Tadano Crane TL-300E-3 Operation and Maintenance Manual TL-300E-3_O2-2EJ EN JP
Language: Japanese, English
Brand: Tadano
Type of Machine: Truck Crane
Type of Manual: Operation and Maintenance Manual
Model: Tadano TL-300E-3 Truck Crane
Applicable Specification: TL-300E-3-00107
Applicable Serial: 355977~
Part Number: TL-300E-3_O2-2EJ
Publication Date: 2008
Number of Pages: 299 Pages
Safety
Safety Rules
Before Operation
Rules for Operation (Setting Outriggers)
Rules for Operation (General)
Rules for Operation (Weather)
Rules for Operation (Power Lines, Radio Waves)
Rules for Operation (Special Operation)
After Operation
Rules for Road Travel
Rules for inspection and Maintenance
Warning Labels
Warning Labels-Location and Contents
Contents
Preface
Servicing and Ordering Parts
Components
Layout Of Controls
Crane Operator’s Cab
Terminology
OPERATION
Crane Operation Procedure-Summary
Preparatory Steps
During Operation
At the End of Operation
How to Read Performance Data Plate
Working Radius & Lifting Height Chart
Rated Lifting Capacity Table
AML (Overload Prevention Device)
Configuration and Functions of the AML System
Controls
Names and Functions of the AML Main Unit Parts
Registering Operational Status
AML Pre-operational Inspection
How to Use the Working Range Restriction Function
Display Alteration
Recovery from an Automatic Stop
Display and Disposition of Failure Messages
Disposition of System Troubles
Other Safety Devices
Overwind Cutout Device
Front Jack Overload Warning Device
Accumulator Low Pressure Warning Device
External Warning Lamps (option)
Starting and Stopping the Engine
Controls
Pre-starting Checks
Starting the Engine
Stopping the Engine
Operating the PTO and Warming Up the Machine
Operating the PTO
Outriggers
Setting the Crane
Controls
Extending the Outriggers
Level Adjustments
Front Jack
Stowing the Outriggers
Opening and Closing the Door
Adjusting Seat Position
Adjusting Length of Control Levers
Acceleration
Controls
Hoisting
Controls
Hoisting Up and Down
Free-fall operation
Other Winch-related Controls and Devices
Telescoping the Boom
Controls
Extending and Retracting the Boom
Emergency Telescoping Procedure
Elevating the Boom
Controls
Raising and Lowering the Boom
Swinging the Boom
Controls
Swinging the Boom
Taking Out and Stowing the Main Hook Block
Taking Out the Main Hook Block
Reeving Wire Rope
Standard Number of Parts of Line
Reeving Procedure
Single Top
Components
Single Top Lift
Mounting the Single Top
Stowing the Single Top
Jib
Components
Jib Lift
Mounting the Jib
Changing the Jib Offset Angle
Changing the Jib Length
Stowing the Jib
Equipment Inside the Cab
Heater (option)
Cooler (option)
Other Equipment Inside the Cab
Equipment Outside the Cab
Oil Cooler (option)
Winch Drum Monitor Mirror (option)
INSPECTION AND MAINTENANCE
Inspection and Maintenance
Pre-operational and Periodic Inspection
Safety Parts Requiring Regular Replacement
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch Speed Reducer Oil Level Check
Winch Speed Reducer Oil Replacement
Swing Speed Reducer Oil Replacement
Maintenance Table
Oil Level Check (Hydraulic Oil Tank)
Oil Replacement (Hydraulic Oil Tank)
Oil Level Check (Oil Reservoir)
Oil Replacement (Oil Reservoir)
Return Filter Replacement (Hydraulic Oil Tank)
Air Breather Replacement (Hydraulic Oil Tank)
Line Filter Replacement (Winch Clutch Circuit)
Line Filter Replacement (Winch Brake Circuit)
Line Filter Replacement (Automatic Stop Circuit)
Line Filter Replacement (Accumulator Circuit)
Swing System
Maintenance Table
Swing Brake Bleeding
Swing Bearing Mounting Bolt Check
Winch System
Maintenance Table
Winch Brake for Wear Check
Winch Brake Adjustment
Brake Cylinder 1 Bleeding
Brake Cylinder 2 Bleeding
Winch Clutch Circuit Bleeding
Winch Clutch Adjustment
Accelerator System
Maintenance Table
Accelerator Circuit Bleeding
Maintenance Table
Fuses Replacement
Wire Ropes
Proper Handling of Wire Ropes
Wire Rope Replacement
INFORMATION AND DATA
Conversion
Major Specifications
Crane Specifications
Overall Dimensions
Mass
Relief Valve Pressure
Wire Rope Specifications
Other
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Consumable Parts
Filters
Fuses
Brand: Tadano
Safety
Safety Rules
Before Operation
After Operation
Warning Labels
Contents
Preface
Components
Layout Of Controls
Terminology
OPERATION
Preparatory Steps
During Operation
Controls
Display Alteration
Controls
Pre-starting Checks
Starting the Engine
Stopping the Engine
Operating the PTO
Outriggers
Setting the Crane
Controls
Level Adjustments
Front Jack
Acceleration
Controls
Hoisting
Controls
Free-fall operation
Controls
Elevating the Boom
Controls
Swinging the Boom
Controls
Swinging the Boom
Reeving Wire Rope
Reeving Procedure
Single Top
Components
Single Top Lift
Jib
Components
Jib Lift
Mounting the Jib
Stowing the Jib
Heater (option)
Cooler (option)
Oil Cooler (option)
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Maintenance Table
Swing System
Maintenance Table
Winch System
Maintenance Table
Accelerator System
Maintenance Table
Maintenance Table
Fuses Replacement
Wire Ropes
Conversion
Overall Dimensions
Mass
Other
Oils and Greases
Consumable Parts
Filters
Fuses
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
