Hyundai
86
176,834
Takeuchi Track Loader TL240 Parts Manual BU2Z006-1-0
Brand: Takeuchi
Type of Machine: Track Loader
Model: Takeuchi TL240 Track Loader
Serial Number: 224000001-UP
Part Number: BU2Z006-1-0
Number of Pages: 490 Pages
UNDERCARRIAGE
TRACK ROLLER A​
TRACK ROLLER B​
FRONT IDLER​
TRACK ADJUSTER​
TRAVEL DEVICE​
CRAWLER BELT​
MAIN FRAME & CONTROL LEVER
FRAME​
ARM STOPPER​
HOOK​
OPERATION LEVER & STAND​
OPERATION LEVER & STAND (multi-functional grip type)​
PIPING; OPERATION LEVER​
ENGINE & ELECTRICAL SYSTEM
ENGINE & ACCESSORIES (1/4)​
ENGINE & ACCESSORIES (2/4)​
ENGINE & ACCESSORIES (3/4)​
ENGINE & ACCESSORIES (4/4)​
DRAIN PLUG​
CONTROL BOX; R.H. (224000001-224000080)​
CONTROL BOX; R.H. (high flow; 224000001-224000080)​
CONTROL BOX; R.H. (224000081-)​
CONTROL BOX; R.H. (high flow; 224000081-)​
CONTROL BOX; L.H.​
CONTROL BOX; L.H. (hydraulic quick hitch type)​
ENGINE CONTROL​
ENGINE CONTROL (throttle pedal type)​
ELECTRICAL (1/2) (224000002-224000016, 224000020-224000024)​
ELECTRICAL (1/2) (multi-functional grip type; 224000002-224000016, 224000020-224000024)​
ELECTRICAL (2/2) (224000002-224000016, 224000020-224000024)​
ELECTRICAL (1/2) (224000017-224000019)​
ELECTRICAL (1/2) (multi-functional grip type; 224000017-224000019)​
ELECTRICAL (2/2) (224000017-224000019)​
ELECTRICAL (1/2) (224000025-224000229)​
ELECTRICAL (1/2) (multi-functional grip type; 224000025-224000229)​
ELECTRICAL (2/2) (224000025-224000229)​
ELECTRICAL (1/2) (224000230-224000542)​
ELECTRICAL (1/2) (multi-functional grip type; 224000230-224000542)​
ELECTRICAL (2/2) (224000230-224000542)​
ELECTRICAL (1/2) (224000543-)​
ELECTRICAL (1/2) (multi-functional grip type; 224000543-)​
ELECTRICAL (2/2) (224000543-)​
ELECTRICAL (cab)​
ELECTRICAL (high flow)​
ELECTRICAL (MULTI-FUNCTIONAL GRIP TYPE)​
BATTERY​
REAR LAMP​
MAINTENANCE LIGHT SOCKET​
WINDOW WASHER​
RADIO​
HYDRAULIC PIPING & TANK
VALVE & ACCESSORIES (1/2)​
VALVE & ACCESSORIES (2/2)​
PIPING (1/2)​
PIPING (2/2)​
PIPING (1/2) (high flow)​
PIPING (2/2) (high flow)​
PUMP DRIVE​
GEAR PUMP DRIVE (high flow)​
HYDRAULIC TANK​
FUEL TANK & FUEL PIPING (224000001-224000560)​
FUEL TANK & FUEL PIPING (224000561-)​
COVER & CAB
COVER (1/3)​
COVER (2/3) (rear door)​
COVER (3/3) (engine hood)​
FLOOR FRAME​
FLOOR FRAME (THROTTLE PEDAL TYPE)​
SEAT (1/2)​
SEAT (2/2)​
SEAT SWITCH (224000001-224000122)​
SEAT SWITCH (224000123-)​
SAFETY BAR​
CANOPY MOUNT​
CANOPY (1/3) (for US)​
CANOPY (2/3) (for US)​
CANOPY (3/3) (for US)​
CAB MOUNT​
CAB (1/6)​
CAB (2/6)​
CAB (3/6)​
CAB (4/6)​
CAB (5/6)​
CAB (6/6) FRONT DOOR​
CAB (6/6) (front door, polycarbonate type)​
CAB KIT (1/5)​
CAB KIT (2/5) (front door)​
CAB KIT (3/5)​
CAB KIT (4/5)​
CAB KIT (5/5)​
DOOR KIT (1/2) (polycarbonate type)​
DOOR KIT (2/2) (polycarbonate type)​
REAR MIRROR​
REARVIEW MIRROR​
MANUAL STORAGE​
AIR CONDITIONER (1/5) (compressor)​
AIR CONDITIONER (2/5) (condenser)​
AIR CONDITIONER (3/5) (air conditioner unit)​
AIR CONDITIONER (4/5)​
AIR CONDITIONER (5/5)​
ARM​
QUICK HITCH​
QUICK HITCH (1/2) (hydraulic type)​
QUICK HITCH (2/2) (hydraulic type)​
QUICK HITCH (2/2) (hydraulic type, with 3/4 coupler)​
PIPING; ARM (1/2)​
PIPING; ARM (2/2)​
PIPING; ARM (2/2) (with coupler, hydraulic quick hitch type)​
PIPING; ARM (2/2) (with 14 pin connector)​
PIPING; ARM (1/2) (high flow)​
PIPING; ARM (2/2) (high flow)​
PIPING; ARM (2/2) (high flow, with coupler, hydraulic quick hitch type)​
PIPING; ARM (2/2) (high flow, with 14 pin connector)​
PIPING; ARM (2/2) (high flow, with 3/4 coupler)​
DECAL & TOOL
DECAL (canopy)​
DECAL (canopy)(English)​
DECAL (canopy) 3​
DECAL (canopy) (for U.S.)​
DECAL (CANOPY)(FOR U.S)​
DECAL (cab)​
DECAL (CAB)(ENGLISH)​
DECAL (cab) 3​
DECAL (cab) (high flow)​
TOOL​
PAINTED COLOR​
HYDRAULIC DEVICE
CONTROL VALVE​
CONTROL VALVE (high flow)​
PILOT VALVE (R.H.)​
PILOT VALVE (L.H.)​
HANDLE (with slide switch)​
HANDLE (with 3 switch)​
PILOT VALVE (R.H.) (multi-functional grip type)​
PILOT VALVE (L.H.) (multi-functional grip type)​
HANDLE (multi-functional grip type, with slide switch)​
HANDLE (multi-functional grip type, with 5 switch)​
SUB VALVE​
SOLENOID VALVE; 1 BLOCK​
ELECTRICAL PROPORTION VALVE​
ARM CYLINDER​
BUCKET CYLINDER​
QUICK HITCH CYLINDER​
TRAVEL MOTOR (1/3) (reduction sec.)​
TRAVEL MOTOR (2/3) (motor sec. )​
TRAVEL MOTOR (3/3) (valve sec. )​
HYDRAULIC PUMP (1/5)​
HYDRAULIC PUMP (2/5)​
HYDRAULIC PUMP (3/5)​
HYDRAULIC PUMP (4/5)​
HYDRAULIC PUMP (5/5)​
GEAR PUMP​
GEAR PUMP (high flow)​
ENGINE 4TNV98T-ZNTBL S/N 224000001-UP
How to read Parts Catalog​
CYLINDER BLOCK​
CYLINDER BLOCK​
GEAR HOUSING​
GEAR HOUSING​
FLYWHEEL HOUSING & OIL SUMP​
CYLINDER HEAD & BONNET​
SUCTION MANIFOLD & AIR CLEANER​
EXHAUST MANIFOLD & SILENCER​
CAMSHAFT & DRIVING GEAR​
TURBINE​
TURBINE​
CRANKSHAFT & PISTON​
LUB.OIL SYSTEM​
LUB.OIL SYSTEM​
LUB.OIL LINE​
LUB.OIL LINE​
COOLING WATER SYSTEM​
FUEL INJECTION PUMP​
GOVERNOR​
GOVERNOR​
FUEL INJECTION VALVE​
FUEL LINE​
FUEL LINE​
STARTING MOTOR​
STARTING MOTOR​
GENERATOR​
GENERATOR​
ELECTRIC PARTS​
ELECTRIC PARTS​
GASKET SET​
GASKET SET​
KITS, ATTACHMENTS & QUICK REFERENCE
Recommended Stock List​
BLOCK HEATERS​
SERVICE BULLETIN(S)
INSTALLATION GUIDE CASE CONTROL KIT 200 SERIES​
INSTALLATION GUIDE TL230, TL240, TL250, TL8, TL10, TL12​
Appendix B:parts Index
Appendix A:pages Index
