Hyundai
86
176,684
Takeuchi Track Loader TL8 TL10 TL12 Operators Manual AU8E003
Brand: Takeuchi
Type of Machine: Loader
Model: Takeuchi TL8 TL10 TL12 Loader
Serial Number:
TL8 : Serial No. 200800002-
TL10 : Serial No. 201000002-
TL12 : Serial No. 201200003-
Part Number: AU8E003
Number of Pages: 241 Pages
Cover
Safety alert symbol
Signal words​
Introduction​
Foreword​
Manual storage compartment​
Introduction​
Serial numbers​
Machine description​
Front, rear, left and right​
Designated operations​
Features​
Break-in period​
Notes on reading this manual​
Safety
General precautions​
Precautions when preparing​
Precautions when starting​
Precautions when operating​
Precautions when stopping​
Precautions when transporting​
Precautions on maintenance​
Safety signs (decals)​
Controls
Names of components​
Covers​
Ignition key​
Fuel filler port​
Engine hood​
Rear door​
Cab​
Cab door​
Side Window​
Emergency exit​
Fuse box​
Lift arm stopper​
Seat and seat belt​
Seat​
Seat belt​
3-point seat belt (optional)​
Instrument cluster​
Warning lamps​
Indicators​
Meters​
Multi-data display​
Switches​
Ignition switch​
Engine shutdown switch​
Horn button​
Float button​
Throttle controller​
Multifunction buttons​
Auxiliary hydraulic switches​
Travel speed button​
Front wiper switch (optional)​
Rear wiper switch (optional)
Front light switch​
Tail light switch​
ECO/Power mode select switch​
DPF manual regeneration/inhibit select switch​
Auxiliary 1st flow rate select switch​
Parking brake switch​
(TL12 optional)
Ride control switch (TL10/TL12 optional)​
Aux. 2nd/14-pin connector select switch (TL10/TL12 optional)​
14-pin connector G/H select switch (optional)​
Levers and Pedal​
Safety Bar​
Throttle lever (TL10/TL12)​
Throttle pedal (optional)​
Right control lever​
Left control lever​
Accessories​
Air conditioner​
External power socket​
Interior light​
Mirrors​
Radio (for cab optional)​
Auxiliary hydraulic lines (optional)​
Aux. 2nd lines (TL10/12 optional)​
High-Flow Hydraulic System​
(If equipped)
Lift arm lower button (If equipped)​
Blow by heater lamp​
Operation
Before starting operation​
Getting on or off the machine​
Walk-around inspection​
Daily inspection​
Starting and stopping the engine​
Before starting the engine​
Starting the Engine​
Warming up the engine​
Stopping the engine​
Operating the machine​
Lever pattern (ISO)​
Lever pattern (H)​
Warming up the machine (hydraulic oil)​
Inspection after warm-up​
Traveling the machine​
Stopping travel​
Operating the working equipment​
Operating procedures​
Prohibited operations​
Cautions on operating​
Cautions on traveling on slopes​
Operations possible with this machine​
Parking the machine​
Parking​
Inspection and checks after stopping the engine​
Handling in cold climates​
Preparing for cold climates​
Cautions after operations​
After the cold climate​
Handling rubber tracks​
Prohibitions​
Cautions​
Preventing the rubber tracks from coming off​
Transport
Loading and unloading​
Hoisting the machine​
Securing the machine​
Maintenance
General​
Maintenance overview​
Cautions on maintenance​
Service data​
Fuel and lubricant table​
Regularly replace the hydraulic oil​
List of consumables​
List of tools​
List of tightening torques​
Safety-critical parts​
Maintenance list​
Inspecting by opening the engine hood and rear door​
Inspecting by walking around the machine​
Inspecting while sitting in the operator’s seat​
Daily inspection (every 10 hours)​
Inspecting and replenishing the coolant​
Inspecting and replenishing the engine oil​
Inspecting the water separator​
Inspecting the fuel level​
Inspecting the hydraulic oil tank level and replenishing​
Lubricating the working equipment​
After the initial 50 hours (only for new machines)​
Replacing the engine oil and the oil filter​
Replacing the hydraulic oil return filter​
Replacing the pilot line filter​
Inspecting and adjusting the fan belt​
Inspecting and adjusting the compressor belt (AC)​
Every 50 hours​
Inspecting and adjusting the track tension​
Draining the water from the fuel tank​
Inspecting the battery fluid level and replenishing​
Inspecting the bucket stoppers (bolts/nuts)​
Every 100 hours​
Cleaning the water separator​
After the initial 250 hours (only for new machines)​
Replacing the travel motor gear oil​
Every 250 hours​
Replacing the air cleaner element​
Cleaning the radiator fins and the oil cooler fins​
Cleaning the condenser (AC)​
Cleaning the air filters (AC)​
Inspecting the refrigerant (gas) level (AC)​
Every 500 hours​
Replacing the fuel filters​
Adjusting or replacing the bucket stoppers (bolts/nuts)​
Every 1000 hours​
Cleaning the engine cooling system​
Replacing the hydraulic oil and cleaning the suction strainer​
Inspecting and adjusting the engine valve clearance​
Every 1500 hours​
Replacing the oil separator element​
Inspecting the injector tip​
Inspecting the EGR cooler​
Inspecting the PCV valve (TL10/TL12)​
Every 3000 hours​
Inspecting the turbocharger​
Cleaning the DPF​
Inspecting the EGR system​
When required​
Replacing the bucket or attachment​
Inspecting and replenishing the windshield washer fluid​
Lubricating the levers​
Inspecting the rubber tracks​
Every year​
Replacing the receiver drier​
Tilting up the canopy (cab)​
Maintenance during extended storage period​
Troubleshooting
Symptoms that are not malfunctions​
If the engine overheats​
If the battery goes dead​
If a fuse blows​
Inspecting and replacing the fuse​
Inspecting the fusible link​
Restarting after adding fuel​
Bleeding air from the fuel system​
If a warning lamp flashes​
Vehicle error code list​
Engine error code list​
Other symptoms​
Lowering the lift arms to the ground​
Towing​
If the cab or canopy is damaged​
Specifications
Basic Specifications​
Machine dimensions​
Operating ranges​
Options
Safety precautions​
Cautions when installing attachments​
Cautions when operating attachments​
Hydraulic quick-hitch​
Replacing the Bucket or Attachment​
Quick-Couplers​
4-Port quick-coupler (TL10/TL12)​
Selecting a lever pattern​
Switching the lever pattern​
Seat (with a switch function)​
Optional equipment mass​
California
EC-Conformity Certificate
