Tadano Crane TM-ZX1200 TM-ZX1000 Series Operation Manual TM-ZX1200-1_OM1-12E 2022
Brand: Tadano
Type of Machine: Cargo Crane
Model: Tadano TM-ZX1200 Series, TM-ZX1000 Series Cargo Crane
Applicable Model: 5-sectioned boom TM-ZX1005-1, TM-ZX1205-1
Serial Number: KZ1006– (TM-ZX1000-1), LZ0001– (TM-ZX1200-1)
Part Number: TM-ZX1200-1_OM1-12E
Publication Date: 2022
Number of Pages: 291 Pages
Introduction
Warranty
Model Name and Specification
Maintenance and Inspection
In Event of Failure
Taking Machine Out of Country of Purchase
Contents
Name of Each Part
Name of Each Part
Control Levers
Panel switch
Transmitter
Communication Unit
Safety Rules
Before Operation
Rules for Operation
Rules for Using Radio Controller
Rules for Traveling on Roads
Warning Labels
Warning Labels - Location and Contents
Operation
Terminology
How to Read Performance Data Table
Working Range Chart
How to Read Rated Lifting Capacity Table
Reading Working Range Chart (Basket mode)
Safety Device
Anti-Two-Block Device
AML (Automatic Moment Limiter)
Working Height Limit Function
Alarm Function
Angle Indicator
Peripheral Speed Control
Operation Speed Limit
Safety Latch
Spirit Level
TM-ZX1200-1_OM1-12EContents 5
Jack Interlock
Emergency Stop Switch
Safety Function for Radio Controller
Stop Operation
Automatic Power OFF Function
Switch Failure Detection Function
Zooming in Load Indication (Only for crane mode)
Receiving Condition Alarm Function
Before Crane Operation
Check before Traveling
Checking the Ground
Starting the Hydraulic Pump
How to Start the Hydraulic Pump
Warm-up Operation in Cold Season
Pre-operational Inspection
Setting Up the Outriggers
How to Set Up Outriggers
Setting Up Rear Outriggers (Option)
Taking Out the Hook Block
Checking Registered Number of Parts of Line
Operation from Crane Body
Operation from Transmitter
Reeving Wire Rope
Number of Parts of Line/Over-unwinding Cutout Function
Reeving Procedure
Registering Number of Parts of Line
Before Basket Operation
Basket Mounting Conditions
Securing Wire Rope (Removing Hook Block)
Basket Mode
Check before Basket Operation
How to Handle the Radio Controller
Switching from Manual Operation to Radio Control Operation
Basic Operation
Switching to Manual Operation
Stopping Radio Wave Transmission for Radio Control
TM-ZX1200-1_OM1-12E6 Contents
Other Functions of the Crane Body
Automatic Acceleration
Manual Acceleration
Acceleration Limit Function
Horn Switch
Volume
Hour Meter
Oil Cooler (option)
Other Functions of the Radio Controller
Speed Mode
Backlight
Volume
Load Weight
"Feeling Operation" Function
Telescoping Boom
Operation from Manual Levers
Hoisting Up and Down
Elevating the Boom
Boom Slewing
Stowing the Boom
Retracting Outriggers
Retracting Rear Outriggers (option)
Stopping the Hydraulic Pump
How to Stop the Hydraulic Pump
Checking the Traveling Configuration
Inspection and Maintenance
TM-ZX1200-1_OM1-12EContents 7
Precautions for Inspection and Maintenance
Periodic Replacement Parts
Inspection and Maintenance Interval
Crane Body
Radio Controller
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch speed reducer
Slewing Speed Reducer
Maintenance Table
Hydraulic Oil Tank
Air Breather
Return Filter
Telescoping System
Maintenance Table
Wire Rope for Boom Telescoping
Slewing and Winch Systems
Maintenance Table
Slewing Bearing Mounting Bolt, Slewing Speed Reducer Mounting Bolt
Winch Speed Reducer Facing
Replacement of Battery
Frame
Maintenance Table
Crane Body Mounting Bolts and Nuts
Wire Rope
Replacing the Wire Rope
Handling the Wire Rope
TM-ZX1200-1_OM1-12E8 Contents
Action Against Emergency
When Radio Communication Is Not Normal
When the Machine Cannot Be Operated by the Transmitter
When an Error Occurs in the Anti-Two-Block Device
When an Error Code is Displayed
If the Machine Cannot be Operated by the Transmitter and Manual Levers
How To Cancel the AML (AML: Rated Capacity Indicator/Limiter specification)
Information and Data
Conversion Tables
Hand Signals
Major Specifications
TM-ZX1000 series
TM-ZX1200 series
Oils and Greases
Oils and Greases Table
Recommended Oils and Greases
Certification Label
Brand: Tadano
Introduction
Warranty
In Event of Failure
Contents
Name of Each Part
Name of Each Part
Control Levers
Panel switch
Transmitter
Communication Unit
Safety Rules
Before Operation
Rules for Operation
Warning Labels
Operation
Terminology
Working Range Chart
Safety Device
Alarm Function
Angle Indicator
Safety Latch
Spirit Level
Jack Interlock
Stop Operation
Checking the Ground
Reeving Wire Rope
Reeving Procedure
Basket Mode
Basic Operation
Manual Acceleration
Horn Switch
Volume
Hour Meter
Oil Cooler (option)
Speed Mode
Backlight
Volume
Load Weight
Telescoping Boom
Elevating the Boom
Boom Slewing
Stowing the Boom
Crane Body
Radio Controller
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch speed reducer
Maintenance Table
Hydraulic Oil Tank
Air Breather
Return Filter
Telescoping System
Maintenance Table
Maintenance Table
Frame
Maintenance Table
Wire Rope
Conversion Tables
Hand Signals
TM-ZX1000 series
TM-ZX1200 series
Oils and Greases
Certification Label
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
