Tadano Crane ATF-120N-5 Operation Manual ATF-120N-5.1(S)_OM1-17E 2024
Brand: Tadano
Type of Manual: Operation Manual, Mounting, Dismounting
Model: Tadano ATF-120N-5 Crane
Applicable Model: ATF-120N-5.1
Applicable Specification: ATF-120N-1-90101
Serial Number: GH0001–
Part Number: ATF-120N-5.1(S)_OM1-17E
Publication Date: 2024
Number of Pages: 303 Pages
1 Preface
1.1 Applicable Specification No.
1.2 How to Read the Operation Manual
1.3 Qualifications Required for Operating the Machine (Applicable in Japan)
1.4 Definition of Worker Levels
1.5 Crane Type Nameplate
1.6 In Case of Failure
1.7 Warranty
1.8 Operating Life
1.9 本機の国外持ち出しについて(携帯/通信衛星端末、ラジコン装置、盗難防止装置)
1.10 Before Exporting This Machine Out of Japan (Including Mobile/Satellite Communication Term
Radio Control Unit, and Immobilizer) 1-6
2 Contents
3 Contents with Illustration
3.1 Auxiliary Winch
3.2 Counterweight
3.3 Hydraulic Telescoping Luffing Jib (FLJ)
3.4 Hydraulic Tilt Jib (HLJ)
3.4.1 Base Jib
3.4.2 Base Jib + Middle A Jib
3.4.3 Base Jib + Middle A Jib + Top Jib
3.4.4 Base Jib + Middle B Jib + Middle A Jib + Top Jib
4 Safety Rules
4.1 Precautions before Starting Engine
4.2 Precautions for Traveling on Roads
4.3 Precautions during Operation
5 Safety Devices
5.1 Safety Devices of this Machine
5.1.1 Safety Instructions
5.1.2 Safety Devices of this Machine
5.2 Fall Prevention Device
5.2.1 Fall Prevention Device
5.2.2 Working on Boom and Slewing Table
5.2.3 Mounting/Dismounting Counterweight
5.2.4 Mounting/Dismounting Auxiliary Winch
5.2.5 Mounting/Dismounting Hydraulic Telescoping Luffing Jib (FLJ)
5.2.6 Mounting/Dismounting Hydraulic Tilt Jib (HLJ)
5.3 Anti-two-block Device
5.3.1 Anti-two-block Device
5.3.2 Checking Anti-two-block Device
5.4 Anemometer
5.4.1 Anemometer
5.4.2 Installing/Removing Anemometer
5.4.3 Checking anemometer
6 Reeving Wire Ropes
6.1 Safety Instructions
6.2 Number of Parts of Line
6.2.1 Reeving for Lift Using Hydraulic Telescoping Luffing Jib (FLJ)
6.2.2 Reeving for Lift Using Hydraulic Tilt Jib (HLJ) Base Jib
6.2.3 Reeving for Lift Using Hydraulic Tilt Jib (HLJ) Middle A Jib
6.2.4 Reeving for Lift Using Hydraulic Tilt Jib (HLJ) Top Jib
7 Mounting/Dismounting Auxiliary Winch
7.1 Name of Each Part
7.2 Lifting Points, Mass and Dimensions
7.3 Mounting Auxiliary Winch
7.3.1 Safety Instructions
7.3.2 Work Preparation
7.3.3 Mounting Auxiliary Winch
7.4 Dismounting Auxiliary Winch
7.4.1 Safety Instructions
7.4.2 Work Preparation
7.4.3 Dismounting Auxiliary Winch
8 Mounting/Dismounting Counterweight
8.1 Name of Each Part
8.1.1 Counterweight
8.1.2 Control Panel
8.2 Lifting Points, Mass and Dimensions
8.2.1 Weight (1)
8.2.2 Weight (2)
8.2.3 Weight (3)
8.2.4 Weights (5) and (6)
8.2.5 Weight (4)
8.2.6 Weight (7)
8.2.7 Weight (8)
8.3 Combinations of Counterweights
8.4 Lifting Points and Mass of Combined Weights
8.4.1 Weights (1) + (3)
8.4.2 Weights (1) + (3) + (4)
8.4.3 Weights (1) + (3) + (4) + (5)
8.5 Mounting Counterweight
8.5.1 Safety Instructions
8.5.2 Work Preparation
8.5.3 Mounting Counterweight
8.6 Dismounting Counterweight
8.6.1 Safety Instructions
8.6.2 Work Preparation
8.6.3 Dismounting Counterweight
9 Mounting/Dismounting Hydraulic Telescoping Luffing Jib (FLJ)
9.1 Name of Each Part
9.1.1 Entire Jib
9.1.2 Jib Foot
9.1.3 FLJ Remote Controller
9.2 Lifting Points, Mass and Dimensions
9.2.1 Hydraulic Telescoping Luffing Jib
9.2.2 Adapter
9.2.3 Hose Reel
9.3 Configuration in Strong Wind
9.4 Mounting Hydraulic Telescoping Luffing Jib (FLJ)
9.4.1 Safety Instructions
9.4.2 Work Preparation
9.4.3 Installing Hose Reel
9.4.4 Mounting Jib
9.5 Dismounting Hydraulic Telescoping Luffing Jib (FLJ)
9.5.1 Safety Instructions
9.5.2 Work Preparation
9.5.3 Dismounting Jib
9.5.4 Removing Hose Reel
10 Mounting/Dismounting Hydraulic Tilt Jib (HLJ)
10.1 Name of Each Part
10.1.1 Entire Jib
10.1.2 Jib Structure
10.2 Lifting Points, Mass and Dimensions
10.2.1 Base Jib
10.2.2 Middle A Jib
10.2.3 Top Jib
10.2.4 Middle B Jib
10.2.5 Base Jib + Middle A Jib + Top Jib
10.2.6 Base Jib + Middle A Jib
10.3 Configuration in Strong Wind
10.4 Mounting Hydraulic Tilt Jib (HLJ)
10.4.1 Safety Instructions
10.4.2 Work Preparation
10.4.3 Installing Hose Reel
10.4.4 Mounting Base Jib
10.4.5 Mounting Jib (Base Jib + Middle A Jib)
10.4.6 Mounting Jib (Base Jib + Middle A Jib + Top Jib)
10.4.7 Mounting Jib (Base Jib + Middle B Jib + Middle A Jib + Top Jib)
10.5 Dismounting Hydraulic Tilt Jib (HLJ)
10.5.1 Safety Instructions
10.5.2 Work Preparation
10.5.3 Dismounting Jib (Base Jib + Middle B Jib + Middle A Jib + Top Jib)
10.5.4 Dismounting Jib (Base Jib + Middle A Jib + Top Jib)
10.5.5 Dismounting Jib (Base Jib + Middle A Jib)
10.5.6 Dismounting Base Jib
10.5.7 Removing Hose Reel
Brand: Tadano
1 Preface
1.7 Warranty
1.8 Operating Life
2 Contents
3.1 Auxiliary Winch
3.2 Counterweight
3.4.1 Base Jib
4 Safety Rules
5 Safety Devices
5.4 Anemometer
5.4.1 Anemometer
8.1.1 Counterweight
8.1.2 Control Panel
8.2.1 Weight (1)
8.2.2 Weight (2)
8.2.3 Weight (3)
8.2.5 Weight (4)
8.2.6 Weight (7)
8.2.7 Weight (8)
9.1.1 Entire Jib
9.1.2 Jib Foot
9.2.2 Adapter
9.2.3 Hose Reel
9.4.4 Mounting Jib
10.1.1 Entire Jib
10.2.1 Base Jib
10.2.2 Middle A Jib
10.2.3 Top Jib
10.2.4 Middle B Jib
- Tadano AML-LC (Moment limited) Manuals and Repair manuals
- Tadano Faun ATF 220G-5 Operating Service & Maintenance Manual
- Tadano Mobile Crane ATF 90G-4 Operating, Service and Maintenance Manual
- Tadano GR-550EX-2 Operation and Maintenance Manual
- Tadano GT-550E-1 Error codes
- Tadano Faun ATF 70G-4 Original operating manual
- Tadano Rough Terrain Crane GR1000XL-2 Operation and Maintenance Manual
- Tadano TR250M-5 CPU Error 07
- Tadano Faun ATF90G-4 Circuit Diagram
- Tadano TM-Z300-2/P-05 Parts Catalog
- Tadano GT-550E-1 Operation end Maintenance manual
- Tadano Faun ATF160G-5 Operating,Service Maintenance Manual
- Tadano Faun ATF110G-5 PAT IK 350,1368 Operator Console
- Tadano Faun RTF 40-3 Load Rating Charts
- Tadano Faun ATF90G-4 Spare Parts List
