Momed80
150
35,046
Tadano Crane TM-ZX1200 Series Operation Manual TM-ZX1200-1_OM2-21E 2024
Brand: Tadano
Type of Machine: Cargo Crane
Model: Tadano TM-ZX1200 Series Cargo Crane
Applicable Model: TM-ZX1200-1, 5-sectioned boom TM-ZX1205-1
Serial Number: LZ0100–
Part Number: TM-ZX1200-1_OM2-21E
Publication Date: 2024
Number of Pages: 181 Pages
Introduction
Warranty
Model Name and Specification
Maintenance and Inspection
In Event of Failure
Taking Machine Out of Country of Purchase
Contents
Name of Each Part
Name of Each Part
Control Levers
Safety Rules
Before Operation
Rules for Operation
Rules for Traveling on Roads
Warning Labels
Warning Labels - Location and Contents
Operation
Terminology
How to Read Performance Data Table
Working Range Chart
How to Read Rated Lifting Capacity Table
Safety Device
Anti-two-block device
Load Indicator
Load Meter
Safety Latch
Spirit Level
Before Crane Operation
Check before Traveling
Checking the Ground
Starting the Hydraulic Pump
How to Start the Hydraulic Pump
Warm-up Operation in Cold Season
Pre-operational Inspection
Setting Up the Outriggers
TM-ZX1200-1_OM2-21EContents 5
How to Set Up Outriggers
Setting Up Rear Outriggers (Option)
Taking Out the Hook Block
Reeving Wire Rope
Number of Parts of Line
Reeving Procedure
Other Functions of the Crane Body
Automatic Acceleration
Manual Acceleration
Horn Switch
Oil Cooler (option)
Telescoping Boom
Hoisting Up and Down
Elevating the Boom
Boom Slewing
Stowing the Boom
Retracting Outriggers
Retracting Rear Outriggers (option)
Stopping the Hydraulic Pump
How to Stop the Hydraulic Pump
Checking the Traveling Configuration
Inspection and Maintenance
Precautions for Inspection and Maintenance
Periodic Replacement Parts
Inspection and Maintenance Interval
Crane Body
Greasing
Maintenance Table
Greasing Chart
TM-ZX1200-1_OM2-21E6 Contents
Gear Oil
Maintenance Table
Winch speed reducer
Slewing Speed Reducer
Maintenance Table
Hydraulic Oil Tank
Air Breather
Return Filter
Telescoping System
Maintenance Table
Wire Rope for Boom Telescoping
Slewing and Winch Systems
Maintenance Table
Slewing Bearing Mounting Bolt, Slewing Speed Reducer Mounting Bolt
Winch Speed Reducer Facing
Frame
Maintenance Table
Crane Body Mounting Bolts and Nuts
Wire Rope
Replacing the Wire Rope
Handling the Wire Rope
Action Against Emergency
When an Error Occurs in the Anti-Two-Block Device
When Machine Does Not Operate
Information and Data
Conversion Tables
Hand Signals
Major Specifications
TM-ZX1200 series
Oils and Greases
Oils and Greases Table
Recommended Oils and Greases
