Tadano Crane GR-350XL Operation Manual GR-350XL-2_OM1(U)-24E 2018
Brand: Tadano
Type of Machine: Rough Terrain Crane
Model: Tadano GR-350XL Rough Terrain Crane
Applicable Model: GR-350XL-2
Applicable Specification: GR-350-2-00101 (2M2D model), GR-350-2-00102 (1M1D model)
Serial Number: 561795–
Part Number: GR-350XL-2_OM1(U)-24E
Publication Date: 2018
Number of Pages: 439 Pages
WARRANTY
Introduction
Warranty
In Event of Failure
Exporting Machine (Including Satellite
Communications Equipment) Abroad
For Safety
Contents
Name of Each Part
Contents with Illustration
Traveling System
Crane Control System
Other Controls
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Check of Traveling Configuration
Position of Switches
Inspection before Traveling
Entering the Cab
Opening/Closing Door
Opening/Closing Window
Adjustment of Seat
Adjustment of Steering Wheel
Adjustment of Mirrors
Fastening/Unfastening of Seat Belt
Adjustment of Control Lever Stand
Sunshade
Reading the Instrument Panel
Meters and Gauges
DPF (Diesel Particulate Filter) Indicator
Warning Lamp
Starting and Stopping Engine
How to Start Engine
How to Stop Engine
DPF regeneration
Transmission Operation
Shift Lever Operation
Brake Operation
Foot Brake Operation
Parking Brake Operation
Exhaust Brake Operation
Steering Operation
Selecting the Steering Mode
Drive Mode Selection
Lighting Switch and Other Switches
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Fuel Consumption Monitor
Air Conditioner
Cab Lamp
Cigarette Lighter
Handling Tires
Tire Air Pressure
Restriction of Continuous Traveling
Operation in Cold Season
Winterization
OPERATION
Terminology
Anchor Points for Safety Belt
Location of Anchor Points
How to Attach to Anchor Point
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
Reduction of Rated Lifting Capacity
Load Moment Indicator (AML)
How to Read the Indication
Selecting the Display
Crane Status Indicator
Registration of Operating Status and Load
Moment Indicator (AML) Function Check
Alarm and Recovery Operation
Other Functions
Action against Load Moment Indicator System
Errors
Other Safety Devices
Anti-Twoblock Device
Load Moment Indicator External Warning Lamp
(option)
Anemometer (Option) (For Serial No.561796 o
later)
PTO
Engaging PTO (PTO "ON" Operation)
Disengaging the PTO (PTO "OFF" Operation).
Suspension Lock
Locking Suspension
Releasing Suspension Lock
Outriggers
Outrigger Set-up
Extending Outriggers
Horizontal Set-up
Stowing Outriggers
Hoisting (MD Model)
Hoisting Up/Down
Drum Indicator (Visual Type)
Drum Indicator (Vibration Type) (Option)
Hoisting (MD Model)
Hoisting Up/Down
Boom Telescoping Control (MD Model)
Elevating Boom
Boom Raising/Lowering Operation
Elevation Slow Stop Function
Swinging Boom
Swinging Boom
Swing Free/Lock Selector Switch
Automatic Swing Stop Function
On-rubber Operation
On-rubber Stationary Operation
On-rubber Creep Operation
Taking Out and Stowing Hook Block
Taking Out Main Hook Block
Stowing Main Hook Block
Reeving the Wire Ropes
Standard Number of Parts of Line
Reeving Procedure
Single Top
Mounting the Single Top
Stowing Single Top
Jib
Registration of Jib status
Jib Lift
Outline of Jib Installation
Mounting of Base Jib
Changing Jib Offset Angle
Changing Jib Length
Outline of Jib Stowing
Stowing Jib
Dismounting Jib
Mounting Jib
Accessories in Cab
Flood Lamp Switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
INSPECTION AND MAINTENANCE .
Precautions for Inspection and Maintenance
About Inspection and Maintenance
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Part
Inspection and Maintenance Interval (Carrier
Inspection and Maintenance Interval (Crane)
Abnormal Items Detected On the Previous D
Operation
Inspection around Carrier
Inspection of the Engine Room
Inspection at Driver’s Seat
Control System
Outrigger System
Swing System
Boom, Jib System
Lifting Device
Safety Devices
Inspection of Crane Structure
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Winch Speed Reducer (Main/Auxiliary Winch
Swing Speed Reducer
Axle (Carrier)
Axle (Planetary Gear)
Maintenance Table
Radiator Fin
Engine Cooling System
Maintenance Table
Coolant Filter
Torque Converter System
Maintenance Table
Line Filter
Fuel System
Maintenance Table
Draining Water from Water Separator
Maintenance Table
Brake Fluid Reservoir
Disc Brake Pad
Air Dryer
Parking Brake Pad
Tire, Wheel
Maintenance Table
Tire
Wheel Nut
Maintenance Table
Hydraulic Oil Tank
Return Filter (Front of Hydraulic Tank)
Line Filter (Pump Circuit for Steering and
Swinging)
Swing System
Maintenance Table
Swing Bearing Mounting Bolt
Maintenance Table
Replacing Fuses
Air Conditioner System
Maintenance Table
Condenser
Refrigerant Level
Refrigerant Piping Connection
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Replacing Wire Ropes
Handling Wire Ropes
EMERGENCY OPERATIONS
Action against Emergency
If Failure Occurs during Traveling on Road
If Stalled at Railroad Crossing
To Interrupt DPF Regeneration
If Transmission Cannot Be Operated
If Engine Speed Does Not Increase
Engine Does Not Stop
If Overheated
When Towed (Vehicle with Emergency Steerin
Pump)
If Error Occurs in the Load Moment Indicator
System
If Boom Cannot Be Telescoped
If Outrigger Extension Detection Device Fails
If Getting In/Out of Cab Door Is Not Possible
(Option)
INFORMATION AND DATA
Conversion Tables
Hand Signals
Major Specifications
Crane
Carrier
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Oils and Greases Table
Recommended Oils and Greases
Service Data
Service Data
Brand: Tadano
WARRANTY
Introduction
Warranty
In Event of Failure
For Safety
Contents
Name of Each Part
Traveling System
Other Controls
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering the Cab
Adjustment of Seat
Sunshade
Meters and Gauges
Warning Lamp
How to Start Engine
How to Stop Engine
DPF regeneration
Brake Operation
Steering Operation
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Air Conditioner
Cab Lamp
Cigarette Lighter
Handling Tires
Tire Air Pressure
Winterization
OPERATION
Terminology
Working Range Chart
Other Functions
Errors
(option)
later)
PTO
Suspension Lock
Locking Suspension
Outriggers
Outrigger Set-up
Horizontal Set-up
Stowing Outriggers
Hoisting (MD Model)
Hoisting Up/Down
Hoisting (MD Model)
Hoisting Up/Down
Elevating Boom
Swinging Boom
Swinging Boom
On-rubber Operation
Reeving Procedure
Single Top
Stowing Single Top
Jib
Jib Lift
Changing Jib Length
Stowing Jib
Dismounting Jib
Mounting Jib
Accessories in Cab
Flood Lamp Switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
Operation
Control System
Outrigger System
Swing System
Boom, Jib System
Lifting Device
Safety Devices
Greasing
Maintenance Table
Greasing Chart
Gear Oil
Maintenance Table
Swing Speed Reducer
Axle (Carrier)
Maintenance Table
Radiator Fin
Maintenance Table
Coolant Filter
Maintenance Table
Line Filter
Fuel System
Maintenance Table
Maintenance Table
Disc Brake Pad
Air Dryer
Parking Brake Pad
Tire, Wheel
Maintenance Table
Tire
Wheel Nut
Maintenance Table
Hydraulic Oil Tank
Swinging)
Swing System
Maintenance Table
Maintenance Table
Replacing Fuses
Maintenance Table
Condenser
Refrigerant Level
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Handling Wire Ropes
If Overheated
Pump)
System
(Option)
Conversion Tables
Hand Signals
Crane
Carrier
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Service Data
Service Data
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
