Hyundai
86
176,834
Takeuchi Track Loader TL12 Parts Manual BU7Z003-0-0
Brand: Takeuchi
Type of Machine: Track Loader
Model: Takeuchi TL12 Track Loader
Part Number: BU7Z003-0-0
Serial Number: 201200003-UP
Number of Pages: 760 Pages
UNDERCARRIAGE
FRAME 1​
FRAME 2​
TRACK ROLLER A​
TRACK ROLLER B​
FRONT IDLER​
TRACK ADJUSTER​
TRAVEL DEVICE​
CRAWLER BELT​
MAIN FRAME & CONTROL LEVER
ARM STOPPER​
HOOK​
OPERATION LEVER & STAND​
PIPING; OPERATION LEVER​
PIPING; OPERATION LEVER (ISO-H pattern) (add-on type) 1​
PIPING; OPERATION LEVER (ISO-H pattern) (add-on type) 2​
ENGINE & ELECTRICAL SYSTEM
ENGINE & ACCESSORIES (1/4) 1​
ENGINE & ACCESSORIES (1/4) 2​
ENGINE & ACCESSORIES (1/4) (with CCV heater) 1​
ENGINE & ACCESSORIES (1/4) (with CCV heater) 2​
ENGINE & ACCESSORIES (2/4)​
ENGINE & ACCESSORIES (3/4)​
ENGINE & ACCESSORIES (4/4)​
DRAIN PLUG​
CONTROL BOX; R.H.​
CONTROL BOX; R.H. (with CCV heater)​
CONTROL BOX; L.H.​
CONTROL BOX; L.H. (hydraulic quick hitch type)​
ENGINE CONTROL​
FOOT ACCELERATOR​
ELECTRICAL (1/2) (201200003-201201480, 201201493, 201201494) 1​
ELECTRICAL (1/2) (201200003-201201480, 201201493, 201201494) 2​
ELECTRICAL (1/2) (201200003-201201480, 201201493, 201201494) 3​
ELECTRICAL (1/2) (201200003-201201480, 201201493, 201201494) 4​
ELECTRICAL (1/2) (201201481-201201492, 201201495-) 1​
ELECTRICAL (1/2) (201201481-201201492, 201201495-) 2​
ELECTRICAL (1/2) (201201481-201201492, 201201495-) 3​
ELECTRICAL (2/2) (201200003-201201480, 201201493, 201201494)​
ELECTRICAL (2/2) (201201481-201201492, 201201495-)​
ELECTRICAL (cab)​
ELECTRICAL (canopy)​
BATTERY​
REAR LAMP​
MAINTENANCE LIGHT SOCKET​
WINDOW WASHER​
RADIO​
HYDRAULIC PIPING & TANK
VALVE & ACCESSORIES (1/3)​
VALVE & ACCESSORIES (1/3) (high flow) 1​
VALVE & ACCESSORIES (1/3) (high flow) 2​
VALVE & ACCESSORIES (2/3)​
VALVE & ACCESSORIES (3/3) (high flow)​
MANUAL PARKING BRAKE​
PIPING 1​
PIPING 2​
RIDE CONTROL​
QUICK HITCH (hydraulic type, with 3/4 coupler) 1​
PUMP DRIVE​
GEAR PUMP DRIVE (high flow)​
HYDRAULIC TANK​
FUEL TANK & FUEL PIPING (1/2) 1​
FUEL TANK & FUEL PIPING (1/2) 2​
FUEL TANK & FUEL PIPING (2/2)​
COVER & CAB
COVER (1/3)​
COVER (2/3) (rear door)​
COVER (3/3) (engine hood)​
FLOOR FRAME​
SEAT (1/2)​
SEAT (2/2)​
SEAT (1/2) (with air-suspension)​
SEAT BELT (three point seat belt)​
SEAT SWITCH​
SAFETY BAR​
CANOPY MOUNT​
CANOPY 1​
CANOPY 2​
CANOPY 3​
CAB MOUNT​
CAB (1/2) 1​
CAB (1/2) 2​
CAB (1/2) 3​
CAB (1/2) 4​
CAB (1/2) 5​
CAB (2/2) (front door)​
CAB (2/2) (front door, polycarbonate type)​
CAB KIT (1/2) 1​
CAB KIT (1/2) 2​
CAB KIT (1/2) 3​
CAB KIT (1/2) 4​
CAB KIT (2/2) (front door)​
DOOR KIT (1/2) (polycarbonate type)​
DOOR KIT (2/2) POLYCARBONATE TYPE​
REAR MIRROR​
AIR CONDITIONER (1/5) (compressor)​
AIR CONDITIONER (2/5) (condenser)​
AIR CONDITIONER (3/5) (air conditioner unit)​
AIR CONDITIONER (4/5)​
AIR CONDITIONER (5/5)​
ARM​
QUICK HITCH​
QUICK HITCH (hydraulic type) 1​
QUICK HITCH (hydraulic type) 2​
QUICK HITCH (hydraulic type, with 3/4 coupler) 2​
PIPING; ARM 1​
PIPING; ARM 2​
PIPING; ARM (with coupler) 1​
PIPING; ARM (with coupler) 2​
PIPING; ARM (high flow) 1​
PIPING; ARM (high flow) 2​
PIPING; ARM (high flow, with 3/4 coupler) 1​
PIPING; ARM (high flow, with 3/4 coupler) 2​
PIPING; ARM (high flow, with coupler, hydraulic quick hitch type) 1​
PIPING; ARM (high flow, with coupler, hydraulic quick hitch type) 2​
2ND AUXILIARY LINE​
2ND AUXILIARY LINE (except for main aux. type)​
DECAL & TOOL
DECAL (canopy) 1​
DECAL (canopy) 2​
DECAL (canopy) 3​
DECAL (cab) 1​
DECAL (cab) 2​
DECAL (cab) 3​
DECAL (high flow)​
TOOL & ACCESSORIES​
PAINTED COLOR​
SERVICE TOOL​
HYDRAULIC DEVICE
CONTROL VALVE (high flow)​
BLOCK ASSY; No. 1​
BLOCK ASSY; No. 2​
BLOCK ASSY; No. 3​
CONTROL VALVE​
PILOT VALVE (R.H.)​
PILOT VALVE (L.H.)​
HANDLE (with slide switch)​
HANDLE (with 5 switch)​
SUB VALVE​
SOLENOID VALVE; 1 BLOCK (201200003-201201271)​
SOLENOID VALVE; 1 BLOCK (201201272-)​
SOLENOID VALVE; 1 BLOCK​
ELECTRICAL PROPORTION VALVE​
SELECTOR VALVE (ISO-H pattern)​
SHUTTLE VALVE (ISO-H pattern)​
LIFT ARM CYLINDER​
BUCKET CYLINDER​
QUICK HITCH CYLINDER​
TRAVEL MOTOR (1/3) (reduction sec.)​
TRAVEL MOTOR (2/3) (motor sec. )​
TRAVEL MOTOR (3/3) (valve sec.)​
HYDRAULIC PUMP (1/5)​
HYDRAULIC PUMP (2/5)​
HYDRAULIC PUMP (3/5)​
HYDRAULIC PUMP (4/5)​
HYDRAULIC PUMP (5/5)​
GEAR PUMP (2 blocks)​
GEAR PUMP (high flow)​
ENGINE V3800-CR-TIE4B-TLTU1 (HIGH FLOW)
OIL PAN​
OIL PAN​
DIPSTICK AND GUIDE​
DIPSTICK AND GUIDE​
CYLINDER HEAD​
CYLINDER HEAD​
INLET VALVE AND EXHAUST VALVE​
ROCKER ARM SHAFT​
ROCKER ARM SHAFT​
HEAD COVER​
HEAD COVER​
GEAR CASE​
GEAR CASE​
PISTON AND CRANKSHAFT​
CAMSHAFT AND IDLE GEAR SHAFT​
BEARING CASE COVER​
BEARING CASE COVER​
FLYWHEEL​
FLYWHEEL​
SUPPLY PUMP​
SUPPLY PUMP​
FUEL FILTER​
FUEL FILTER​
FUEL FILTER​
FUEL FILTER​
FUEL PIPE​
FUEL PIPE​
SEPARATOR​
SEPARATOR​
INJECTION PIPE​
INJECTION PIPE​
COMMON RAIL​
COMMON RAIL​
ALTERNATOR AND PULLEY​
ALTERNATOR (COMPONENT PARTS)​
STARTER​
STARTER​
STARTER (COMPONENT PARTS)​
SWITCH/SENSOR​
SWITCH/SENSOR​
INJECTOR HARNESS​
INJECTOR HARNESS​
WATER FLANGE AND THERMOSTAT​
WATER PUMP​
WATER PUMP​
RESERVE TANK​
RESERVE TANK​
FAN AND PULLEY​
FAN AND PULLEY​
INLET MANIFOLD​
INLET MANIFOLD​
AIR CLEANER FLANGE AND THROTTLE VALVE​
EXHAUST MANIFOLD​
EXHAUST MANIFOLD​
EGR VALVE​
EGR VALVE​
EGR COOLER​
EGR COOLER​
TURBO CHARGER​
TURBO CHARGER​
DIESEL PARTICULATE FILTER MUFFLER​
DPF MUFFLER (COMPONENT PARTS)​
DIESEL PARTICULATE FILTER MUFFLER [COMPONENT PARTS]​
DPF RECONDITIONED PROGRAM​
DPF Reconditioned Core Exchange Program​
DPF CLEANING PROGRAM​
DPF MUFFLER SENSOR​
DPF MUFFLER SENSOR​
DIFFERENTIAL PRESSURE PIPE​
BREATHER PIPE/SEPARATOR PIPE​
BREATHER PIPE/SEPARATOR PIPE (FOR CCV HEATER)​
Diagmaster [OPTION]​
OIL PIPE(TURBO CHARGER)​
ECU​
OIL SEPARATOR (FOR CCV HEATER)​
OIL SEPARATOR​
OIL SEPARATOR​
OIL PIPE (TURBO CHARGER)​
OIL COOLER​
OIL COOLER​
OIL FILTER​
OIL FILTER​
HYDARULIC PUMP​
HYDRAULIC PUMP​
ECU​
ECU​
ACCESSORIES AND SERVICE PARTS​
LABEL AND OPERATOR'S MANUAL​
PISTON KIT (OPTION)​
PISTON KIT [OPTION]​
DIAGMASTER (OPTION)​
ENGINE V3800-CR-TIE4B-TLTU2
CRANKCASE​
CRANKCASE​
DIPSTICK AND GUIDE​
DIPSTICK AND GUIDE​
CYLINDER HEAD​
CYLINDER HEAD​
ROCKER ARM SHAFT​
ROCKER ARM SHAFT​
HEAD COVER​
HEAD COVER​
GEAR CASE​
GEAR CASE​
BEARING CASE COVER​
BEARING CASE COVER​
FLYWHEEL​
FLYWHEEL​
SUPPLY PUMP​
SUPPLY PUMP​
FUEL FILTER​
FUEL FILTER​
FUEL FILTER​
FUEL FILTER​
FUEL PIPE​
FUEL PIPE​
SEPARATOR​
SEPARATOR​
INJECTION PIPE​
INJECTION PIPE​
COMMON RAIL​
COMMON RAIL​
STARTER​
STARTER​
SWITCH/SENSOR​
SWITCH/SENSOR​
INJECTOR HARNESS​
INJECTOR HARNESS​
WATER PUMP​
WATER PUMP​
RESERVE TANK​
RESERVE TANK​
FAN AND PULLEY​
FAN AND PULLEY​
INLET MANIFOLD​
INLET MANIFOLD​
EXHAUST MANIFOLD​
EXHAUST MANIFOLD​
EGR VALVE​
EGR VALVE​
EGR COOLER​
EGR COOLER​
TURBO CHARGER​
TURBO CHARGER​
DPF MUFFLER SENSOR​
DPF MUFFLER SENSOR​
OIL SEPARATOR​
OIL SEPARATOR​
OIL COOLER​
OIL COOLER​
OIL FILTER​
OIL FILTER​
ECU​
ECU​
KITS, ATTACHEMENTS & QUICK REFERENCE
BUCKETS​
TL12 WINTER KIT​
BLOCK HEATERS​
SERVICE BULLETIN(S)
SERVICE BULLETIN SB112213​
SERVICE BULLETIN SB112213 INSTALLATION INSTRUCTIONS​
SERVICE BULLETIN SB012714​
SERVICE BULLETIN SB012714 INSTALLATION INSTRUCTIONS​
SERVICE BULLETIN SB101514​
SERVICE BULLETIN SB101514 INSTALLATION INSTRUCTIONS​
INSTALLATION GUIDE CASE CONTROL KIT 200 SERIES​
INSTALLATION GUIDE TL230, TL240, TL250, TL8, TL10, TL12​
Appendix B:parts Index
Appendix A:pages Index
