Tadano Crane GR-1000EX-4 Operation Manual GR-1000EX-4_OM2-17E 2025
Brand: Tadano
Type of Machine: Rough Terrain Crane
Model: Tadano GR-1000EX-4 Rough Terrain Crane
Applicable Model: GR-1000EX-4
Applicable Specification: GR-1000E-4-00201
Serial Number: RA0991 –
Part Number: GR-1000EX-4_OM2-17E
Publication Date: 2025
Number of Pages: 629 Pages
EC Declaration of Conformity
Appendix
Introduction
Warranty
In Event of Failure
Taking Machine Out of Country (Including Mobile/Satellite Communication Terminals and Wireless L
Devices)
For Safety
Contents
Name of Each Part
Contents with Illustrations
Traveling System
Crane Control System
Other Controls
Safety Precaution
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Warning Labels
Label Location and Content of Warnings
TRAVELING
Before Traveling
Checking Traveling Configuration
Status of Traveling Controls
Inspection before Traveling
Entering Cab
Opening/Closing Door
Opening/Closing Window
Adjustment of Seat
Adjustment of Steering Wheel
Adjustment of Mirrors
Fastening/Unfastening Seat Belt
Adjustment of Control Lever Stand
Sunshade
How to Read Instrument Panel and MFD
Meters and Gauges
Exhaust Gas Purifying System Indicator
Warning Sign
Error Codes Shown on MFD
TADANO View System
Camera Position
Displaying Camera Images
Starting and Stopping Engine
Starter Switch
How to Start Engine
How to Stop Engine
DEF/AdBlue (Urea Solution)
Cleaning Exhaust Gas Purifying System
Transmission Operation
Positions and Functions of Gearshift Switch
Gearshift Switch Operation
Brake Operation
Foot Brake Operation
Parking Brake Operation
Operating Exhaust Brake
Steering Operation
Selecting Steering Mode
Drive Mode Selection
Lighting Switch and Other Switches
Light Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Fuel Consumption Monitor
Dimming of MFD Screen
Preset Menu
Air Conditioner
Clearance Sonar
How to Use Other Accessories
Outside Cab Accessories
Steps
Radiator Shutter and Radiator Cover
Battery Disconnect Switch
Engine Preheater (Option)
Handling Tires
Tire Air Pressure
Restriction of Continuous Traveling
Operation in Cold Season
Winterization
OPERATION
Terminology
Anchor Point for Fall-arrest System
Location of Anchor Points
How to Attach Fall-arrest System
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
Working Area Chart
Reduction of Rated Lifting Capacity
AML (Automatic Moment Limiter )
How to Read Indication
Selecting Display
Crane Status Indicator
Registration of Operation Status and AML Function Check
Alarm and Recovery Operation
Other Functions
When Error Occurs in AML system
Other Safety Devices
Anti-two-block Device
AML External Warning Lamps
Stop Switch
Beacon Lamp (option)
Over-unwinding Cutout Function (option)
Anemometer
Aviation Obstruction Light (Option)
PTO Operation
PTO ON Operation
PTO OFF Operation
Outrigger Operation
Control System
Extension Width of Outriggers and Appearance of Marks on Side of Outrigger Beam
Cautions for Setting Up Outriggers
Outrigger Extending Operation from Outrigger Control Panel/Box
Horizontal Set-up
Outrigger Stowing Operation from Outrigger Control Panel/Box
Counterweight Jack Interlock
Winch Operation
Hoisting Up/Down
High-speed Hoist Up/Down
Drum Indicator
Boom Telescoping Operation
Elevating Boom
Elevating Boom
Elevation Slow Stop Function
Slewing Operation
Slewing Operation
Slewing Free Switch
Slewing Automatic Stop Function
Traveling On Work Site
Traveling Configuration in Work Site
On-rubber Operation
On-rubber (Stationary) Operation
On-rubber (Creep) Operation
Taking Out and Stowing Hook Block
Taking Out Hook Block
Stowing Hook Block
Reeving Wire Rope
Standard number of parts of line
Reeving Procedure
Hook Block with Sheave Covers
Auxiliary Winch Hook Block with Lock
Single Top
Mounting Single Top
Stowing Single Top
Jib
Registering Jib Mounting/dismounting Status
Jib Lift
Outline of Jib Mounting
Mounting of Base Jib
Mounting of Base Jib + Top Jib
Changing Jib Offset Angle
Outline of Jib Stowing
Stowing of Base Jib
Stowing of Base Jib + Top Jib
Dismounting Jib
Mounting Removed Jib
Mounting and Dismounting Counterweight
Rigging Point of Counterweight
Mounting Counterweight
Accessories in Cab
MFD Operation Switch
Flood Lamp Button
Alarm Buzzer Muting Function
Pump Stop Function
Cab Tilt Switch
Roof Washer Switch
Roof Wiper Switch
Drink Holder
Searchlight (Option)
Slewing Table Mirror (Option)
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance
About Inspection and Maintenance
Under Severe Use (Severe Condition)
Conditions of Severe Use
Periodic Replacement Part
Inspection and Maintenance Interval (Carrier)
Inspection and Maintenance Interval (Crane)
Irregularities Detected on Previous Day or Operation
Inspection around Carrier
Inspection of Engine Room
Inspection at Driver's Seat
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Devices
Inspection of Crane Structure
Boom Structure
Jib Structure
Slewing Frame
Outrigger Structure
Chassis Frame
Greasing
Greasing Chart
Gear Oil
Winch Speed Reducer (Main/Auxiliary Winch)
Slewing Speed Reducer
Axle (Carrier)
Axle (Planetary Gear)
DEF/AdBlue Tank
Engine Cooling System
Coolant Filter (Warm Water)
Transmission System
Line Filter
Fuel System
Draining Water from Engine Fuel Filter with Water Separator
Brake Fluid Reservoir
Disc Brake Pad
Air Dryer
Air Tank
Tire, Wheel
Tires
Wheel Nut
Hydraulic Oil Tank
Return Filter
Line Filter (Steering Circuit)
Slewing System
Slewing Bearing Mounting Bolt
Replacing
Air Conditioner System
Condenser
Refrigerant Level
Refrigerant Piping Connection
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
EMERGENCY OPERATIONS
Action in Emergency
If Failure Occurs while Traveling on Road
If Stalled at Railroad Crossing
If Transmission Cannot Be Operated
If Engine Speed Does Not Increase
When Overheating Occurs
When Towed
If Crane Cannot Be Operated toward Non-critical Side
If Error Occurs in AML System
If Boom Telescoping Is Not Possible
If Boom Cannot Be Elevated
If Counterweight Status or Outrigger Status Is Not Detected
Escaping in Emergency
INFORMATION AND DATA
Conversion Tables
Major Specifications
Crane Specifications
Carrier Specifications
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Oil and Grease Table
Recommended Oils and Greases
Transportation of Crane
Checking Transportation Configuration
Binding Point
Error Code Table
VCU/DCU2 Error Code
Stop/Warning Error Code
Service Data
Service Data
EU Battery Regulation
Brand: Tadano
Appendix
Introduction
Warranty
In Event of Failure
Devices)
For Safety
Contents
Name of Each Part
Traveling System
Other Controls
Safety Precaution
Warning Labels
TRAVELING
Before Traveling
Entering Cab
Adjustment of Seat
Sunshade
Meters and Gauges
Warning Sign
TADANO View System
Camera Position
Starter Switch
How to Start Engine
How to Stop Engine
Brake Operation
Steering Operation
Light Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories in Cab
Preset Menu
Air Conditioner
Clearance Sonar
Steps
Handling Tires
Tire Air Pressure
Winterization
OPERATION
Terminology
Working Range Chart
Working Area Chart
Selecting Display
Other Functions
Stop Switch
Anemometer
PTO Operation
PTO ON Operation
PTO OFF Operation
Outrigger Operation
Control System
Horizontal Set-up
Winch Operation
Hoisting Up/Down
Drum Indicator
Elevating Boom
Elevating Boom
Slewing Operation
Slewing Operation
Slewing Free Switch
On-rubber Operation
Stowing Hook Block
Reeving Wire Rope
Reeving Procedure
Single Top
Mounting Single Top
Stowing Single Top
Jib
Jib Lift
Stowing of Base Jib
Dismounting Jib
Accessories in Cab
Flood Lamp Button
Pump Stop Function
Cab Tilt Switch
Roof Washer Switch
Roof Wiper Switch
Drink Holder
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Devices
Boom Structure
Jib Structure
Slewing Frame
Outrigger Structure
Chassis Frame
Greasing
Greasing Chart
Gear Oil
Axle (Carrier)
DEF/AdBlue Tank
Transmission System
Line Filter
Fuel System
Disc Brake Pad
Air Dryer
Air Tank
Tire, Wheel
Tires
Wheel Nut
Hydraulic Oil Tank
Return Filter
Slewing System
Replacing
Condenser
Refrigerant Level
Inside Air Filter
Outside Air Filter
V-belt
Wire Rope
Replacing Wire Rope
Handling Wire Ropes
Action in Emergency
When Towed
Conversion Tables
Overall Dimensions
Mass
Wire Rope
Others
Oils and Greases
Binding Point
Error Code Table
VCU/DCU2 Error Code
Service Data
Service Data
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
