Hyundai
86
176,834
Takeuchi Track Loader TL230 Parts Manual P-TL230BBG
Brand: Takeuchi
Type of Machine: Track Loader
Model: Takeuchi TL230 Track Loader
Serial Number: 223100001-
Part Number: P-TL230BBG
Publication Date: BU5Z005-1-0
Number of Pages: 415 Pages
UNDERCARRIAGE
TRACK ROLLER A​
TRACK ROLLER B​
FRONT IDLER​
TRACK ADJUSTER​
TRAVEL DEVICE​
CRAWLER BELT​
MAIN FRAME & CONTROL LEVER
FRAME​
ARM STOPPER​
HOOK​
OPERATION LEVER & STAND​
PIPING; OPERATION LEVER​
ENGINE & ELECTRICAL SYSTEM
ENGINE & ACCESSORIES (1/5) (223100001-223101932)​
ENGINE & ACCESSORIES (2/5) (223100001-223101932)​
ENGINE & ACCESSORIES (1/5) (223101933-)​
ENGINE & ACCESSORIES (2/5) (223101933-)​
ENGINE & ACCESSORIES (3/5)​
ENGINE & ACCESSORIES (4/5)​
ENGINE & ACCESSORIES (5/5)​
DRAIN PLUG​
CONTROL BOX RH​
CONTROL BOX, RH (high flow)​
CONTROL BOX; L.H.​
CONTROL BOX; L.H. (hydraulic quick hitch type)​
ENGINE CONTROL​
ENGINE CONTROL (throttle pedal type)​
ELECTRICAL (1/2)​
ELECTRICAL (2/2)​
ELECTRICAL (grip switch)​
BATTERY​
REAR LAMP​
MAINTENANCE LIGHT SOCKET​
WINDOW WASHER​
RADIO​
HYDRAULIC PIPING & TANK
VALVE & ACCESSORIES (1/2)​
VALVE & ACCESSORIES (2/2)​
PIPING (1/2)​
PIPING (2/2)​
PIPING (1/2) (high flow)​
PIPING (2/2) (high flow)​
PUMP DRIVE​
GEAR PUMP DRIVE (high flow)​
HYDRAULIC TANK​
FUEL TANK & FUEL PIPING​
COVER & CAB
COVER (1/3)​
COVER (2/3) (engine hood)​
COVER (3/3) (rear door)​
FLOOR FRAME​
FLOOR FRAME (throttle pedal type)​
SEAT (1/2)​
SEAT (2/2)​
SEAT SWITCH​
SAFETY BAR​
CANOPY MOUNT (for US)​
CANOPY (1/2) (for US)​
CANOPY (2/2) (for US)​
CAB MOUNT​
CAB (1/6)​
CAB (2/6)​
CAB (3/6)​
CAB (4/6)​
CAB (5/6)​
CAB (6/6) (front door) (223100001-223101417)​
CAB (6/6) (front door) (22310141:cool:​
DOOR KIT (1/2) (polycarbonate type)​
DOOR KIT (2/2) (polycarbonate type)​
REAR MIRROR​
REARVIEW MIRROR​
MANUAL STORAGE​
AIR CONDITIONER (1/5) (compressor)​
AIR CONDITIONER (2/5) (condenser)​
AIR CONDITIONER (3/5) (air conditioner unit)​
AIR CONDITIONER (4/5)​
AIR CONDITIONER (5/5)​
ARM​
QUICK HITCH​
QUICK HITCH (1/2) (hydraulic type)​
QUICK HITCH (2/2) (hydraulic type)​
PIPING; ARM (1/2)​
PIPING: ARM (2/2)​
PIPING; ARM (2/2) (with coupler, hydraulic quick hitch type)​
PIPING; ARM (1/2) (high flow)​
PIPING; ARM (2/2) (high flow)​
PIPING; ARM (2/2) (high flow, with coupler, hydraulic quick hitch type)​
DECAL & TOOL
DECAL (canopy) (U.S. TAKEUCHI) 1​
DECAL (canopy) (U.S. TAKEUCHI) 2​
DECAL (cab) U.S TAKEUCHI - 1​
DECAL (cab) (high flow)​
PAINTED COLOR​
HYDRAULIC DEVICE
CONTROL VALVE​
PILOT VALVE (RH)​
PILOT VALVE (LH)​
HANDLE (with slide switch)​
HANDLE (with 5 switch)​
SUB VALVE​
SOLENOID VALVE; 1 BLOCK​
ELECTRICAL PROPORTION VALVE​
ARM CYLINDER​
BUCKET CYLINDER​
QUICK HITCH CYLINDER​
TRAVEL MOTOR (1/3) (reduction sec.)​
TRAVEL MOTOR (2/3) (motor sec.)​
TRAVEL MOTOR (3/3) (valve sec.)​
HYDRAULIC PUMP (1/4)​
HYDRAULIC PUMP (2/4)​
HYDRAULIC PUMP (3/4)​
HYDRAULIC PUMP (4/4)​
GEAR PUMP​
GEAR PUMP (high flow)​
ENGINE V3307-DI-T-E3B-TLTU1 KUBOTA ENGINE
V3307-DI-T-E3B-TLTU1 KUBOTA ENGINE​
OIL PAN​
OIL PAN​
DIPSTICK AND GUIDE​
DIPSTICK AND GUIDE​
CYLINDER HEAD​
CYLINDER HEAD​
INLET VALVE AND EXHAUST VALVE​
ROCKER ARM SHAFT​
ROCKER ARM SHAFT​
HEAD COVER​
HEAD COVER​
FRONT COVER​
FRONT COVER​
PISTON AND CRANKSHAFT​
CAMSHAFT AND IDLE GEAR SHAFT​
FLYWHEEL​
FLYWHEEL​
INJECTION PUMP UNIT​
INJECTION PUMP HOUSING​
INJECTION PUMP​
INJECTION PUMP​
FUEL PUMP​
FUEL PUMP​
FUEL CAMSHAFT​
FUEL CAMSHAFT​
GOVERNOR​
GOVERNOR​
FORK LEVER (GOVERNOR)​
RESTRICTION ADJUSTING BOLT​
STOP SOLENOID​
STOP SOLENOID​
FUEL FILTER​
FUEL FILTER​
NOZZLE HOLDER AND GLOW PLUG​
INJECTION PIPE​
INJECTION PIPE​
ALTERNATOR AND PULLEY​
ALTERNATOR (COMPONENT PARTS)​
STARTER​
STARTER​
STARTER (COMPONENT PARTS)​
OIL SWITCH​
OIL SWITCH​
WATER FLANGE AND THERMOSTAT​
WATER PUMP​
WATER PUMP​
WATER PIPE​
WATER PIPE​
RESERVE TANK​
RESERVE TANK​
FAN AND PULLEY​
FAN AND PULLEY​
INLET MANIFOLD​
INLET MANIFOLD​
EXHAUST MANIFOLD​
EXHAUST MANIFOLD​
EGR VALVE​
EGR VALVE​
EGR COOLER​
EGR COOLER​
TURBO CHARGER​
TURBO CHARGER​
OIL PIPE (TURBO CHARGER)​
OIL PIPE (SIDE PTO)​
OIL COOLER​
OIL COOLER​
GLOW LAMP AND TIMER​
ACCESSORIES AND SERVICE PARTS​
UPPER GASKET KIT (OPTION)​
LOWER GASKET KIT (OPTION)​
METAL KIT (OPTION)​
METAL KIT (OPTION)​
PISTON KIT (OPTION)​
KITS, ATTACHMENTS & QUICK REFERENCE
BLOCK HEATERS​
BUCKETS-BLADES-ATTACHMENTS​
RECOMMENDED STOCK LIST (TL230) SN 223100001-​
TL8-TL130-TL230 UNDERCARRIAGE TRACK KITS​
Appendix A:pages Index
Appendix B:parts Index
Blank Page
