Tadano Crane GT-300ER Operation Manual GT-300ER-3(C)_OM2-14E 2025
Brand: Tadano
Type of Machine: Crane Carrier
Model: Tadano GT-300ER Crane Carrier
Applicable Model: GT-300ER-3
Applicable Specification: GT-300E-3-01201
Serial Number: 430681–
Part Number: GT-300ER-3(C)_OM2-14E
Publication Date: 2025
Number of Pages: 233 Pages
Introduction
Warranty
Maintenance and Inspection
In Event of Failure
Before Using Crane Out of Country of Purchase
(Including Satellite/Mobile Communication
Terminal)
For Safety
Contents
Name of Each Part
Contents with Illustrations
Traveling System
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Check of Traveling Configuration
Status of Traveling Controls
Inspection before Traveling
Entering Cab
Opening/Closing Door
Adjustment of Seat
(For serial No.430688 or later)
Adjustment of Seat (For up to serial No.430687).
Adjustment of Steering Wheel
Opening/Closing Window
Adjustment of Mirrors
Fastening/Unfastening Seat Belt
Sunshade
Reading Instrument Panel
Meters and Gauges
Warning Sign
Error Codes Shown on MFD
Starting and Stopping Engine
Control System
How to Start Engine
Adjustment of Idle Speed
How to Stop Engine
Transmission Operation
Operations of Gearshift Switch and Shift Lever
Shift Operation
Selecting Low Speed Mode
Brake Operation
Foot Brake Operation
Parking Brake Operation
Operating Exhaust Brake
Steering Operation
Differential Lock Operation
(inter-axle differential lock)
Releasing Differential Lock
(Inter-wheel Differential Lock)
Cruise Control Operation
Setting Cruise Control
Canceling Cruise Control
Temporary Cancellation of Cruise Control
Lighting Switch and Other Switches
Light Switch
How to Use Turn Signal Lamp
Hazard Lamp Switch
Horn Switch
Wiper
Front Fog Lamp Switch (Option)
Rear Fog Lamp Switch (Option)
Accessories in Cab
Monitor
AUX Display
Screen Brightness/Contrast Adjustment
Dimming of MFD Screen
Air Conditioner
How to Use Other Accessories
Operation in Cold Season
Winterization
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance.
About Inspection and Maintenance
Legal Inspection
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Part
Inspection and Maintenance Interval (Carrier)
Irregularities Detected on the Previous Day or
Operation
Inspection Around Carrier
Inspection of the Engine Room
Inspection at Driver's Seat
Greasing
Greasing Chart
Water Separator
Engine Coolant
Coolant Filter (Warm Water)
Radiator Fin
Air Hose, Engine Coolant Hose
Air Cleaner
Air Intake Manifold and Hose
Transmission Oil
Axle
Axle and differential
Differential Lock Function
Propeller Shaft
Torque Rod, Suspension
Suspension system
Leaf Spring Type Suspension (front)
Rear Suspension
Air Dryer
Front Brake Pad
Rear Brake Lining
Air Circuit
Breather Hole of Front Brake Chamber
Breather Hole of Rear Brake Chamber
Brake Valve Silencer
Hydraulic Oil Tank
Fuse
Tire, Wheel
Tires
Wheel Nut
Air Conditioner
Air Conditioner System
Condenser
Inside Air Filter
Outside air filter
EMERGENCY OPERATIONS
Action in Emergency
If Failure Occurs while Traveling on a Road .
If Stalled at a Railroad Crossing
When Engine Problem Occurs
When Overheating Occurs
When Fuel Runs Out
When Towed
INFORMATION AND DATA
Conversion Tables
Bolt Tightening Torque
Major Specifications
Engine Type
Traveling Performance
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Transportation of Crane
Checking the Transportation Configuration
Binding Point
Service Data
Service Data
Brand: Tadano
Introduction
Warranty
In Event of Failure
Terminal)
For Safety
Contents
Name of Each Part
Traveling System
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering Cab
Adjustment of Seat
Sunshade
Meters and Gauges
Warning Sign
Control System
How to Start Engine
How to Stop Engine
Shift Operation
Brake Operation
Steering Operation
Light Switch
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Monitor
AUX Display
Air Conditioner
Winterization
Legal Inspection
Operation
Greasing
Greasing Chart
Water Separator
Engine Coolant
Radiator Fin
Air Cleaner
Transmission Oil
Axle
Propeller Shaft
Suspension system
Rear Suspension
Air Dryer
Front Brake Pad
Rear Brake Lining
Air Circuit
Hydraulic Oil Tank
Fuse
Tire, Wheel
Tires
Wheel Nut
Air Conditioner
Condenser
Inside Air Filter
Outside air filter
Action in Emergency
When Fuel Runs Out
When Towed
Conversion Tables
Engine Type
Oils and Greases
Binding Point
Service Data
Service Data
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
