test Of Automatic Clearance Adjuster
5.2.5 Adjusting Brake Pedal
5.2.6 Troubleshooting Guide
6. STEERING SYSTEM
6.1 General Description
6.1.1 Outline Of Steering System
6.1.2 Steering Gearbox
6.1.3 Actuator
6.1.4 Rear Axle
6.1.5 Adjusting Preload Of Rear Wheel Bearing
6.1.6 Assembling Wheel
6.2 Maintenance
6.2.1 Maintenance Of Actuator
6.2.2 Maintenance Of Steering Bearbox
7. HYDRAULIC SYSTEM
7.1 General Description
7.1.1 Main Pump
7.1.2 Control Valve
7.1.3 Hydraulic Oil Tank
7.1.4 Lift Cylinder
7.1.5 Flow Regulator Valve
7.1.6 Tilt Cylinder
7.2 Maintenance
7.2.1 Maintenance Of Pump
7.2.2 Trial Run
7.2.3 Troubleshooting Guide
8. LOAD HANDLING SYSTEM
8.1 General Description
8.1.1 Outer And Inner Channels
8.1.2 Carriage
8.1.3 Locations Of Rollers
8.2 Maintenance
8.2.1 Adjust Lift Cylinder Rod With Shims
8.2.2 Adjusting Height Of Carriage
8.2.3 Procedure For Replacing Rollers At Carriage Side
8.2.4 Procedure For Replacing Rollers At Mast Side
8.2.5 Procedure For Adding Or Subtracting Shims
9. ELECTRIC WIRING
