Tadano Crane GR-350XL Operation Manual GR-350XL-3_OM1(U)-21E 2025
Brand: Tadano
Type of Machine: Rough Terrain Crane
Model: Tadano GR-350XL Rough Terrain Crane
Applicable Model: GR-350XL-3
Applicable Specification: GR-350-3-00311
Serial Number: 562640 –
Part Number: GR-350XL-3_OM1(U)-21E
Publication Date: 2025
Number of Pages: 475 Pages
WARRANTY
Introduction
Warranty
In Event of Failure
Using Crane Out of the US
(Including Satellite Communication Terminal)
For Safety
Contents
Name of Each Part
Contents with Illustrations
Traveling System
Crane Control System
Other Controls
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Check of Traveling Configuration
Status of the Traveling Controls
Inspection before Traveling
Entering the Cab
Opening/Closing Door
Opening/Closing Window
Adjustment of Seat
Adjustment of Steering Wheel
Adjustment of Mirrors
Fastening/Unfastening of Seat Belt
Adjustment of Control Lever Stand
Sunshade
Reading the Instrument Panel
Meters and Gauges
SCR System Indicator
Warning Lamp
Error Codes Shown on the Hour Meter
Starting and Stopping Engine
How to Start Engine
How to Stop Engine
Exhaust Gas Purifying System
DEF / AdBlue (Urea Solution)
Cleaning the SCR System
Transmission Operation
Shift Lever Operation
Brake Operation
Foot Brake Operation
Parking Brake Operation
Exhaust Brake Operation
Steering Operation
Selecting the Steering Mode
Drive Mode Selection
Lighting Switch and Other Switches
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Fuel Consumption Monitor
Air Conditioner
Cab Lamp
Cigarette Lighter
Outside Cab Accessories
Radiator Shutter, Radiator Cover
Engine Pre-heater (Option)
Handling Tires
Tire Air Pressure
Restriction of Continuous Traveling
Operation in Cold Season
Winterization
OPERATION
Terminology
Anchor Points for Safety Belt
Location of Anchor Points
How to Attach to Anchor Point
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
Reduction of Rated Lifting Capacity
Load Moment Indicator (AML)
How to Read the Indication
Selecting Display
Crane Status Indicator
Registration of Operating Status and Load
Moment Indicator (AML) Function Check
Alarm and Recovery Operation
Other Functions
Action against Load Moment Indicator System
Errors
Other Safety Devices
Anti-two-block Device
Load Moment Indicator External Warning
Lamps
Lamps (Option)
Over-unwinding Cutout Function (Option)
Anemometer (Option)
Emergency Stop Switch
PTO
PTO "ON" Operation
PTO "OFF" Operation
Suspension Lock
Locking Suspension
Releasing Suspension Lock
Outriggers
Outrigger Set-up
Extending Outriggers
Horizontal Set-up
Stowing Outriggers
Hoisting
Hoisting Up/Down
Drum Indicator (Visual Type)
Drum Indicator (Vibration Type) (Option)
Boom Telescoping Operation
Elevating Boom
Boom Raising/Lowering Operation
Elevation Slow Stop Function
Slewing Boom
Slewing Boom
Slewing Free/Lock Selector Switch
Automatic Slewing Stop Function
On-rubber Operation
On-rubber Stationary Operation
On-rubber Creep Operation
Taking Out and Stowing Hook Block
Taking Out Main Hook Block
Stowing Main Hook Block
Reeving the Wire Ropes
Standard Number of Parts of Line
Hook Block with Sheave Covers
Auxiliary Hook Block with Safety Latch Lock
Function
Single Top
Mounting the Single Top
Stowing Single Top
Jib
Registration of Jib status
Jib Lift
Outline of Jib Installation
Mounting of Jib
Changing Jib Offset Angle
Changing Jib Length
Outline of Jib Stowing
Stowing Jib
Dismounting Jib
Mounting Removed Jib
Accessories in Cab
Flood Lamp Switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance
About Inspection and Maintenance
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Part
Inspection and Maintenance Interval
(Carrier)
(Crane)
Abnormal Items Detected On the Previous D
or Operation
Inspection around Carrier
Inspection of the Engine Room
Inspection at Driver’s Seat
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Devices
Inspection of Crane Structure
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch Speed Reducer
(Main/Auxiliary Winch)
Slewing Speed Reducer
Axle (Carrier)
Axle (Planetary Gear)
Maintenance Table
Radiator Fin
Air Cleaner for Air Compressor
DEF/AdBlue Tank
Adding DEF/AdBlue
Replacing DEF/AdBlue
Engine Cooling System
Maintenance Table
Coolant Filter
Transmission System
Maintenance Table
Line Filter
Fuel System
Maintenance Table
Fuel tank
Draining Water from Water Separator
Maintenance Table
Brake Fluid Reservoir
Disc Brake Pad
Air Dryer
Parking Brake Pad
Tire, Wheel
Maintenance Table
Tire
Wheel Nut
Maintenance Table
Hydraulic Oil Tank
Return Filter
Line Filter (Steering, Slewing Pump Circuit)
Slewing System
Maintenance Table
Slewing Bearing Mounting Bolt
Maintenance Table
Replacing Fuses
Air Conditioner System
Maintenance Table
Condenser
Refrigerant Level
Refrigerant Piping Connection
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Replacing Wire Ropes
Handling Wire Ropes
Brand: Tadano
WARRANTY
Introduction
Warranty
In Event of Failure
For Safety
Contents
Name of Each Part
Traveling System
Other Controls
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering the Cab
Adjustment of Seat
Sunshade
Meters and Gauges
Warning Lamp
How to Start Engine
How to Stop Engine
Brake Operation
Steering Operation
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Air Conditioner
Cab Lamp
Cigarette Lighter
Handling Tires
Tire Air Pressure
Winterization
OPERATION
Terminology
Working Range Chart
Selecting Display
Other Functions
Errors
Lamps
Lamps (Option)
Anemometer (Option)
PTO
PTO "ON" Operation
PTO "OFF" Operation
Suspension Lock
Locking Suspension
Outriggers
Outrigger Set-up
Horizontal Set-up
Stowing Outriggers
Hoisting
Hoisting Up/Down
Elevating Boom
Slewing Boom
Slewing Boom
On-rubber Operation
Function
Single Top
Stowing Single Top
Jib
Jib Lift
Mounting of Jib
Changing Jib Length
Stowing Jib
Dismounting Jib
Accessories in Cab
Flood Lamp Switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
(Carrier)
(Crane)
or Operation
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Devices
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch Speed Reducer
Axle (Carrier)
Maintenance Table
Radiator Fin
DEF/AdBlue Tank
Adding DEF/AdBlue
Maintenance Table
Coolant Filter
Transmission System
Maintenance Table
Line Filter
Fuel System
Maintenance Table
Fuel tank
Maintenance Table
Disc Brake Pad
Air Dryer
Parking Brake Pad
Tire, Wheel
Maintenance Table
Tire
Wheel Nut
Maintenance Table
Hydraulic Oil Tank
Return Filter
Slewing System
Maintenance Table
Maintenance Table
Replacing Fuses
Maintenance Table
Condenser
Refrigerant Level
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Handling Wire Ropes
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
