Momed80
150
35,046
Tadano Crane ATF100G-4 Operation Manual ATF-100G4(J)-1_OM1-34E 2017
Brand: Tadano
Type of Machine: All Terrain Crane
Model: Tadano ATF100G-4 All Terrain Crane
Applicable Model: ATF-100G4(J)-1
Applicable Specification: ATF-100G-1-90101, ATF-100G-1-90102
Serial Number: GA5288–
Part Number: ATF-100G4(J)-1_OM1-34E
Publication Date: 2017
Number of Pages: 455 Pages
Introduction
Warranty
Qualifications Required for Driving and Operati
(Applicable in Japan)
Inspection and Maintenance
In Event of Failure
Before Exporting This Machine Out of Japan
(Including Mobile/Satellite Communication
Terminal)
Contents
Name of Each Part
Contents with Illustration
Outrigger Control System
Crane Control System
Safety Rules
Precautions before Starting Engine
Precautions for Traveling on Roads
Precautions during Operation
Warning Label
Label Location and Content of Warnings
OPERATION
Terminology
Anchor Points for Safety Belt
Location of Anchor Points
Before Crane Operation
Pre-operational Inspection
Preparing for Crane Operation
How to Read Performance Data Plates
Working Range Chart
Rated Lifting Capacity Table
Working Area Diagram
Automatic Moment Limiter (AML)
Display
Registration of Operating Status and AML
Function Check
Alarm and Recovery Operation
Other Functions
Action against AML System Error
How to Read Meter Panel
Meters and Gauges
Alarm Buzzer
Warning Lamp and Indicator Lamp
Monitor (AML)
How to Use Monitor
Drum Monitoring Camera
Other Safety Devices
Anti-two-block Device
Over-unwinding cutout device
Anemometer
AML external indicator lamp
Outriggers
Outrigger Set-up
Extending Outriggers
Horizontal Set-up
Retracting Outriggers
Entering Cab
Opening/Closing Door
Opening/Closing Windshield
Extending/Stowing Step
Adjusting Seat Tilt
Adjusting Seat
Adjusting Control Lever Stand
Sun Visor
Sunshade
Starting and Stopping Engine
How to Start Engine
How to Stop Engine
Functions of Control Lever and Pedal
Hoisting
Hoisting Up/Down Operation
Winch Speed Changeover Operation
Drum Rotation Indicator
Boom Telescoping Operation
Outline of Telescoping System
Types of Telescope Mode
Normal Telescoping Operation
Telescoping with Load Lifted
Maintenance Telescoping
Slow Telescope Mode
Boom Telescoping Speed Changeover Opera
Boom Elevating Operation
Slow Stop Cancel Switch
Boom Elevating Speed Changeover Operatio
Slewing Operation
Slewing Operation
Slewing Release Switch
Slewing Brake Pedal
Slewing Lock Operation
Slewing Alarm Switch
Hydraulic Tilt Jib Operation
Jib Tilt Speed Changeover Operation
Reeving Wire Ropes
Standard Number of Parts of Line
Reeving Procedure
Stowing Procedure for Main Wire Rope
Single Top
Mounting Single Top
Stowing Single Top
Accessories in Cab
Heater and Air Conditioner
How to Use Other Accessories
Accessories outside Cab
Ladders
MOUNTING/DISMOUNTING
Mounting/Dismounting Counterweight
Combinations of Counterweights
Counterweight Operation
Mounting Counterweight
Mounting/dismounting of Hydraulic Tilt Jib
Mounting Hydraulic Tilt Jib
Dismounting Hydraulic Tilt Jib
Mounting/Dismounting of Auxiliary Winch
Mounting Auxiliary Winch
Dismounting Auxiliary Winch
INSPECTION AND MAINTENANCE
Precautions for Inspection and Maintenance
About Inspection and Maintenance
Legal Inspection
Periodic Replacement Part
Inspection and Maintenance Interval
Control System
Outrigger System
Slewing System
Boom, Jib System
Lifting Device
Safety Devices
Inspection of Crane Structure
Greasing
Maintenance Table
Greasing Chart
Greasing Centralized Lubrication Device
Gear Oil
Maintenance Table
Winch Speed Reducer (Main/Auxiliary Winch
Slewing Speed Reducer
Maintenance Table
Engine Oil
Air Cleaner
Engine Cooling System
Maintenance Table
Coolant
Fuel System
Maintenance Table
AdBlue® Tank
Water Separator
Maintenance Table
Hydraulic Oil Tank
Line Filter
Slewing System
Maintenance Table
Slewing Bearing Mounting Bolt
Outrigger System
Maintenance Table
Outrigger Beam
Maintenance Table
Replacing Fuse
Battery Electrolyte Inspection
Air Conditioner System
Maintenance Table
Checking Refrigerant Level
Checking and Cleaning Condenser
Cleaning and Replacing Air Filter
Checking Refrigerant Hose
Checking V belt
Wire Rope
Replacing Wire Ropes
Handling Wire Ropes
Action against Emergency
If Boom Cannot be Telescoped
Monitor Screen During Emergency Telescopin
Operation
Action against Abnormality (A)
Action against Abnormality (B)
Action against Abnormality (C)
If Error Occurs in AML System
If Error Occurs with AML Main Body
If Crane Operation Does Not Stop Even When
Control Lever is Returned to Neutral Position
If Weight Set Failure Warning Lamp Does Not
Out
If Engine Cannot be Started/Stopped
If Battery Is Exhausted
INFORMATION AND DATA
Conversion Tables
The Safety Ordinance for Cranes (Japan)
Hand Signals
Major Specifications
Crane
Overall Dimensions
Oils and Greases
Oil and Grease Table
Main Transportation Component List
Mass Distribution List
Mounting Counterweights with Traveling
Configuration in Work Site with
Boom Mounted
Stowing/Taking Out Hook Block
Traveling Configuration in the Work Site
