Momed80
150
35,046
Tadano Crane RTF160-5 Operation Manual RTF160-5_O1-3E 2015
Brand: Tadano
Type of Machine: Crane Carrier
Model: Tadano RTF160-5 Crane Carrier
Applicable Model: AR-1600M-1
Serial Number: WFN5KFHN2P4012001, WFN5KFHN2R4016001–
Part Number: RTF160-5_O1-3E
Publication Date: 2015
Number of Pages: 142 Pages
Safety
Safety Rules
Before Traveling
Rules for Traveling
Rules for Traveling on Slope
Rules for Stopping and Parking
Rules for Inspection and Maintenance
Warning Labels
Label Location and Content of Warnings
Contents
Preface
Conversion Table
Qualifications Required for Driving (Applicable
Japan)
Servicing and Ordering Parts
Indications of Front, Rear, Left, and Right
Components
Layout of Controls
In Cab
Dashboard (Meters, Buzzers, and Switches)
Dashboard (Lamps)
Reference Page List
[TRAVELING
Vehicle Traveling Procedure
Preparations before Driving Off
Starting
Traveling
Stopping
Parking
Vehicle Operator's Cab
Adjusting Seat and Seatbelt
Adjusting Steering Wheel
How to Read Meter Panel
Meters
Lamps and Buzzers
Starting and Stopping the Engine
Control Devices
How to Start Engine
How to Stop Engine
Operating Differential Lock
Control Devices
Transfer Low Speed Traveling Operation
Control Devices
Selecting Speed Range
Control Devices
Operating Brake
Control Devices
Operating Foot Brake
Operating Retarder
Operating Parking Brake
Operating Steering
Control Devices
Operating Steering
Operating All-wheel Steering
Operating Suspension
Control Devices
Selecting Suspension Mode
Suspension Lock Operation
Vehicle Leveling Operation
Vehicle Inclination Adjustment (Vehicle
Adjustment)
Operating Lighting Switch and Others
Control Devices
How to Use Tachograph
Control Devices
Handling Recording Chart
Opening/Closing Main Unit
Setting Recording Chart
Removing Recording Chart
Actions at Driver Change and When
Vehicle
Adjusting Clock
Traveling Speed Warning
Failure Diagnosis Function
Replacing Light Bulb
How to Use Equipment Inside Cab
How to Use Air Conditioner
Radio
Rear View Monitor
How to Use Other Equipment
Action against Emergency
When Failure Occurs
Towing
When Battery Becomes Exhausted
FOR REFERENCE ONLYContents[INSPECTION AND MAINTENANCE
General Instructions
Pre-operational Inspection and
Inspection
Maintenance Table
Inspection of Coolant in Radiator Reservoir
Replacement of Engine Oil
Air Cleaner
Maintenance Table
Cleaning of Air Cleaner Housing
Removal and Installation of Filter Element
Cleaning of Filter Element
Cleaning of Rain Cap of Air Cleaner
Inspection of Air Intake Pipes and Hoses
Maintenance Table
Oil Level Check
Replacement of Oil and Filters
Drop Box
Maintenance Table
Oil Level Check
Oil Replacement
Transfer Box
Maintenance Table
Oil Level Check
Oil Replacement
Pump Transfer Box
Maintenance Table
Oil Level Check
Oil Replacement
Maintenance Table
Oil Level Check for Differentials and
Hubs
Oil Replacement for Differential and Wheel
Oil Level Check for 4th Inter Axle Differential
Oil Replacement for 4th Inter Axle Differential
Visual Check for Leakage and Functional Check
Check of Axle and Wheel Hub and
Replacement for Wheel Hub
Check of Axle, Steering Lever, and Thrust Rod
Installation Status
Maintenance of Axles and Wheel Hubs
Propeller Shafts
Maintenance Table
Greasing of Propeller Shafts
Check of Backlash in Propeller Shafts
Check of Propeller Shaft Noise
Breather
Maintenance Table
Cleaning and Check of Breather (Vent Hole)
Transmission and Axle
Maintenance Table
Check of Oil Level in Hydraulic Oil Tank
Replacement of Oil Filter (Hydraulic Oil Filter)
Replacement of Air Breather Cap
Element)
Replacement of Hydraulic Oil
Maintenance Table
Oil Level Check of Miter Gear
Suspension System
Maintenance Table
Function Check and Oil Leakage Check
Suspension System
Check of Gas Pressure in Hydraulic
of Suspension System
Maintenance Table
Check of Air Tank Drain Valve
Function Check of Air Dryer
Replacement of Air Dryer Desiccant Cartridge
Brake Cylinders
Check of Wheel Brake
Maintenance of Wheel Brake
Electrical Equipment
Maintenance Table
Battery
Starter
Lamps and Lights
Fuse
Relay Arrangement
FOR REFERENCE ONLYContentsWheels and Tires
Maintenance Table
Check of Wheels for Accident Prevention
Check of Wheel Nuts for Tight Fit
Tire Air Pressure
Tire Inflator
Tire Rotation (Position Change)
Automatic Centralized Lubrication System
Maintenance Table
Refilling Grease Reservoir Tank
Setting Operating Time of Oil Filling Pump
Control Unit
Malfunction Indicator and Functional Check
Maintenance of Centralized Lubrication System.
Air Conditioner
Maintenance Table
Operation Check
Check of Gas Level and Gas Leakage
Cleaning of Condenser
Check of Evaporator (with Blower Fan)
Check of Air Conditioner Compressor V-belt
Check of Oil Level in Air Conditioner
Maintenance Diagram
Inspection and Cleaning Diagram
Oil Level Check and Oil Replacement Diagram
Lubrication Schedule – Nipple Greasing Points
[INFORMATION AND DATA
Major Specifications
General Technical Details
Technical Details
Oils and Greases
Oils and Greases Table
Recommended Oils and Greases
