Hyundai
86
176,834
Sumitomo Hydraulic Excavator SH75X-3B Shop Manual ASM-17-00-001EN
Brand: Sumitomo
Type of Manual: Shop Manual
Model: Sumitomo SH75X-3B Hydraulic Excavator
Part Number: ASM-17-00-001EN
Number of Pages: 447 Pages
Safety
Introduction
Using Technical Information
Symbols
Precautions for Use
General Preparation for Disassembly
General Cautions for Assembly
General Cautions When Performing Inspections
Tightening Torque
Tightening Bolts and Nutsc
Retightening Torque Table
Numerical Conversion Table
Specifications
Overall View
Equipment Layout
Overall
Operator's Cab
Main Equipment Table
Lower Assembly Diagram (overall)
1. SH75X-3B (Mono-boom / Offset-boom)
Lower Component
1. Travel Unit
2. Take-up Roller
3. Upper Roller
4. Lower Roller
5. Recoil Spring
6. Shoe
Upper Component
1. Swing Unit
Engine-related
1. Engine
2. Muffler
3. Air Cleaner (double element)
4. Radiator
Hydraulic Oil Tank
Hydraulic Device
1. Hydraulic Pump
Control-related
1. Control Valve
2. Solenoid Valve (3 stack)
3. Remote Control Valve
4. Remote Control Valve Characteristic Diagram
5. Center Joint
Backhoe Attachment
1. Cylinder
2. Attachments
Oil and Filters
Method of Use for Fuel and Lubricating Oil According to Air Temperature
Fuel and Oil
Anti-freeze
Sumitomo Genuine Parts
Engine Fuel and Filter Maintenance
Fuel Used
Filter and Maintenance
Consumable Parts
SH75X-3B Oil Feeding and Element Replacement
Replacement Times for Hydraulic Oil and Filters When Using the Breaker
Performances
Lifting Capacity
Precautions for Lifting Loads with the Hydraulic Excavator
Lifting Capacities SH75X-3B (Mono-boom with blade)
1. Standard Arm (1.71 m), 450 Grouser shoe (Blade down)
2. Standard Arm (1.71 m), 450 Grouser shoe (Blade up)
3. Long Arm (2.12 m), 450 Grouser shoe (Blade down)
4. Long Arm (2.12 m), 450 Grouser shoe (Blade up)
Lifting Capacities SH75X-3B (Offset-boom with blade)
1. Standard Arm (1.75 m), 450 Grouser shoe (Blade down)
2. Standard Arm (1.75 m), 450 Grouser shoe (Blade up)
3. Long Arm (2.10 m), 450 Grouser shoe (Blade down)
4. Long Arm (2.10 m), 450 Grouser shoe (Blade up)
Hydraulic Pump Control Diagram
P-Q Diagram
Disassembling and Maintenance Instructions for Main Body
Maintenance Procedures
Lower Unit Path Block Diagram
Main Parts Tightening Torque
Bolt and Nut Tightening
Inspection and Maintenance
Lower Unit
Track Shoe
1. Removal Procedure
2. Installation Procedure
3. Track Link Replacement Procedure
Travel Unit
1. Assembly Precautions
2. Removal Procedure
3. Installation Procedure
Recoil Spring Assembly
Upper Roller
Lower Roller
Center Joint
Upper Unit
Swing Unit
Control Valve
Operator's Cab
Removal and Installation of Bucket Cylinder
Removal and Installation of Arm Cylinder
Removal and Installation of Boom Cylinder
Take-up Roller
Assembly and Disassembly Procedures
1. Configuration Diagram
2. Tools and Jigs
3. Disassembly Procedures
4. Assembly Procedures
Assembly Diagram
Upper Roller
Disassembly and Assembly Procedures
2. Tools and Jigs
Assembly Diagram
Lower Roller
2. Tools and Jigs
Assembly Diagram
Grease Cylinder
2. Tools and jigs
4. Assembly procedure
Assembly Diagram
Center Joint
2. Tools and Jigs
Assembly Diagram
