Hyundai
86
176,684
Tadano Aerial Work Platform AT-200S-2 Diagrams and Operation Training Manual
Brand: Tadano
Type of Manual: Operation Maintenance Manual, Training Manual, Hydraulic and Electric Diagrams, Error Code
Model: Tadano AT-200S-2 Aerial Work Platform
AT-200S-2
AT200S-2
AT 200S-2
AT-200S/2
AT200S/2
AT 200S/2
List of Files:
AT-200S-2 Operation Manual AT-200S-2_O1-2E.pdf (129 Pages)
AT-200S-2 Hydraulic and Electric Diagrams AT-200S-2_C1-1E.pdf (112 Pages)
AT-200S-2 Operation Maintenance Manual AT-200S-2_OM4-11E.pdf (215 Pages):
Introduction
OPERATION
INSPECTION AND MAINTENANCE
INFORMATION AND DATA
Automatic Motion Controller AMC 3 Service Manual W319-0014E.pdf (292 Pages):
Foreword
Contents
1. Structure
2. Function
3. Contents to display
4. Display of error history
5. Display of operation history
6. Erasing error history and operation history
7. Replacing method of board (AMC unit and control box)
8. Adjustment after board or detector replacement
9. Replacement of clock batteries and adjustment of clock
Attached material:
Aerial Platform Error Code Table (AMC3)
Attached material:
Bridge Inspection Vehicle Error Code Table (AMC3)
Attached material:Error Code Table (Outrigger Indicator)
History of revision
General Cautions Service Manual WA01-0121E 2014.pdf (72 Pages):
Foreword
Conversion Table
Contents
Contents of Information
Hydraulic System Troubleshooting
Hydraulic Units
Sealing Parts
Piping Procedure
Machine Elements
Hydraulic Oil
Wiring
General Cautions Service Manual WA01-0121E 2024.pdf (79 Pages):
Foreword
Contents
A General Precautions
Revision history
Tadano AT-100S to AT-300S Training Manual AT-10_12_15_20_25_30S-1_TC-01E (101 Pages):
AT-10_12_15_20_25_30S-1_TC-01E Aerial Work Platform
Table of Contents
Conversion
Super Deck Series Specifications
Controls of Super Deck Series
Controls of Super Deck Series No.1​
Controls of Super Deck Series No.2​
Voice output condition
Hydraulic circuit diagram
AT-200S
AT-100,120,150S​
Circuit diagrams: AT-100S, 120S, 150S
Danfoss valve internal operation principle​
Outrigger extension, stowing operation​
Elevating operation, boom telescoping operation​
Leveling operation​
Boom, deck slewing operation​
Electric circuit diagram
AT-100S​
AT-120S​
AT-200S​
AT-150S​
Circuit diagrams: AT-150S
Power supply circuit​
Neutral relay circuit​
Engine start operation​
Engine stop operation​
Accelerator control​
Unload SOL, emergency switch circuit​
AMC, deck input/output signal voltage​
Automatic retraction operation​
Deck flat operation​
Leveling adjustment operation​
Yellow flicker circuit​
Input/Output signals (Common to 4 models)
AMC Input/Output signals table​
Deck operation box input/output signals (Common to 4 models)​
O/R indicator input/output signals table​
Error messages (Common to 4 models)
AMC error No. & Circuit check quick reference​
AMC error troubleshooting​
Parts Placement
Layout inside control unit
Various controls on the AMC (Common to 4 models)
AMC displays table (Common to 4 models)
Various adjustment procedures
Error histories reset procedure (Common for all models)​
Power ONs count reset procedure (Common for all models)​
Deck, boom interference control switch adjustment procedure​
Boom adjustment procedure​
Boom retraction switch adjustment procedure​
Jack-up detector switch adjustment procedure (Common to 4 models)​
Outrigger extension width detector switch adjustment procedure​
Outrigger jack clearance adjustment procedure (Common for all models)​
Engine speed/pressure adjustment procedure​
AMC-specific adjustment procedures
Points to be checked on built-in functions (Common for all models)​
Valve output adjustment procedure (Common for all models)​
10°, 50° moment write procedure (Common for all models)​
Moment zero/span adjustment, working radius adjustment procedure​
Deck slewing angle display adjustment procedure (Common for all models)​
Boom slewing angle display adjustment procedure (Common for all models)​
Boom length display adjustment procedure (Common for all models)​
Elevation angle display adjustment procedure (Common for all models)​
Deck boards
Adjustment mode operation procedure​
Monitor mode operations​
AT-250, 300S documentations
Hydraulic circuit diagram​
Differences in Hydraulic circuit diagram​
Electric circuit diagram​
Differences in Electric circuit diagram​
Errors and troubleshooting​
Voice outputs​
Various parts adjustment procedure (Common to AT-150S, 200S)​
