Sumitomo Forklift 8FB15PXIII to 8FB35PSZXIII Trouble Shooting Maintenance Manual 5501510-26
Hyundai
86
176,834
Brand: Sumitomo
Type of Machine: Forklift
Type of Manual: Trouble Shooting, Maintenance Manual, Electrical Diagram
Model: Sumitomo
8FB15PXIII, 8FB25PXIII, 8FB15PLXIII, 8FB25PLXIII, 8FB20PSXIII
8FB30PZXIII, 8FB35PSZXIII (C881)
Number of Pages: 212 Pages
1. Cautionary Notes on Inspecting and Repairing Electrical System
2. Overview of Electrical System
3. Operating Method (Extracted from Operation Manual)
[1] Operating System and Display
[2] Handling of Each Device
[3] Battery charging
4. AC Motor
[1] Principles of Operation
[2] Comparison with DC Motor
5. Description of Controller Operation
[1] Travel System
[2] Hydraulic System
[3] EHPS
[4] Overall Configuration of Control System
[5] Major Functions of Travel System, Hydraulic System, EHPS and Display
6. Adjustment and Setup: Controller / Display
[1] Switching Modes
[2] Controller Setting Value Adjustment
[3] Display option Setting Procedure
[4] Password Entry Setting Procedure
[5] Display Panel Memory Clear
[6] Software Version Confirmation Procedure
[7] Hour Meter Data Recovery Procedure
[8] Controller Installation and Removal
7. Display panel
[1] Overview
[2] Specification
[3] Removal and Installation
[4] Inspection
[5] Troubleshooting
8. Trouble Shooting : Travel / Hydraulic / EHPS / Display
[1] Preliminary Knowledge and Inverter Transistor Failure
[2] Corresponding at the Time of Controller Fuilure
[3] How to Check Transistor
[4] ErrorCode List
[5] Switch Monitor
[6] Error Log Memory
[7] Troubleshooting (Fault Finding)
9. Schematic / Diagrams
Layout Drawing of Electrical Equipment (1 ton, 2 ton)
Layout Drawing of Electrical Equipment (3 ton)
Controller 1 ton, 2 ton (48V) [Sinfonia] (Serial No. xxx-09999 and earlier)(The view which removed the printed board assy.)
Controller 1 ton, 2 ton (48V) [Sumitomo Nacco] (Serial No. xxx-10000 and later)(The view which removed the printed board assy.)
Controller 3 ton (72V) [Sinfonia] (Serial No. xxx-09999 and earlier)(The view which removed the printed board assy.)
Controller 3 ton (72V) [Sumitomo Nacco] (Serial No. xxx-10000 and later)(The view which removed the printed board assy.)
Controller printed board assy Layout drawing for connector on printed board[Sinfonia] (Serial No. xxx-09999 and earlier)
Wiring Diagram [Sinfonia](Serial No. xxx-09999 and earlier)
Wiring Diagram [Sumitomo Nacco](Serial No. xxx-10000 and later)
1 ton, 2 ton (48V) Frame Harness (Standard)[Sinfonia] (Serial No. xxx-09999 and earlier)
1 ton, 2 ton (48V) Frame Harness (Standard)[Sumitomo Nacco] (Serial No. xxx-10000 and later)
1 ton, 2 ton (48V) Frame Harness (Option)[Sinfonia] (Serial No. xxx-09999 and earlier)
1 ton, 2 ton (48V) Frame Harness (Option)[Sumitomo Nacco] (Serial No. xxx-10000 and later)
3 ton (72V) Frame Harness (Standard)[Sinfonia] (Serial No. xxx-09999 and earlier)
3 ton (72V) Frame Harness (Standard)[Sumitomo Nacco] (Serial No. xxx-10000 and later)
3 ton (72V) Frame Harness (Option)[Sinfonia] (Serial No. xxx-09999 and earlier)
3 ton (72V) Frame Harness (Option)[Sumitomo Nacco] (Serial No. xxx-10000 and later)
Cowl Harness(Common to all models)
Check sheet
