Hyundai
86
176,834
Takeuchi Track Loader TL230 Parts Manual BU1Z007-2-0
Brand: Takeuchi
Type of Machine: Track Loader
Model: Takeuchi TL230 Track Loader
Serial Number: 223000001-
Part Number: BU1Z007-2-0
Number of Pages: 442 Pages
UNDERCARRIAGE
TRACK ROLLER A​
TRACK ROLLER B​
FRONT IDLER​
TRACK ADJUSTER​
TRAVEL DEVICE​
CRAWLER BELT​
MAIN FRAME & CONTROL LEVER
FRAME​
ARM STOPPER​
HOOK​
OPERATION LEVER & STAND​
OPERATION LEVER & STAND (multi-functional grip type)​
PIPING; OPERATION LEVER​
ENGINE & ELECTRICAL SYSTEM
ENGINE & ACCESSORIES (1/4)​
ENGINE & ACCESSORIES (2/4)​
ENGINE & ACCESSORIES (3/4)​
ENGINE & ACCESSORIES (4/4)​
DRAIN PLUG​
CONTROL BOX; R.H. (223000001-223000122)​
CONTROL BOX; R.H. (high flow; 223000001-223000122)​
CONTROL BOX; R.H. (223000123-)​
CONTROL BOX; R.H. (high flow; 223000123-)​
CONTROL BOX; L.H.​
CONTROL BOX; L.H. (hydraulic quick hitch type)​
ENGINE CONTROL​
ENGINE CONTROL (throttle pedal type)​
ELECTRICAL (1/3) (223000002-223000007, 223000009-223000033, 223000035, 223000042-223000081)​
ELECTRICAL (2/3) (223000002-223000007, 223000009-223000033, 223000035, 223000042-223000081)​
ELECTRICAL (3/3) (223000002-223000007, 223000009-223000033, 223000035, 223000042-223000081)​
ELECTRICAL (1/3) (223000008, 223000034, 223000036-223000041)​
ELECTRICAL (2/3) (223000008, 223000034, 223000036-223000041)​
ELECTRICAL (3/3) (223000008, 223000034, 223000036-223000041)​
ELECTRICAL (1/3) (223000082-223000296)​
ELECTRICAL (2/3) (223000082-223000296)​
ELECTRICAL (3/3) (223000082-223000296)​
ELECTRICAL (1/3) (223000297-223000854)​
ELECTRICAL (2/3) (223000297-223000854)​
ELECTRICAL (3/3) (223000297-223000854)​
ELECTRICAL (1/3) (223000855-)​
ELECTRICAL (2/3) (223000855-)​
ELECTRICAL (3/3) (223000855-)​
ELECTRICAL (multi-functional grip type)​
ELECTRICAL (cab)​
ELECTRICAL (high flow)​
BATTERY​
REAR LAMP​
MAINTENANCE LIGHT SOCKET​
WINDOW WASHER​
RADIO​
HYDRAULIC PIPING & TANK
VALVE & ACCESSORIES (1/2)​
VALVE & ACCESSORIES (2/2)​
PIPING (1/2)​
PIPING (2/2)​
PIPING (1/2) (high flow)​
PIPING (2/2) (high flow)​
PUMP DRIVE​
GEAR PUMP DRIVE (high flow)​
HYDRAULIC TANK​
FUEL TANK & FUEL PIPING (223000001-223000833)​
FUEL TANK & FUEL PIPING (223000834-)​
COVER & CAB
COVER (1/3)​
COVER (2/3) (engine hood)​
COVER (3/3) (rear door)​
FLOOR FRAME​
FLOOR FRAME (throttle pedal type)​
SEAT (1/2)​
SEAT (2/2)​
SEAT SWITCH (223000001-223000182)​
SEAT SWITCH (223000183-)​
SAFETY BAR​
CANOPY MOUNT (for US)​
CANOPY (1/2) (for US)​
CANOPY (2/2) (for US)​
CAB MOUNT​
CAB (1/6)​
CAB (2/6)​
CAB (3/6)​
CAB (4/6)​
CAB (5/6)​
CAB (6/6) (front door)​
DOOR KIT (1/2) (polycarbonate type)​
DOOR KIT (2/2) (polycarbonate type)​
REAR MIRROR​
REARVIEW MIRROR​
MANUAL STORAGE​
AIR CONDITIONER (1/5) (compressor)​
AIR CONDITIONER (2/5) (condenser)​
AIR CONDITIONER (3/5) (air conditioner unit)​
AIR CONDITIONER (4/5)​
AIR CONDITIONER (5/5)​
ARM​
QUICK HITCH​
QUICK HITCH (1/2) (hydraulic type)​
QUICK HITCH (2/2) (hydraulic type)​
PIPING; ARM (1/2)​
PIPING; ARM (2/2)​
PIPING; ARM (2/2) (with coupler, hydraulic quick hitch type)​
PIPING; ARM (1/2) (high flow)​
PIPING; ARM (2/2) (high flow)​
PIPING; ARM (2/2) (high flow, with coupler, hydraulic quick hitch type)​
DECAL & TOOL
DECAL (canopy) (U.S. TAKEUCHI) 1​
DECAL (canopy) (U.S. TAKEUCHI) 2​
DECAL (cab) 1​
DECAL (cab) 2​
DECAL (cab) 3​
DECAL (cab) (high flow)​
TOOL & ACCESSORIES​
PAINTED COLOR​
HYDRAULIC DEVICE
CONTROL VALVE​
CONTROL VALVE (high flow)​
PILOT VALVE (R.H.)​
PILOT VALVE (L.H.)​
HANDLE (with slide switch)​
HANDLE (with 3 switch)​
PILOT VALVE (R.H.) (multi-functional grip type)​
PILOT VALVE (L.H.) (multi-functional grip type)​
HANDLE (multi-functional grip type, with slide switch)​
HANDLE (multi-functional grip type, with 5 switch)​
SUB VALVE​
SOLENOID VALVE; 1 BLOCK​
ELECTRICAL PROPORTION VALVE​
ARM CYLINDER​
BUCKET CYLINDER​
QUICK HITCH CYLINDER​
TRAVEL MOTOR (1/3) (reduction sec.)​
TRAVEL MOTOR (2/3) (motor sec.)​
TRAVEL MOTOR (3/3) (valve sec.)​
HYDRAULIC PUMP (1/4)​
HYDRAULIC PUMP (2/4)​
HYDRAULIC PUMP (3/4)​
HYDRAULIC PUMP (4/4)​
GEAR PUMP​
GEAR PUMP (high flow)​
ENGINE 4TNV98-ZNTBL EAC S/N 223000001-UP
CYLINDER BLOCK​
CYLINDER BLOCK​
GEAR HOUSING​
GEAR HOUSING​
FLYWHEEL HOUSING & OIL SUMP​
CYLINDER HEAD & BONNET​
SUCTION MANIFOLD & AIR CLEANER​
EXHAUST MANIFOLD & SILENCER​
CAMSHAFT & DRIVING GEAR​
CRANKSHAFT & PISTON​
LUB. OIL SYSTEM​
LUB. OIL SYSTEM​
COOLING WATER SYSTEM​
FUEL INJECTION PUMP​
GOVERNOR​
GOVERNOR​
FUEL INJECTION VALVE​
FUEL LINE​
FUEL LINE​
STARTING MOTOR​
STARTING MOTOR​
GENERATOR​
GENERATOR​
ELECTRIC PARTS​
ELECTRIC PARTS​
GASKET SET​
GASKET SET​
KITS, ATTACHMENTS & QUICK REFERENCE
Recommended Stock List​
BLOCK HEATERS​
FIELD INSTALL OPTION HYD QUICK ATTACH CANOPY UNIT
K28837001 FIELD INSTALL OPTION 1 OF 3​
K28837001 FIELD INSTALL OPTION 2 OF 3​
K28837001 FIELD INSTALL OPTION 3 OF 3​
INSTALLATION GUIDE CASE CONTROL KIT 200 SERIES​
Appendix B:parts Index
Appendix A:pages Index
