Tadano Crane TT-300XL-1 Operation and Maintenance Manual TT-300XL-1_O1(U)-3E 2006
Brand: Tadano
Type of Machine: Truck Crane
Type of Manual: Operation and Maintenance Manual
Model: Tadano TT-300XL-1 Truck Crane
Specification Number: TT-300-1-90101, TT-300-1-90201
Serial Number: 291030~
Part Number: TT-300XL-1_O1(U)-3E
Publication Date: 2006
Number of Pages: 173 Pages
Safety A-1
Safety Rules A-2
Before Operation A-2
Rules for Operation (Setting Outriggers) A-7
Rules for Operation (General) A-8
Rules for Operation (Weather) A-17
Rules for Operation (Power Lines, Radio Waves)
A-18
Rules for Operation (Special Operation) A-20
After Operation A-20
Rules for Road Travel A-21
Rules for Parking A-23
Rules for Inspection and Maintenance A-24
Warning Labels A-29
Warning Labels - Location and Contents A-30
Contents 1
Preface 3
Servicing and Ordering Parts 4
Components 5
Layout of Controls 6
Terminology 8
[OPERATION]
Crane Operation Procedure – Summary 11
Preparatory Steps 11
During Operation 12
At the End of Operation 13
How to Read the Performance Data Plate 14
Load Radius/Lifting Height Chart 14
Rated Lifting Capacity Table 15
Load Moment Indicator (AML) 17
Configuration and Functions of the Load Moment
Indicator System 18
Controls 21
Names and Functions of Load Moment Indicator
Main Unit Parts 22
Selecting Operational Status 28
Load Moment Indicator Pre-operational Inspection
31
How to Use the Working Range Limit Function
32
Display Alteration 35
Recovery from a Stop 36
Abonrmality Messages
and Recovering Operations 39
In the Event of a System Failure 41
Other Safety Devices 43
Anti-twoblock Device 43
Front jack Overload Warning Device 44
Accumulator Low Pressure Warning Device 44
External Warning Lamps (Option) 45
Operating the PTO and Warming Up the Machine
46
Operating the PTO 46
Warming Up the Machine 46
Checks to Make during Warmup 46
Outriggers 47
Setting the Crane 47
Controls 47
Extending the Outriggers 48
Level Adjustment 50
Front Jack 51
Stowing the Outriggers 52
Crane Operator's Cab 53
Opening and Closing the Door 53
Adjusting Seat Position 54
Adjusting Length of Control Levers 54
Upperstructure Power Supply 55
Controls 55
Acceleration 56
Controls 56
Hoisting 57
Controls 57
Hoisting Up and Down 58
Other Winch-related Control and Devices 59
Telescoping the Boom 60
Controls 60
Extending and Retracting the Boom 60
Emergency Telescoping Procedure 62
Elevating the Boom 63
Controls 63
Raising and Lowering the Boom 63
Swinging the Boom 64
Controls 64
Reeving Wire Rope 66
Standard Number of Parts of line 66
Reeving Procedure 67
Jib 68
Components 68
Jib Lift 69
Mounting the Jib 70
Contents
T060140E
Contents 1 Contents
TT-300XL-1/O1(U)-3EChanging the Jib Offset Angle
Stowing the Jib
Equipment Inside the Cab
Heater (Option)
Other Equipment Inside the Cab
Equipment outside the Cab
Winch Drum Monitor Mirror (Option)
Oil cooler (Option)
[INSPECTION AND
Pre-Operational and Periodic Inspection
Safety Parts Requiring Regular Replacement
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch Speed Reducer Oil Level Check
Winch Speed Reducer Oil Replacement
Swing Speed Reducer Oil Replacement
Maintenance Table
Oil Level Check (Hydraulic Oil Tank)
Oil Replacement (Hydraulic Oil Tank)
Oil Level Check (Oil Reservoir)
Oil Replacement (Oil Reservoir)
Air Breather Replacement (Hydraulic
Return Filter Replacement (Hydraulic
Return Filter Replacement (Drain Circuit)
Line Filter Replacement (Accumulator Circuit)
Line Filter Replacement (Winch
Line Filter Replacement (Automatic
Swing System
Maintenance Table
Swing Brake Bleeding
Swing Bearing Mounting Bolt Check
Winch System
Maintenance Table
Winch Brake for Wear Check
Winch Brake Adjustment
Brake Cylinder Bleeding
Brand: Tadano
Safety A-1
Safety Rules A-2
A-18
Warning Labels A-29
Contents 1
Preface 3
Components 5
Terminology 8
[OPERATION]
During Operation 12
Indicator System 18
Controls 21
Main Unit Parts 22
31
32
46
Outriggers 47
Controls 47
Level Adjustment 50
Front Jack 51
Controls 55
Acceleration 56
Controls 56
Hoisting 57
Controls 57
Controls 60
Controls 63
Controls 64
Jib 68
Components 68
Jib Lift 69
Mounting the Jib 70
Contents
T060140E
Contents 1 Contents
Stowing the Jib
Heater (Option)
Oil cooler (Option)
[INSPECTION AND
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Maintenance Table
Swing System
Maintenance Table
Winch System
Maintenance Table
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
