Hyundai
86
176,834
Tadano Crane GR-550XL-2 Service Manual GR-550XL-2_C1(U)-2E
Tadano Rough Terrain Crane GR-550XL-2 Service Manual GR-550XL-2_C1(U)-2E
Brand: Tadano
Type of Machine: Rough Terrain Crane
Type of Manual: Service Manual, Hydraulic Diagram
Model: Tadano GR-550XL-2 Rough Terrain Crane
Applicable Serial No. 540642 --
Part Number: GR-550XL-2/C1(U)-2E
Number of Pages: 147 Pages
GR-550XL-2/C1(U)-2E
Foreword
1. Applicable spec. and serial number
2. Separate service manual
3. Outline of specifications
4. Group index
5. Contents
(Y)Data, Adjustment and Checks
Y-1 Service Data
1. Amounts of oil and coolant​
2. Operating speed​
3. Hydraulic device​
4. Swing section​
5. Boom section​
6. Criteria for maintenance and replacement of vehicle​
7. Mass table​
Y-2 Adjusting Pressure (Hydraulic Pressure)
1. Winch​
2. Telescoping​
3. Elevating​
4. Steering​
5. Swing​
6. Outrigger​
7. Lower pilot pressure​
8. Remote control pilot pressure​
9. Torque converter oil pressure​
Y-3 Adjusting Pressure (Pneumatic Pressure)
1. Pneumatic pressure setting table​
Y-4 Air Bleeding Procedure
1. Hydraulic pump​
2. Winch brake​
3. Service brake​
4. Hydraulic motor assy​
5. Winch counterbalance valve (main and aux.)​
6. Swing control back-pressure valve​
7. Pilot circuit (hydraulic pilot control valve)​
8. Positive control circuit​
9. Hydraulic valve (winch brake)​
10. Jib lock pin and jib offset cylinder​
Y-5 Adjusting Procedure (Electric)
1. Boom full retraction detection switch (CN859)​
2. Jib stowed detection switch (CN572)​
3. Jib lock pin retractiondetection switch (CN573)​
4. Main winch drum rotation detection switch (CN591)​
5. Aux. winch drum rotation detection switch (CN592)​
6. Over-front detection switch (CN521)​
7. Control lever stand position detection switch (left) (CN529)​
8. Straight ahead detection switch (CN408)​
Y-6 Assembly Adjustment (Crane Operation)
1. Adjusting boom telescoping wire ropes​
Y-7 Assembly Adjustment (Traveling Device)
1. Service brake adjustment​
2. Accelerator adjustment​
3. Parking brake adjustment​
4. Tire and steering angle adjustment​
5. Engine speed (and governor setting)​
6. Torque converter and transmission​
7. Braking force​
8. Adjusting the headlight light axes​
9. Retightening the hub nuts​
Y-8 Operation Check (Crane Operation)
1. Outrigger status indicator​
2. Hoisting​
3. Backward stability control​
4. Outrigger emergency setting​
5. Jib​
6. Suspension lock​
7. Warning​
8. Outrigger slide plate adjustment​
9. Eco mode operation check​
Y-9 Operation Check (Traveling Device)
1. Exhaust brake (EXB)​
2. Automatic transmission​
3. Steering mode change​
4. Emergency switch​
5. Overshift prevention​
6. Warning​
7. Speedometer​
Y-10 Inspection and Maintenance
Y-11 Boom Connecting Pin and Thread Size Table
(Z)System Diagrams
Z-1 Hydraulic Circuit
1. Comparison table of hydraulic parts (Part No., Part name and Location)​
2. Hydraulic circuit diagram​
Z-2 Torque Converter Circuit
Z-3 Pneumatic Circuit
Z-4 Electric Circuit (Upper) (Crane)
1. Composition of the electric circuit diagram​
2. Reading method of electric circuit diagram​
3. Comparison table (Connector No., Usage, Coordinate and Paragraph No.)​
4. Electric circuit​
Z-5 Electric Circuit (Upper) (Carrier)
2. Comparison table (Connector No., Usage, Coordinate and Paragraph No.)​
3. Electric circuit​
Z-6 Electric Circuit (Lower)
Z-7 Hydraulic Parts Location Diagram (Upper)
1. Winch​
2. Telescoping​
3. Elevation​
4. Swing​
5. Return​
6. Drain​
7. Gauge​
8. Pilot​
9. Steering​
10. Air conditioner​
11. Operation assy, operation valve​
12. Pressure switch​
13. Jib​
Z-8 Hydraulic Parts Location Diagram (Lower)
1. Suction​
2. Steering, suspension lock​
3. Outrigger (H type)​
4. Center joint​
5. Return​
6. Outrigger main body (H type)​
Z-9 Hydraulic Parts Location Diagram (Torque Converter)
1. Torque converter related​
Z-10 Pneumatic Parts Location Diagram
1. Service brake related (upper)​
2. Service brake related (lower)​
3. Control parts (lower)​
Z-11 Electric Parts Location Diagram (Upper)
1. Inside cab​
2. Swing table, boom​
3. Relay assy (inside cab)​
4. Pressure switch installation diagram​
Z-12 Electric Parts Location Diagram (AML, Overwinding (Two-blocking))
1. AML parts assy​
2. Overwind (two-blocking) indicator assy (boom)​
3. Overwind (two-blocking) indicator assy (single top and jib)​
Z-13 Electric Parts Location Diagram (ICF, SCT)
1. ICF​
2. SCT​
Z-14 Electric Parts Location Diagram (Lower)
1. Lower, main​
2. Lower electric unit box (MDT, ECU, DIAG lamps)​
3. Relay and fuse box (under the battery)​
Z-15 Harness (Upper) (Crane)
1. Harness (crane, main)​
2. Harness (swing table, right)​
3. Harness (swing table, left)​
4. Harness (boom)​
5. Harness (AML)​
6. Harness (AML override)​
7. Harness (overwinding (two-blocking)) (boom)​
Z-16 Harness (Upper) (Carrier)
1. Harness (carrier, main)​
2. Harness (T/M, O/R)​
3. Harness (accelerator)​
4. Harness (ICF)​
5. Harness (SCT)​
Z-17 Harness (Lower)
1. Harness (lower, main)​
2. Harness (lower air)​
3. Harness (engine, without DPF)​
History of revision
