Hyundai
86
176,684
Takeuchi Excavator TB260 Parts Manual P-TB260B-AN
Brand: Takeuchi
Type of Machine: Excavator
Model: Takeuchi TB260 Excavator
Serial No. 126100003~
Part Number: BQ1Z002-5-1 [P-TB260B-AN]
Number of Pages: 867 Pages
UNDERCARRIAGE
LOWER FRAME​
CENTER GUIDE (option)​
CRAWLER BELT (rubber)​
CRAWLER BELT (steel)​
CRAWLER BELT (segment rubber crawler)​
RUBBER PADS​
CRAWLER GUIDE (for steel crawler)​
CARRIER ROLLER​
TRACK ROLLER​
FRONT IDLER​
TRACK ADJUSTER​
TRAVEL DEVICE​
SLEW BEARING​
SWIVEL JOINT & ACCESSORIES​
SWIVEL JOINT & ACCESSORIES (angle blade type)​
DOZER BLADE​
DOZER BLADE (angle blade type)​
PIPING; LOWER​
PIPING; LOWER (angle blade type)​
PIPING; LOWER (with aux. line)​
TURNTABLE & CONTROL LEVER
SLEWING DEVICE​
TURNTABLE (cab)​
TURNTABLE (canopy)​
BOOM SWING​
SWING STOPPER​
TRAVEL LEVER & SWING PEDAL​
TRAVEL LEVER & SWING PEDAL (with travel alarm)​
DOZER BLADE LEVER​
DOZER BLADE LEVER (angle blade type) (cab)​
DOZER BLADE LEVER (angle blade type) (canopy)​
OPERATION LEVER & STAND (L.H.) (cab)​
OPERATION LEVER & STAND (R.H.) (cab)​
OPERATION LEVER & STAND (L.H.) (canopy) (126100003-126100563)​
OPERATION LEVER & STAND (L.H.) (canopy) (126100564-)​
OPERATION LEVER & STAND (R.H.) (canopy) (126100003-126100563)​
OPERATION LEVER & STAND (R.H.) (canopy) (126100564-)​
PIPING; OPERATION LEVER 1​
PIPING; OPERATION LEVER 2​
PIPING; OPERATION LEVER (A-G pattern) (cab) 1​
PIPING; OPERATION LEVER (A-G pattern) (cab) 2​
PIPING; OPERATION LEVER (A-G pattern) (canopy) 1​
PIPING; OPERATION LEVER (A-G pattern) (canopy) 2​
PIPING; OPERATION LEVER (A-G pattern) (without shut-off valve) 1​
PIPING; OPERATION LEVER (A-G pattern) (without shut-off valve) 2​
ENGINE & ELECTRICAL SYSTEM
ENGINE & ACCESSORIES (1/3) (cab) 126100003-126100075) 1​
ENGINE & ACCESSORIES (1/3) (cab; 126100003-126100075) 2​
ENGINE & ACCESSORIES (1/3) (cab) (126100076-) 1​
ENGINE & ACCESSORIES (1/3) (cab) (126100076-) 2​
ENGINE & ACCESSORIES (2/3) (cab)​
ENGINE & ACCESSORIES (1/3) (canopy) 1​
ENGINE & ACCESSORIES (1/3) (canopy) 2​
ENGINE & ACCESSORIES (2/3) (canopy)​
ENGINE & ACCESSORIES (3/3) (air cleaner)​
CONTROL BOX (R.H.) (cab)​
CONTROL BOX (R.H.) (canopy)​
CONTROL BOX (L.H.) (cab)​
CONTROL BOX (L.H.) (canopy)​
ELECTRICAL (with travel alarm) 1​
ELECTRICAL (with travel alarm) 2​
ELECTRICAL (with travel alarm) 3​
ELECTRICAL (with travel alarm) 4​
ELECTRICAL (canopy) 1​
ELECTRICAL (canopy) 2​
ELECTRICAL (canopy) 3​
ELECTRICAL (canopy) 4​
GPS DEVICE (cab)​
GPS DEVICE (canopy)​
BATTERY​
CAB LIGHT​
REAR LIGHT​
WINDOW WASHER​
RADIO​
HYDRAULIC PIPING & TANK
GREASE PIPING​
VALVE & ACCESSORIES (1/2) (3rd aux. line plug type) 1​
VALVE & ACCESSORIES (1/2) (3rd aux. line plug type) 2​
VALVE & ACCESSORIES (1/2) (3rd aux. line plug type & with auto tank) 1​
VALVE & ACCESSORIES (1/2) (3rd aux. line plug type & with auto tank) 2​
VALVE & ACCESSORIES (2/2) (3rd aux. line plug type)​
VALVE & ACCESSORIES (1/2) (with 3rd aux. line) 1​
VALVE & ACCESSORIES (1/2) (with 3rd aux. line) 2​
VALVE & ACCESSORIES (2/2) (with 3rd aux. line)​
VALVE & ACCESSORIES (1/2) (with 4th aux. line, auto tank & auto pressure release) 1​
VALVE & ACCESSORIES (1/2) (with 4th aux. line, auto tank & auto pressure release) 2​
VALVE & ACCESSORIES (2/2) (with 4th aux. line, auto tank & auto pressure release)​
VALVE & ACCESSORIES (1/2) (with blade float) 1​
VALVE & ACCESSORIES (1/2) (with blade float) 2​
VALVE & ACCESSORIES (2/2) (with blade float)​
VALVE & ACCESSORIES (1/2) (for angle blade) 1​
VALVE & ACCESSORIES (1/2) (for angle blade) 2​
VALVE & ACCESSORIES (2/2) (angle blade type)​
VALVE & ACCESSORIES (1/2) (angle blade type) (without shut-off valve) 1​
VALVE & ACCESSORIES (1/2) (angle blade type) (without shut-off valve) 2​
VALVE & ACCESSORIES (2/2) (angle blade type) (without shut-off valve)​
AUTO DECEL​
ACCUMULATOR​
PIPING; UPPER (3rd aux. line plug type) 1​
PIPING; UPPER (3rd aux. line plug type) 2​
PIPING; UPPER (3rd aux. line plug type) 3​
PIPING; UPPER (3rd aux. line plug type & with auto tank) 1​
PIPING; UPPER (3rd aux. line plug type & with auto tank) 2​
PIPING; UPPER (3rd aux. line plug type & with auto tank) 3​
PIPING; UPPER (with 3rd aux. line) 1​
PIPING; UPPER (with 3rd aux. line) 2​
PIPING; UPPER (with 3rd aux. line) 3​
PIPING; UPPER (with 3rd aux. line) 4​
PIPING; UPPER (with 4th aux. line, auto tank & auto pressure release) 1​
PIPING; UPPER (with 4th aux. line, auto tank & auto pressure release) 2​
PIPING; UPPER (with 4th aux. line, auto tank & auto pressure release) 3​
PIPING; UPPER (with 4th aux. line, auto tank & auto pressure release) 4​
PIPING; UPPER (with blade float) 1​
PIPING; UPPER (with blade float) 2​
PIPING; UPPER (with blade float) 3​
PIPING; UPPER (with blade float) 4​
PIPING; UPPER (angle blade type) 1​
PIPING; UPPER (angle blade type) 2​
PIPING; UPPER (angle blade type) 3​
PIPING; UPPER (angle blade type) 4​
PIPING; UPPER (angle blade type) (without shut-off valve) 1​
PIPING; UPPER (angle blade type) (without shut-off valve) 2​
PIPING; UPPER (angle blade type) (without shut-off valve) 3​
PIPING; UPPER (angle blade type) (without shut-off valve) 4​
PUMP DRIVE​
HYDRAULIC TANK (1/2)​
HYDRAULIC TANK (2/2)​
FUEL TANK & FUEL PIPING (1/2) (126100003-126100031) 1​
FUEL TANK & FUEL PIPING (1/2) (126100003-126100031) 2​
FUEL TANK & FUEL PIPING (2/2) (126100003-126100031)​
FUEL TANK & FUEL PIPING (1/2) (126100032-) 1​
FUEL TANK & FUEL PIPING (1/2) (126100032-) 2​
FUEL TANK & FUEL PIPING (2/2) (126100032-126100940)​
FUEL TANK & FUEL PIPING (2/2) (126100941-)​
FUEL TANK & FUEL PIPING (1/3) (with fuel supply pump) 1​
FUEL TANK & FUEL PIPING (1/3) (with fuel supply pump) 2​
FUEL TANK & FUEL PIPING (2/3) (with fuel supply pump) (126100003-126100940)​
FUEL TANK & FUEL PIPING (2/3) (with fuel supply pump) (126100941-)​
FUEL TANK & FUEL PIPING (3/3) (with fuel supply pump)​
COVER & CAB
COVER (1/3) (cab)​
COVER (2/3) (cab) (engine hood)​
COVER (1/3) (canopy)​
COVER (2/3) (canopy) (engine hood)​
COVER (3/3) (side cover)​
FLOOR FRAME (1/2) (cab) (126100003-126100081)​
FLOOR FRAME (2/2) (cab) (126100003-126100081)​
FLOOR FRAME (1/2) (cab) (126100082-)​
FLOOR FRAME (2/2) (cab) (126100082-)​
FLOOR FRAME (1/2) (canopy) (126100003-126100097)​
FLOOR FRAME (2/2) (canopy) (126100003-126100097)​
FLOOR FRAME (1/2) (canopy) (12610009:cool:​
FLOOR FRAME (2/2) (canopy) (12610009:cool:​
FLOOR MAT (cab)​
FLOOR MAT (cab) (with foot switch)​
FLOOR MAT (canopy)​
SEAT (1/2) (cab)​
SEAT (1/2) (canopy)​
SEAT (2/2) (cab) (126100003-126101887)​
SEAT (2/2) (canopy) (126100003-126101926)​
SEAT (2/2) (cab) (12610188:cool:​
SEAT (2/2) (canopy) (126101927-)​
CAB MOUNT​
CAB (1/4) 1​
CAB (1/4) 2​
CAB (1/4) 3​
CAB (1/4) 4​
CAB (2/4) (door)​
CAB (3/4) (front sash) (126100003-126100061)​
CAB (3/4) (front sash) (126100062-)​
CAB (4/4) (side sash)​
CAB INTERIOR 1​
CAB INTERIOR 2​
CAB INTERIOR (with auto tank switch) 1​
CAB INTERIOR (with auto tank switch) 2​
SWITCH​
CANOPY​
FRONT GUARD​
RAIN GUARD​
FRONT STAY​
REAR STAY​
ROOF GUARD​
AIR CONDITIONER (1/4) (compressor)​
AIR CONDITIONER (2/4) (condenser)​
AIR CONDITIONER (3/4) (air-conditioner unit-1) 1​
AIR CONDITIONER (3/4) (air-conditioner unit-1) 2​
AIR CONDITIONER (4/4) (air-conditioner unit-2)​
HOE ATTACHMENT
BOOM (1/4) (with shut-off valve + 2nd aux. line)​
BOOM (2/4) (with shut-off valve + 2nd aux. line)​
BOOM (1/4) (with boom shut-off valve + 2nd aux. line)​
BOOM (2/4) (with boom shut-off valve + 2nd aux. line)​
BOOM (1/4) (with shut-off valve + 3rd aux. line)​
BOOM (2/4) (with shut-off valve + 3rd aux. line)​
BOOM (1/4) (with shut-off valve + 4th aux. line)​
BOOM (2/4) (with shut-off valve + 4th aux. line)​
BOOM (3/4) (boom cylinder) (with shut-off valve)​
BOOM (4/4) (arm cylinder) (with shut-off valve)​
BOOM (4/4) (arm cylinder)​
ARM (1/2) (for U.S.) (long arm) (with 2nd aux. line)​
ARM (2/2) (for U.S.) (long arm) (with 2nd aux. line)​
DECAL & TOOL
DECAL (cab) (English, for U.S.) 1​
DECAL (cab) (English, for U.S.) 2​
DECAL (canopy) (English, for U.S.) 1​
DECAL (canopy) (English, for U.S.) 2​
DECAL (foot switch)​
DECAL (grip button) (cab)​
DECAL (grip button) (canopy)​
DECAL (breaker)​
DECAL (selector valve) (cab)​
DECAL (selector valve) (canopy)​
DECAL (selector valve) (A-B pattern)​
DECAL (angle blade) (cab)​
DECAL (angle blade) (canopy)​
TOOL & ACCESSORIES​
PAINTED COLOR (cab)​
PAINTED COLOR (cab) (for Sunbelt Rentals)​
PAINTED COLOR (canopy)​
PAINTED COLOR (canopy) (for Sunbelt Rentals)​
MAINTENANCE TOOL KIT​
GRIP PATTERN CHANGE KIT​
HYDRAULIC DEVICE
SWIVEL JOINT​
SWIVEL JOINT (angle blade type)​
CONTROL VALVE​
CONTROL VALVE (with 3rd aux. line)​
BLOCK ASSY; No. 1​
BLOCK ASSY; No. 2​
BLOCK ASSY; No. 3​
BLOCK ASSY; No. 5​
BLOCK ASSY; No. 6​
BLOCK ASSY; No. 7​
BLOCK ASSY; No. 8​
BLOCK ASSY; No. 9​
BLOCK ASSY; No. 10​
BLOCK ASSY; No. 10 (with 3rd aux. line)​
BLOCK ASSY; No. 11 (angle blade type)​
BLOCK ASSY; No. 11 (with 3rd aux. line)​
BLOCK ASSY; No. 12 (angle blade type)​
BLOCK ASSY; No. 12 (with 3rd aux. line)​
BLOCK ASSY; No. 13 (with 3rd aux. line)​
BLOCK ASSY; No. 14​
PILOT VALVE (R.H.) (3-switch type)​
PILOT VALVE (R.H.) (4-switch type)​
PILOT VALVE (L.H.) (3-switch type)​
HANDLE (3-switch type)​
HANDLE (4-switch type)​
SOLENOID VALVE; 1 BLOCK (with auto pressure release)​
SOLENOID VALVE; 1 BLOCK (with auto tank)​
SOLENOID VALVE; 1 BLOCK​
SOLENOID VALVE; 1 BLOCK (with 3rd aux. line)​
SOLENOID VALVE; 1 BLOCK (with 4th aux. line)​
SOLENOID VALVE; 2 BLOCKS (for angle blade)​
SOLENOID VALVE; 4 BLOCKS​
REMOTE CONTROL VALVE (travel)​
REMOTE CONTROL VALVE (swing)​
REMOTE CONTROL VALVE (dozer blade)​
REMOTE CONTROL VALVE (angle blade)​
SELECTOR VALVE (A-G pattern)​
SHUT-OFF VALVE (boom) (126100003-126102002)​
SHUT-OFF VALVE (boom) (126102003-)​
SHUT-OFF VALVE (arm) (126100003-126101991)​
SHUT-OFF VALVE (arm) (126101992-)​
BOOM CYLINDER​
ARM CYLINDER​
BUCKET CYLINDER​
SWING CYLINDER​
DOZER BLADE CYLINDER​
ANGLE BLADE CYLINDER​
TRAVEL MOTOR (1/3) (reduction sec.) (126100003-126101286)​
TRAVEL MOTOR (2/3) (motor sec.) (126100003-126101286)​
TRAVEL MOTOR (3/3) (valve sec.) (126100003-126101286)​
TRAVEL MOTOR (1/3) (reduction sec.) (126101287-)​
TRAVEL MOTOR (2/3) (motor sec.) (126101287-)​
TRAVEL MOTOR (3/3) (valve sec.) (126101287-)​
SLEW MOTOR (1/2) (reduction sec.)​
SLEW MOTOR (2/2) (motor sec.)​
HYDRAULIC PUMP (1/3) 1​
HYDRAULIC PUMP (2/3) 2​
HYDRAULIC PUMP (3/3) 3​
ENGINE - YANMAR 4TNV86CT-PTB (CAB) S/N 126100003-
CYLINDER BLOCK ASSY​
Fig.1 CYLINDER BLOCK​
GEAR HOUSING​
Fig.2 GEAR HOUSING​
FLYWHEEL HOUSING & OIL SUMP​
Fig.3 FLYWHEEL HOUSING & OIL SUMP​
CYLINDER HEAD & BONNET​
Fig.4 CYLINDER HEAD & BONNET​
SUCTION MANIFOLD​
Fig.5 SUCTION MANIFOLD​
EXHAUST MANIFOLD​
Fig.6 EXHAUST MANIFOLD​
DIESEL PARTICULATE FILTER (DPF)​
Fig.7 DIESEL PARTICULATE FILTER (DPF)​
DPF CLEANING PROGRAM REV 021418​
DPF CLEANING ORDER FORM - REV 021418​
CAMSHAFT & DRIVING GEAR​
Fig.8 CAMSHAFT & DRIVING GEAR​
TURBINE​
Fig.9 TURBINE​
CRANKSHAFT & PIST0N​
Fig.10 CRANKSHAFT & PISTON​
LUBE OIL SYSTEM​
Fig.11 LUB.OIL SYSTEM​
LUB OIL PIPE​
Fig.12 LUB.OIL PIPE​
COOLING WATER SYSTEM​
Fig.13 COOLING WATER SYSTEM​
FUEL SUPPLY PUMP​
Fig.14 FUEL SUPPLY PUMP​
FUEL INJECTION VALVE​
Fig.15 FUEL INJECTION VALVE​
FUEL PIPE​
Fig.16 FUEL PIPE​
STARTING MOTOR​
Fig.17 STARTING MOTOR​
GENERATOR​
Fig.18 GENERATOR​
ELECTRONIC CONTROL UNIT (ECU)​
Fig.19 ELECTRONIC CONTROL UNIT (ECU)​
ELECTRIC PARTS​
Fig.20 ELECTRIC PARTS​
GASKET SET​
Fig.21 GASKET SET​
ENGINE - YANMAR 4TNV86CT-PTB1 (CANOPY) S/N 126100003-
GEAR HOUSING​
Fig.2 GEAR HOUSING​
SUCTION MANIFOLD​
EXHAUST MANIFOLD​
TURBINE​
Fig.9 TURBINE​
LUBE OIL SYSTEM​
LUB OIL PIPE​
FUEL SUPPLY PUMP​
FUEL LINE​
Fig.16 FUEL PIPE​
STARTING MOTOR​
GENERATOR​
Fig.18 GENERATOR​
ELECTRIC PARTS​
GASKET SET​
Fig.21 GASKET SET​
KITS, ATTACHMENTS & QUICK REFERENCE
BLOCK HEATERS​
BUCKETS-BLADES-ATTACHMENTS (TB260)​
EXCAVATOR ATTACHMENT MOUNT QUICK REFERENCE GUIDE​
QUICK COUPLER (TB260)​
RECOMMENDED STOCK LIST (TB260)​
TAKEUCHI FLEET MANAGEMENT COMPONENT GUIDE​
TFM-FUSE DETAIL 11-18-16​
THUMBS (TB260)​
Appendix A:pages Index
Appendix B:parts Index
