Momed80
150
35,046
Tadano Crane ATF100G-4 Operation Manual ATF100G-4_OM1-16E 2018
Brand: Tadano
Type of Machine: Crane Carrier
Model: Tadano ATF100G-4 Crane Carrier
Applicable Model: ATF-100G4(J)-1
Serial Number: GA5251–
Applicable Specifications: ATF-100G-1-90102, ATF-100G-1-90101
Part Number: ATF100G-4_OM1-16E
Publication Date: 2018
Number of Pages: 247 Pages
Introduction
Warranty
Qualifications Required For Driving (Applicable In
Japan)
Inspection And Maintenance
In Event Of Failure
Exporting Abroad
For Safety
Contents
Name Of Each Part
Contents With Illustration
Traveling System
Safety Rules
Precautions Before Starting Engine
Precautions For Traveling On Roads
Warning Label
Label Location And Content Of Warnings
Traveling
Legal Restriction For Traveling On Roads
(Applicable In Japan)
Security Standards For Road Transport
Vehicles
Vehicle Restriction Ordinance
Before Traveling
Checking Traveling Configuration
Status Of Traveling Controls
Inspection Before Traveling
Preparation Before Traveling
Entering Cab
Opening/Closing Door
Adjusting Seat
Adjusting Steering Wheel
Opening/Closing Window
Adjusting Mirrors
Fastening/Unfastening Seat Belt
Sunshade
How To Read Instrument Panel
Meters And Gauges
Warning Lamps
Starting And Stopping Engine
How To Start Engine
Warm-Up Operation
How To Stop Engine
Operating Transmission
Operating Shift Switch
Selecting Low-Speed Mode
Changing To Power Mode
Operating Brake
Operating Foot Brake
Operating Parking Brake
Operating Engine Brake And Automatic
Retarder
Operating Retarder
Abs Off-Road Mode Operation
Operating Steering
Selecting Steering Mode
Operating Suspension
Suspension Locking
Suspension Leveling
Adjusting Vehicle Height
Adjusting Vehicle Inclination
Oscillating Axle
Operating Drive Mode Changeover, Differentia
Lock
Lock
Releasing Drive Mode Changeover
Selecting Transfer
Changing From On-Road Mode To Off-Road
Mode
Changing From Off-Road Mode To On-Road
Mode
Operating Cruise Control
Selecting Cruise Control
Releasing Cruise Control
Lighting Switches And Other Switches
Lighting Switch
Turn Signal Lever
Hazard Lamp Switch
Horn Switch
Wiper
Accessories In Cab
Air Conditioner
Tachograph
Radio
Rearview Monitor
Cab Lamp
Mirror Heater Switch
24 V Power Supply Socket
Fold-Down Bed
Operation In Cold Season
Winterization/Inspection
Precautions For Inspection And Maintenance
About Inspection And Maintenance
Legal Inspection
Under Severe Use (Severe Condition)
Conditions Of Severe Use
Periodic Replacement Part
Inspection And Maintenance Interval (Carrier
Abnormal Items Detected On Previous Day O
Travel
Inspection Around Carrier
Inspection Of Engine Room
Inspection At Driver’s Seat
Inspection Of Chassis
Greasing
Maintenance Table
Greasing Chart
Greasing (Centralized Lubrication System)
Maintenance Table
Refilling Grease
Setting Operating Time
Operation Monitor Of Lubrication System
Inspection Of Joints And Hoses
Maintenance Table
Water Separator
Coolant
Coolant Hose, Air Intake Hose
Air Cleaner
Air Intake Manifold And Hose
Adblue® Tank
Exhaust System
Maintenance Table
Transfer
Maintenance Table
Axle And Propeller Shaft
Maintenance Table
Axle
Inspection Of Wheel Hub Oil Level
(Drive Shaft)
Propeller Shaft
Maintenance Table
Hydraulic Oil Tank
Steering
Suspension
Maintenance Table
Compressed Air System
Brake
Abs System
Engine Brake
Air Circuit
Maintenance Table
Inspection Of Battery
Inspection Of Alternator And Starter
Operation Check Of Lighting Device And Turn
Signal
Cleaning And Appearance Check Of Lamps
Inspection Of Tachograph
Fuse
Tire, Wheel
Maintenance Table
Tire, Wheel
Cab And Others
Maintenance Table
Air Conditioner
Maintenance Table
Air Conditioner Main Unit
Action Against Emergency
If Failure Occurs During Traveling On Road
If Stalled At Railroad Crossing
If Failure Occurs To Engine
If Transmission Operation Cannot Be
Operated
If Engine Cannot Be Started/Stopped
If Overheated
If Failure Occurs To Steering Device
If Failure Occurs To Rear Steering
If Failure Occurs To Abs Device
When Fuel Runs Out
If Battery Is Exhausted
When Towed
Information And Data
Conversion Tables
Bolt Tightening Torque
Oils And Greases
Oils And Greases Table
Recommended Oils And Greases
Service Data
Service Data
