Takeuchi Excavator TB260 Service Manual WETB260_B-XP
Brand: Takeuchi
Type of Machine: Excavator
Type of Manual: Service Manual, Electric and Hydraulic Diagram
Model: Takeuchi TB260 Excavator
Serial Number: 126100003-
Part Number: WETB260_B-XP
Book Number: CQ1E014
Number of Pages: 484 Pages
1 SAFETY
Brand: Takeuchi
1 SAFETY
Safety alert symbol
Safety precautions
Cautions when working
2 SERVICE DATADimensional drawing
Specification tables
Table of masses
Lubricant and fuel chart
Performance criteria
Standard values table
Hydraulic pump assignment table
Methods for inspecting performance
Tightening torque
Hydraulic hose
Bite-type pipe fitting for steel pipe
Joint for piping
Joint for piping (O-ring seal type)
Bolts and nuts (JIS strength category 10.9)
Hydraulic circuit diagram
Electrical circuit diagram
Electrical circuit diagram symbols
Electrical schematic diagram
Wire harness diagram
3 FUNCTIONPiston pump
Gear pump
Control valve
Pilot valve (control lever)
Pilot valve (swing)
Pilot valve (blade)
Pilot valve (travel)
Proportional control solenoid valve (1st/2nd auxiliary line piping)
Solenoid valve (Power Control)
Emergency shut-off valve
Solenoid valve(angle blade)
Selector valve
Cylinders
Travel motor
Slew motor
Swivel joint
4 DISASSEMBLY AND ASSEMBLYService standards
Drive system
Travel system
Slew equipment
Upper frame
Operating device
Hydraulic tank
Hydraulic pump
Control valve
Pilot valve(control lever)
Pilot valve (swing, blade)
Pilot valve (travel )
Solenoid valve (blade float)
Solenoid valve (angle blade)
Selector valve
Cylinders
Angle cylinder
Travel motor
Slew motor
Swivel joint (Equipped with angle blade)
5 TROUBLESHOOTINGAbout the troubleshooting section
Overall machine
Traveling
Slewing
Boom
Arm
Bucket
Boom swing
Blade
Auxiliary hydraulics
Angle blade
Piston pump
Gear pump
Control valve
Pilot valve
Solenoid valve
Cylinders
Travel motor
Slew motor
6 OtherMaintenance Software Manual
Contents
1. Outline
2. Connection methods
3. Description of functions
Air conditioner
[1] Product Overview
[2] Operating and Handling the Air Conditioner
[3] Construction, Operation and Control
[4] Inspection and Maintenance
[5] Refrigerant Charging
[6] Troubleshooting
Multi-information display
Lever switch pattern switching method
How to enable the aux4 function
Vehicle error codes
- Takeuchi Compact Excavator TB014-TB016 Workshop Manual
- Takeuchi TB125, TB135, TB145 owners manual
- Takeuchi 10.2014 Parts Manual
- Takeuchi TB15 Operator Manual
- Takeuchi Excavator TB228 TB235 TB250 Operator Manual
- TAKEUCHI EXCAVATOR TB016 Parts Manual
- TAKEUCHI EXCAVATOR TB23 R Parts Manual
- Takeuchi Crawler Loader TL10 Operator Manual
- Takeuchi TB014 and TB016 Workshop Manual
- Takeuchi Mini Excavator TB240 Operator Manual
- Takeuchi Track Loader TL120/TL130/TL140/TL150 AT7E023 Operators Manual
- Takeuchi TB260 A-XDE Mini Excavator Operator Manual
- Takeuchi TL 130 & 150 Stop Solenoid Circuit Wiring Diagram Manual
- TAKEUCHI EXCAVATOR TB216 Parts Manual
- Takeuchi TL 140 Engine Shut Down Circuit Wiring Diagram Manual
