Takeuchi Track Loader TL230A Series 2 Parts Manual BU5Z005
Brand: Takeuchi
Type of Machine: Track Loader
Model: Takeuchi TL230A Series 2 Track Loader
Serial Number 223100001-
Part Number: BU5Z005
Number of Pages: 463 Pages
UNDERCARRIAGE
arts Index
Appendix A
ages Index
Brand: Takeuchi
UNDERCARRIAGE
TRACK ROLLER A
TRACK ROLLER B
FRONT IDLER
TRACK ADJUSTER
TRAVEL DEVICE
CRAWLER BELT
MAIN FRAME & CONTROL LEVERFRAME
ARM STOPPER
HOOK
OPERATION LEVER & STAND
PIPING; OPERATION LEVER
ENGINE & ELECTRICAL SYSTEMENGINE & ACCESSORIES (1/5) (223100001-223101932)
ENGINE & ACCESSORIES (2/5) (223100001-223101932)
ENGINE & ACCESSORIES (1/5) (223101933-)
ENGINE & ACCESSORIES (2/5) (223101933-)
ENGINE & ACCESSORIES (3/5)
ENGINE & ACCESSORIES (4/5)
ENGINE & ACCESSORIES (5/5)
DRAIN PLUG
CONTROL BOX RH
CONTROL BOX; L.H.
CONTROL BOX; L.H. (hydraulic quick hitch type)
ENGINE CONTROL
ENGINE CONTROL (throttle pedal type)
ELECTRICAL (1/2)
ELECTRICAL (2/2)
ELECTRICAL (grip switch)
BATTERY
REAR LAMP
MAINTENANCE LIGHT SOCKET
WINDOW WASHER
RADIO
HYDRAULIC PIPING & TANKVALVE & ACCESSORIES (1/2)
VALVE & ACCESSORIES (2/2)
PIPING (1/2)
PIPING (2/2)
PIPING (1/2) (high flow)
PIPING (2/2) (high flow)
PUMP DRIVE
GEAR PUMP DRIVE (high flow)
HYDRAULIC TANK
FUEL TANK & FUEL PIPING
COVER & CABCOVER (1/3)
COVER (2/3) (engine hood)
COVER (3/3) (rear door)
FLOOR FRAME
FLOOR FRAME (throttle pedal type)
SEAT (1/2)
SEAT (2/2)
SEAT SWITCH
SAFETY BAR
CANOPY MOUNT (for US)
CANOPY (1/2) (for US)
CANOPY (2/2) (for US)
CAB MOUNT
CAB (1/6)
CAB (2/6)
CAB (3/6)
CAB (4/6)
CAB (5/6)
CAB (6/6) (front door) (223100001-223101417)
CAB (6/6) (front door) (22310141
DOOR KIT (1/2) (polycarbonate type)
DOOR KIT (2/2) (polycarbonate type)
REAR MIRROR
REARVIEW MIRROR
MANUAL STORAGE
AIR CONDITIONER (1/5) (compressor)
AIR CONDITIONER (2/5) (condenser)
AIR CONDITIONER (3/5) (air conditioner unit)
AIR CONDITIONER (4/5)
AIR CONDITIONER (5/5)
ATTACHMENTARM
QUICK HITCH
QUICK HITCH (1/2) (hydraulic type)
QUICK HITCH (2/2) (hydraulic type)
PIPING; ARM (1/2)
PIPING: ARM (2/2)
PIPING; ARM (2/2) (with coupler, hydraulic quick hitch type)
PIPING; ARM (1/2) (high flow)
PIPING; ARM (2/2) (high flow)
PIPING; ARM (2/2) (high flow, with coupler, hydraulic quick hitch type)
DECAL & TOOLDECAL (canopy) 1
DECAL (canopy) 2
DECAL (canopy) (U.S. TAKEUCHI) 1
DECAL (canopy) (U.S. TAKEUCHI) 2
DECAL (cab) 1
DECAL (cab) (high flow)
PAINTED COLOR
HYDRAULIC DEVICECONTROL VALVE
CONTROL VALVE (high flow)
PILOT VALVE (RH)
PILOT VALVE (LH)
HANDLE (with slide switch)
HANDLE (with 5 switch)
SUB VALVE
SOLENOID VALVE; 1 BLOCK
ELECTRICAL PROPORTION VALVE
ARM CYLINDER
BUCKET CYLINDER
QUICK HITCH CYLINDER
TRAVEL MOTOR (1/3) (reduction sec.)
TRAVEL MOTOR (2/3) (motor sec.)
TRAVEL MOTOR (3/3) (valve sec.)
HYDRAULIC PUMP (1/4)
HYDRAULIC PUMP (2/4)
HYDRAULIC PUMP (3/4)
HYDRAULIC PUMP (4/4)
GEAR PUMP
GEAR PUMP (high flow)
ENGINE V3307-DI-T-E3B-TLTU1 KUBOTA ENGINEV3307-DI-T-E3B-TLTU1 KUBOTA ENGINE
OIL PAN
OIL PAN
DIPSTICK AND GUIDE
DIPSTICK AND GUIDE
CYLINDER HEAD
CYLINDER HEAD
INLET VALVE AND EXHAUST VALVE
ROCKER ARM SHAFT
ROCKER ARM SHAFT
HEAD COVER
HEAD COVER
FRONT COVER
FRONT COVER
PISTON AND CRANKSHAFT
CAMSHAFT AND IDLE GEAR SHAFT
FLYWHEEL
FLYWHEEL
INJECTION PUMP UNIT
INJECTION PUMP UNIT
INJECTION PUMP HOUSING
INJECTION PUMP
FUEL PUMP
FUEL PUMP
FUEL CAMSHAFT
FUEL CAMSHAFT
GOVERNOR
GOVERNOR
FORK LEVER (GOVERNOR)
RESTRICTION ADJUSTING BOLT
STOP SOLENOID
STOP SOLENOID
FUEL FILTER
FUEL FILTER
NOZZLE HOLDER AND GLOW PLUG
INJECTION PIPE
INJECTION PIPE
ALTERNATOR AND PULLEY
ALTERNATOR (COMPONENT PARTS)
STARTER
STARTER
STARTER (COMPONENT PARTS)
OIL SWITCH
OIL SWITCH
WATER FLANGE AND THERMOSTAT
WATER PUMP
WATER PUMP
WATER PIPE
WATER PIPE
RESERVE TANK
RESERVE TANK
FAN AND PULLEY
FAN AND PULLEY
INLET MANIFOLD
INLET MANIFOLD
EXHAUST MANIFOLD
EXHAUST MANIFOLD
EGR VALVE
EGR VALVE
EGR COOLER
EGR COOLER
TURBO CHARGER
TURBO CHARGER
OIL PIPE (TURBO CHARGER)
OIL PIPE (SIDE PTO)
OIL PIPE (SIDE PTO)
OIL COOLER
OIL COOLER
GLOW LAMP AND TIMER
GLOW LAMP AND TIMER
ACCESSORIES AND SERVICE PARTS
UPPER GASKET KIT (OPTION)
LOWER GASKET KIT (OPTION)
METAL KIT (OPTION)
METAL KIT (OPTION)
PISTON KIT (OPTION)
PISTON KIT (OPTION)
KITS, ATTACHMENTS & QUICK REFERENCERecommended Stock List
BLOCK HEATERS
SERVICE BULLETIN(S)SERVICE BULLETIN SB020113
SERVICE BULLETIN SB020113 INSTALLATION INSTRUCTIONS
INSTALLATION GUIDE CASE CONTROL KIT 200 SERIES
INSTALLATION GUIDE TL230, TL240, TL250, TL8, TL10, TL12
Appendix BAppendix A
- Takeuchi Compact Excavator TB014-TB016 Workshop Manual
- Takeuchi TB125, TB135, TB145 owners manual
- Takeuchi 10.2014 Parts Manual
- Takeuchi TB15 Operator Manual
- Takeuchi Excavator TB228 TB235 TB250 Operator Manual
- TAKEUCHI EXCAVATOR TB016 Parts Manual
- TAKEUCHI EXCAVATOR TB23 R Parts Manual
- Takeuchi Crawler Loader TL10 Operator Manual
- Takeuchi TB014 and TB016 Workshop Manual
- Takeuchi Mini Excavator TB240 Operator Manual
- Takeuchi Track Loader TL120/TL130/TL140/TL150 AT7E023 Operators Manual
- Takeuchi TB260 A-XDE Mini Excavator Operator Manual
- Takeuchi TL 130 & 150 Stop Solenoid Circuit Wiring Diagram Manual
- TAKEUCHI EXCAVATOR TB216 Parts Manual
- Takeuchi TL 140 Engine Shut Down Circuit Wiring Diagram Manual
