Tadano Crane GR-700N Operation Manual GR-700N-2_OM4-13E 2025
Brand: Tadano
Type of Machine: Rough Terrain Crane
Model: Tadano GR-700N Rough Terrain Crane
Applicable Model: GR-700N-2
Applicable Specification: GR-700N-2-00123
Serial Number: FE2548
Part Number: GR-700N-2_OM4-13E
Publication Date: 2025
Number of Pages: 655 Pages
Introduction
Warranty
In Event of Failure
Taking Machine Out of Country (Including
Mobile/Satellite Communication Terminals (Equipp
Machine Only), Radio Control Device, and Immobiliz
(Equipped Machine Only))
For Safety
Contents
Name of Each Part
Contents with Illustrations
Traveling System
Crane Control System
Other Controls
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Precautions for Using Setup Radio Controller
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Checking Traveling Configuration
Status of Traveling Controls
Inspection before Traveling
Entering Cab
Opening/Closing Door
Opening/Closing Window
Adjusting Seat
Adjusting Steering Wheel
Adjusting Mirrors
Fastening/Unfastening Seat Belt
Stowing Control Lever Stand
Sunshade
How to Read Instrument Panel and MFD .
Meters and Gauges
Urea SCR System Indicator
Warning Sign
Error Codes Shown on MFD
TADANO View System
Camera Positions
Displaying Camera Images
Wide Sight View
Human Alert System
Front Left Camera (Option)
Starting and Stopping Engine
Starter Switch
Immobilizer (If Equipped)
How to Start Engine
How to Stop Engine
Exhaust Gas Purifying System
DEF/AdBlue (Urea Solution)
Cleaning of Urea SCR System
Transmission Operation
Positions and Functions of Gearshift Switch
Gearshift Switch Operation
Setting Power Mode
Brake Operation
Foot Brake Operation
Parking Brake Operation
Engine Retarder Operation
Retarder Operation
Auxiliary Operating Brake (AUX)
Operating Steering
Selecting Steering Mode
Drive Mode Selection
Selecting Drive Mode
Defferential Lock Operation
Switching Differential Lock
Operating Suspension
Suspension Free Operation
Vehicle Height Up/Down Operation
Fully Retracting Suspension
Lighting Switch and Other Switches
Light Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Fuel Consumption Monitor
Alarm Buzzer Muting Function
Dimming of MFD Screen
Preset Menu
Folding/Unfolding Rearview Mirrors
Mirror Heater
Air Conditioner
Tachograph
AM/FM Radio
How to Use Other Accessories
Operation in Cold Season
Winterization/Inspection
OPERATION1
Terminology
Anchor Point for Fall-arrest System
Location of Anchor Points
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
AML (Automatic Moment Limiter)
How to Read Indication
Selecting Display
Crane Status Indicator
Lift Status Registration and AML Function
Check
Alarm and Recovery Operation
Other Functions
When Error Occurs in Load Moment Indicator
System
Other Safety Devices
Anti-two-block Device
AML External Warning Lamp
Stop Switch
Anemometer (Option)
PTO Operation
PTO “ON” Operation
PTO “OFF” Operation
Selecting Mode
Safety Functions
Preparing for Operation Using Radio Controller
Basic Operations
Switching Operation from Radio Controller to Cont
n Cab
Other Functions
Transmitter
Outrigger Operations
Control System
Crane Operation Mode
Outrigger Operation Mode
Outrigger Extension Width and Appearance of Ma
on Side of Outrigger Beams
Cautions for Setting Up Outriggers
Setting up Pads
Outrigger Extending Operation from Outrigger Co
Panel/Box
Extending Outriggers Using Radio Controller
Horizontal Set-up
Outrigger Stowing Operation from Outrigger Cont
Panel/Box
Stowing Outriggers Using Radio Controller
Stowing Pads
Adjusting Control Lever Stands and Control
Levers
Adjusting Control Levers
Hoisting
Hoisting Up/Down Operation
High-speed Hoist-down Operation
Drum Indicator
Boom Telescoping Operation
Maintenance Telescoping Operation
Boom Elevating Operation
Elevation Slow Stop/Cancel Operation
Slewing Operation
Slewing Operation
Slewing Free Switch
Traveling on Work Site
Traveling Configuration in Work Site
On-rubber Operation
On-rubber (Stationary) Operation
On-rubber (Creep) Operation
Taking Out and Stowing Hook Block
Taking Out Hook Block
Stowing Hook Block
Reeving Wire Ropes
Standard Number of Parts of Line
Reeving Procedure
Heavy Load Lifting Device
Check before Using Heavy Load Lifting Device
Single Top
Check before Single Top Lift
Full Automatic Jib
Jib Lift
Jib Set Mode
Outline of Jib Mounting
Mounting Jib
Changing Jib Length
Changing Jib Offset Angle
Outline of Jib Stowing
Stowing Jib
Accessories in Cab
MFD Operation Switch
Flood Lamp Button
Mirror Heater
Roof Washer Switch
Roof Wiper Switch
Microphone Control Box
Table
Drink Holder
Searchlight (Option)
Outside Cab Accessories
Stepladder
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance
About Inspection and Maintenance
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Parts
Inspection and Maintenance Interval (Carrier)
Inspection and Maintenance Interval (Crane)
Irregularities Detected on Previous Day or
Operation
Inspection Around Carrier
Inspection of Engine Room
Inspection at Driver’s Seat
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Device
Inspection of Crane Structure
Boom Structure
Jib Structure
Slewing Frame
Outrigger Structure
Chassis Frame
Greasing
Greasing Chart
Greasing (Centralized Greasing Supply Unit)
(Option)
Using Centralized Greasing Supply Unit
Greasing Intervals
Greasing Points
Adding Grease
Gear Oil
Winch Speed Reducer (Main/Auxiliary Winch)
Slewing Speed Reducer
1st Axle Hub and 2nd/3rd/4th Axle Planetary
Gear
2nd/3rd/4th Axles on Carrier
Air Cleaner for Compressor
DEF/AdBlue Tank
Retarder
Air Gap
Drum
Center Bearing
Engine Cooling System
Coolant Filter (Warm Water)
Transmission System
Line Filter
Fuel System
Brake Fluid Reservoir
Disc Brake Pad
Air Dryer
Air Tank
Tire, Wheel
Tires
Wheel Nut
Hydraulic Oil Tank
Return Filter
Line Filter
(Pump Circuit for Steering and Slewing)
Line Filter (P4 Circuit)
Telescoping System
Boom Telescoping Wire Rope
Jib Telescoping Wire Rope
Slewing System
Slewing Bearing Mounting Bolt
Electric System
Fuse Replacement
Radio Controller Battery Replacement
Air Conditioner System
Condenser
Refrigerant Level
Refrigerant Piping Connection
Inside Air Filter and Outside Air Filter
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
EMERGENCY OPERATIONS
Action in Emergency
If Failure Occurs While Traveling on Road
If Stalled at Railroad Crossing
If Tires Are Off Ground and Machine Cannot
Move
If Transmission Cannot Be Operated
When Fuel Runs Out
When Overheating Occurs
When Towed
If Error Occurs in AML System
If Crane Is not Operable
If Crane Does Not Stop Even If Control Lever is
Returned to Neutral Position
If Boom Cannot Be Telescoped
When Boom Length Is Corrected
INFORMATION AND DATA
Conversion Tables
Major Specifications
Crane Specifications
Carrier Specifications
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Error Code Table
VCU/DCU2 Error Code
Stop/Warning Error Code
Service Data
Service Data
Brand: Tadano
Introduction
Warranty
In Event of Failure
For Safety
Contents
Name of Each Part
Traveling System
Other Controls
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering Cab
Adjusting Seat
Adjusting Mirrors
Sunshade
Meters and Gauges
Warning Sign
TADANO View System
Camera Positions
Wide Sight View
Human Alert System
Starter Switch
How to Start Engine
How to Stop Engine
Setting Power Mode
Brake Operation
Retarder Operation
Operating Steering
Light Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Preset Menu
Mirror Heater
Air Conditioner
Tachograph
AM/FM Radio
OPERATION1
Terminology
Working Range Chart
Selecting Display
Check
Other Functions
System
Stop Switch
Anemometer (Option)
PTO Operation
PTO “ON” Operation
PTO “OFF” Operation
Selecting Mode
Safety Functions
Basic Operations
n Cab
Other Functions
Transmitter
Control System
Setting up Pads
Panel/Box
Horizontal Set-up
Panel/Box
Stowing Pads
Levers
Hoisting
Drum Indicator
Slewing Operation
Slewing Operation
Slewing Free Switch
On-rubber Operation
Stowing Hook Block
Reeving Wire Ropes
Reeving Procedure
Single Top
Full Automatic Jib
Jib Lift
Jib Set Mode
Mounting Jib
Changing Jib Length
Stowing Jib
Accessories in Cab
Flood Lamp Button
Mirror Heater
Roof Washer Switch
Roof Wiper Switch
Table
Drink Holder
Stepladder
Operation
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Device
Boom Structure
Jib Structure
Slewing Frame
Outrigger Structure
Chassis Frame
Greasing
Greasing Chart
(Option)
Greasing Intervals
Greasing Points
Adding Grease
Gear Oil
Gear
DEF/AdBlue Tank
Retarder
Air Gap
Drum
Center Bearing
Transmission System
Line Filter
Fuel System
Disc Brake Pad
Air Dryer
Air Tank
Tire, Wheel
Tires
Wheel Nut
Hydraulic Oil Tank
Return Filter
Line Filter
Telescoping System
Slewing System
Electric System
Fuse Replacement
Condenser
Refrigerant Level
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
Action in Emergency
Move
When Fuel Runs Out
When Towed
Conversion Tables
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Error Code Table
VCU/DCU2 Error Code
Service Data
Service Data
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
