Momed80
150
35,046
Tadano Crane TL-350E-3 Operation and Maintenance Manual TL-350E-3_O1-1EJ EN JP
Language: Japanese, English
Brand: Tadano
Type of Machine: Hydraulic Truck Crane
Type of Manual: Operation and Maintenance Manual
Model: Tadano TL-350E-3 Hydraulic Truck Crane
Applicable Specification: TL-350E-3-20101
Applicable Serial: 355320~
Part Number: TL-350E-3_O1-1EJ
Publication Date: 2000
Number of Pages: 239 Pages
Safety
Safety Rules
Contents
Preface
Servicing and Ordering Parts
Directional Terms
Components
Layout Of Controls
Crane Operator's Cab
Terminology
[OPERATION]
Crane Operation Procedure-Summary
Preparatory Steps
During Operation
At the End of Operation
How to Read Performance Data Plate
Working Radius / Lifting Height Chart
Total Rated Load Table
AML (Overload Prevention Device)
Configuration and Functions of AML System
Controls
Selecting Operational Status
AML Pre-operational Inspection
How to Use Working Range Limit Function
Recovery from an Automatic Stop
In the Event of AML Failure
Other Safety Devices
Overwind Cutout Device
Front Jack Overload Warning Device
Accumulator Low Pressure Warning Device
Over-unwinding Cutout Device
Starting and Stopping the Engine
Pre-starting Checks
Starting the Engine
Stopping the Engine
Operating the PTO and Warming Up
the Machine
Operating the PTO
Warming Up the Machine
Checks to Make during Warm-up
Outriggers
Placing the Crane
Extending Outriggers
Lebel Adjustment
Front Jack
Stowing the Outriggers
Opening and Closing the Door
Adjusting Seat Position
Adjusting Length of Control Levers
Acceleration
Hoisting
Hoisting Up and Down
Other Winch-related Controls and Devices
Telescoping the Boom
Extending and Retracting the Boom
Emergency Telescoping Procedure
Elevating the Boom
Raising and Lowering the Boom
Swinging the Boom
Taking Out and Stowing
the Main Hook Block
Taking Out Main Hook Block
Stowing Main Hook Block
Reeving Wire Rope
Standard Number of Parts of Line
Reeving Procedure
Single Top
Single Top Lift
Mounting Single Top
Stowing Single Top
Jib
Jib Lift
Mounting Jib
Changing Jib Offset Angle
Changing Jib Length
Stowing Jib
Equipment Inside Cab
Heater(option)
Other Equipment Inside Cab
Equipment Outside Cab
Oil Cooler(option)
[INSPECTION AND MAINTENANCE]
Inspection and Maintenance
Pre-operational and Periodic Inspection
Maintenance
Greasing
Gear Oil
Swing System
Winch System
Accelerator System
Electrial System
Wire Ropes
Proper Handling of Wire Ropes
Wire Rope Replacement
[INFORMATION AND DATA]
Major Specifications
Crane Specifications
Overall Dimensions
Weight
Relief Valve Pressure
Wire Rope Specifications
Other
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Consumable Parts
Filters
Fuses
