Momed80
150
35,046
Tadano Crane TL-350E-3 Operation and Maintenance Manual TL-350E-3_O4-1EJ EN JP
Language: Japanese, English
Brand: Tadano
Type of Machine: Truck Crane
Type of Manual: Operation and Maintenance Manual
Model: Tadano TL-350E-3 Truck Crane
Applicable Specification: TL-350E-3-20303
Applicable Serial: 355838~
Part Number: TL-350E-3_O4-1EJ
Publication Date: 1999
Number of Pages: 284 Pages
Safety
Safety Rules
Before Operation
Rules for Operation (Setting Outriggers)
Rules for Operation (General)
Rules for Operation (Weather)
Rules for Operation (Power Lines, Radio Waves)
Rules for Operation (Special Operation)
After Operation
Rules for Road Travel
Rules for Inspection and Maintenance
Warning Labels
Warning Labels-Location and Contents
Contents
Preface
Servicing and Ordering Parts
Directional Terms
Components
Layout of Controls
Crane Operator's Cab
Terminology
[OPERATION]
Crane Operation Procedure-Summary
Preparatory Steps
During Operation
At the End of Operation
How to Read Performance Data Plate
Working Range & Lifting Height Chart
Rated Lifting Capacity Table
AML (Overload Prevention Device)
Configuration and Functions of the AML System
Controls
Names and Functions of AML Main Unit Parts
Registering Operational Status
AML Pre-operational Inspection
How to Use the Working Range Restricting Function
Display Alteration
Recovery from an Automatic Stop
Display and Disposition of Failure Messages
Disposition of System Troubles
Other Safety Devices
Overwind Cutout Device
Front Jack Overload Warming Device
Accumulator Low Pressure Warning Device
Over-unwinding Cutout Device
Starting and Stopping the Engine
Control
Pre-starting Checks
Starting the Engine
Stopping the Engine
Operating the PTO and Warming Up the Machine
Operating the PTO
Checks to Make during Warm-up
Outriggers
Setting the Crane
Extending the Outriggers
Level Adjustments
Front Jack
Stowing the Outriggers
Opening and Closing the Door
Adjusting Seat Position
Adjusting Length of Control Levers
Acceleration
Hoisting
Hoisting Up and Down
Other Winch-related Controls and Devices
Telescoping the Boom
Extending and Retracting the Boom
Emergency Telescoping Procedure
Elevating the Boom
Raising and Lowering the Boom
Swinging the Boom
Taking Out and Stowing the Main Hook Block
Taking Out Main Hook Block
Stowing Main Hook Block
Reeving Wire Rope
Standard Number of Parts of Line
Reeving Procedure
Single Top
Single Top Lift
Mounting the Single Top
Stowing the Single Top
Jib
Jib Lift
Mounting the Jib
Changing the Jib Offset Angle
Changing the Jib Length
Stowing the Jib
Equipment Inside the Cab
Heater (option)
Other Equipment Inside the Cab
Equipment Outside the Cab
Oil Cooler (option)
Oil Temperature Gauge (option)
[INSPECTION AND MAINTENANCE]
Pre-Operational and Periodic Inspection
Safety Parts Requiring Regular Replacement
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Winch Speed Reducer Oil Level Check
Winch Speed Reducer Oil Replacement
Swing Speed Reducer Oil Replacement
Oil Level Check (Hydraulic Oil Tank)
Oil Replacement (Hydraulic Oil Tank)
Oil Level Check (Oil Reservoir)
Oil Replacement (Oil Reservoir)
Return Filter (Hydraulic Oil Tank)
Return Filter (Inside Swing Table)
Air Breather (Hydraulic Oil Tank)
Line Filter (Winch Brake Circuit)
Line Filter (Automatic Stop Circuit)
Line Filter (Boom Telescoping Circuit)
Line Filter (Accumulator Circuit)
Swing System
Swing Brake Bleeding
Swing Bearing Mounting Bolt Check
Winch System
Winch Brake for Wear Check
Winch Brake Adjustment
Brake Cylinder Bleeding
Accelerator System
Accelerator Circuit Bleeding
Fuses Replacement
Wire Ropes
Proper Handling of Wire Ropes
Wire Rope Replacement
[INFORMATION AND DATA]
Conversion.
Major Specifications
Crane Specifications
Overall Dimensions
Mass
Relief Valve Pressure
Wire Rope Specifications
Other
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Consumable Parts
Filters
Fuses
