Tadano Crane GR-1100EX Operation Manual GR-1100EX-3_OM2-24E 2025
Brand: Tadano
Type of Machine: Rough Terrain Crane
Model: Tadano GR-1100EX Rough Terrain Crane
Applicable Model: GR-1100EX-3
Applicable Specification: GR-1100E-3-00102
Serial Number: FF0200–
Part Number: GR-1100EX-3_OM2-24E
Publication Date: 2025
Number of Pages: 621 Pages
Introduction
Warranty
In Event of Failure
Before Using Crane Out of Country of Purchase
(Including Satellite/Mobile Communication
Terminal)
For Safety
Contents
Name of Each Part
Contents with Illustrations
Traveling System
Crane Control System
Other Controls
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Checking Traveling Configuration
Status of Traveling Controls
Inspection before Traveling
Status While Traveling in Work Site
Entering Cab
Opening/Closing Door
Opening/Closing Window
Adjustment of Seat
Adjustment of Steering Wheel
Mirror adjustment
Fastening/Unfastening Seat Belt
Adjustment of Control Lever Stand
Sunshade
Reading Instrument Panel
Meters and gauges
Warning sign
Error Codes Shown on Hour Meter
Starting and Stopping Engine
Starter switch
Idling Adjuster Knob
(for serial No. FF0274 or later)
Idling Adjuster Knob (for up to serial No. FF0273)
How to Start Engine
How to Stop Engine
Transmission Operation
Positions and Functions of Shift Lever
Shift Lever Operation
Brake Operation
Foot Brake Operation
Parking Brake Operation
Operating Exhaust Brake
Steering Operation
Selecting Steering Mode
Drive Mode Selection
Lighting Switch and Other Switches
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Fuel Consumption Monitor
Air Conditioner
Cab Lamp
Cigarette Lighter
Outside Cab Accessories
Steps
Radiator Shutter and Radiator Cover
Engine Pre-heater (option)
Handling Tires
Tire Air Pressure
Restriction of Continuous Traveling
Operation in Cold Season
Winterization
OPERATION1
Terminology
Anchor Points for Safety Belt
Location of Anchor Points
How to Attach to Anchor Point
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
Reduction of Rated Lifting Capacity
Automatic Moment Limiter (AML)
How to Read Indication
Selecting Display
Crane Status Indicator
Registration of Operating Status and AML Functio
Check
Alarm and Recovery Operation
Other Functions
Action against AML System Errors
Other Safety Devices
Anti-two-block Device
AML External Warning Lamp
AML External Warning Lamps (option)
Emergency Stop Switch
Beacon Lamp (Option)
Over-unwinding Cutout Function (Option)
Anemometer (option)
Aviation Obstruction Light (Option)
PTO
PTO ON Operation
PTO OFF Operation
Outriggers
Control system
Extension Width of Outriggers and Appearance of
Marks on Side of Outrigger Beam
Outrigger Set-up
Extending Outriggers
Horizontal Set-up
Stowing Outriggers
Hoisting
Hoisting Up/Down
High-Speed Hoist-Up/Down Operation
Drum Indicator (Visual Type)
Drum Indicator (Vibration Type) (Option)
Winch Speed Changeover Operation
Boom Telescoping Operation
Outline of Telescoping Mode
Type of Telescoping Mode
Outline of AML Display Change
Normal Telescoping Operation
Maintenance Telescoping Operation
Low Temperature Telescoping Mode
Boom Telescoping Speed Changeover
Operation
Elevating boom
Elevating Boom
Elevation Slow Stop Function
Boom Raising/Lowering Operation
(When Traveling Work Site)
Boom Elevation Speed Changeover Operation
Slewing Boom
Slewing Boom
Slewing Free/Lock Selector Switch
Automatic Slewing Stop Function
On-rubber Operation
On-rubber Stationary Operation
On-rubber (creep) operation
Taking Out and Stowing Hook Block
Taking Out the Main Hook Block
Stowing Main Hook Block
Reeving Wire Rope
Standard number of parts of line
Reeving Procedure
Single top
Mounting Single Top
Stowing Single Top
Jib
Registering Jib Mounting/dismounting Status
Jib Lift
Outline of Jib Mounting
Mounting of Base Jib
Mounting of Base Jib + Top Jib
Changing Jib Offset Angle
Outline of Jib Stowing
Stowing of Base Jib
Stowing of Base Jib + Top Jib
Dismounting Jib
Mounting Removed Jib
Mounting and Dismounting Counterweight
Counterweight Rigging Points
Mounting Counterweight
Mounting and Dismounting Auxiliary Winch
Mounting Auxiliary Winch
Accessories in Cab
Flood lamp switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
Cab tilt switch
Searchlight (Option)
Fire Extinguisher (Option)
Winch Drum Monitoring Mirror
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance.
About Inspection and Maintenance
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Part
Inspection and Maintenance Interval (Carrier)
Inspection and Maintenance Interval (Crane)
Irregularities detected on the previous day or
operation
Inspection around carrier
Inspection of the Engine Room
Inspection at Driver's Seat
Hydraulic system
Control system
Outrigger system
Slewing system
Boom, Jib System
Lifting device
Safety Devices
Inspection of Crane Structure
Boom Structure
Jib Structure
Slewing frame
Outrigger Structure
Chassis frame
Greasing
Greasing Chart
Gear Oil
Winch Speed Reducer (Main/Auxiliary Winch)
Slewing Speed Reducer
Axle (Carrier)
Axle (Planetary Gear)
Radiator Fin
Engine Cooling System
Coolant Filter
Transmission System
Line filter
Fuel System
Fuel tank
Fuel filter
Brake Fluid Reservoir
Disc brake pad
Air dryer
Air Tank
Parking brake pad
Tire, Wheel
Tires
Wheel nut
Hydraulic Oil Tank
Return filter
Line filter (steering/slewing pump circuit)
Slewing System
Slewing bearing mounting bolt
Fuse Replacement
Air Conditioner System
Condenser
Refrigerant Level
Refrigerant piping connection
Inside air filter
Outside air filter
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
EMERGENCY OPERATIONS
Action in Emergency
If Failure Occurs while Traveling on a Road
If Stalled at a Railroad Crossing
If transmission cannot be operated
If engine speed does not increase
When Fuel Runs Out
When overheating occurs
When Towed
(Vehicle with Emergency Steering Pump)
If Boom Telescoping Operation Cannot Be
Performed
Display During Emergency Telescoping
Operation
Troubleshooting (A)
Troubleshooting (B)
Troubleshooting (C)
If Error Occurs in AML System
When Over-unwinding Cutout Function Hinders
Operation
If Counterweight Status Cannot Be Detected
If outrigger status cannot be detected
INFORMATION AND DATA
Conversion Tables
Major Specifications
Crane Specifications
Carrier Specifications
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
List of Main Components
(For Transportation)
Transportation of Crane
Checking the Transportation Configuration.
Binding Point
Service Data
Service Data
Brand: Tadano
Introduction
Warranty
In Event of Failure
Terminal)
For Safety
Contents
Name of Each Part
Traveling System
Other Controls
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering Cab
Adjustment of Seat
Mirror adjustment
Sunshade
Meters and gauges
Warning sign
Starter switch
How to Start Engine
How to Stop Engine
Brake Operation
Steering Operation
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Air Conditioner
Cab Lamp
Cigarette Lighter
Steps
Handling Tires
Tire Air Pressure
Winterization
OPERATION1
Terminology
Working Range Chart
Selecting Display
Check
Other Functions
Anemometer (option)
PTO
PTO ON Operation
PTO OFF Operation
Outriggers
Control system
Outrigger Set-up
Horizontal Set-up
Stowing Outriggers
Hoisting
Hoisting Up/Down
Operation
Elevating boom
Elevating Boom
Slewing Boom
Slewing Boom
On-rubber Operation
Reeving Wire Rope
Reeving Procedure
Single top
Mounting Single Top
Stowing Single Top
Jib
Jib Lift
Stowing of Base Jib
Dismounting Jib
Accessories in Cab
Flood lamp switch
Roof Washer Switch
Roof Wiper Switch
ECO Mode Switch
Cab tilt switch
operation
Hydraulic system
Control system
Outrigger system
Slewing system
Boom, Jib System
Lifting device
Safety Devices
Boom Structure
Jib Structure
Slewing frame
Outrigger Structure
Chassis frame
Greasing
Greasing Chart
Gear Oil
Axle (Carrier)
Radiator Fin
Coolant Filter
Transmission System
Line filter
Fuel System
Fuel tank
Fuel filter
Disc brake pad
Air dryer
Air Tank
Parking brake pad
Tire, Wheel
Tires
Wheel nut
Hydraulic Oil Tank
Return filter
Slewing System
Fuse Replacement
Condenser
Refrigerant Level
Inside air filter
Outside air filter
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
Action in Emergency
When Fuel Runs Out
When Towed
Performed
Operation
Troubleshooting (A)
Troubleshooting (B)
Troubleshooting (C)
Operation
Conversion Tables
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Binding Point
Service Data
Service Data
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
