Sumitomo Excavator SH240-5 Spare Parts Catalog
Brand: Sumitomo
Type of Machine: Excavator
Model: Sumitomo SH240-5 Excavator
List of Files:
SH240-5 inner.pdf (Pages: 170)
SH240-5 main.pdf (Pages: 703)
Detail Content:
SH240-5 inner.pdf
CYL; ARM
CYL; BOOM
CYL; BUCKET
MOTOR; SWING
MOTOR; TRACTION
PUMP; GEAR
PUMP; HYD
RADIATOR
REDUCTION GEARS
VALVE; CONTROL
VALVE; CUSHION
VALVE; DIRECTION
VALVE; HOLDING
VALVE; RELIEF
VALVE; REMOTE CONT
VALVE; SHUT-OFF
VALVE; SOLENOID
SH240-5 main.pdf
AIR CLEANER(W ELEMENT)
AIR CONDITIONER (CAB)
AIR CONDITIONER (FRAME)
AM/FM RADIO HIGH BAND
ARM CYLINDER LINE
ARM(LONG)
ARM(SHORT)
ARM(STANDARD) (3.0M)
ARM(STANDARD)
BATTERY
BOOM CYLINDER LINE
BOOM LINE
BOOM(BACK-HOE)
BUCKET & ARM LINE
BUCKET CYL. LINE (2.5M ARM)
BUCKET CYLINDER LINE
BUCKET LINKAGE(BUILD-UP)
BUCKET LINKAGE(STANDARD)
BUCKET(0.80M3)
BUCKET(1.00M3)
BUCKET(1.10M3)
BUCKET(1.30M3)
CAB GUARD FOPS LEVEL2
CENTER GUARD
CENTER JOINT
CLAMP (2.5M ARM)
CLAMP (3.0M ARM)
CLAMP
CONSOLE BOX(100)
CONSOLE BOX(0)
CONSOLE BOX
CONTROL VALVE
CONTROLLER
COUNTER WEIGHT
COVER
DC-DC CONVERTER
DOG CHAIN
DRAIN LINE
ELEC.PARTS & WIRE HARNESS
ELEC.PARTS & WIRE HARNESS(FRM)
ELEC.PARTS & WIRE HARNESS(HBCV
ENGINE(ISUZU)
FLOOR MAT
FUEL FEED PUMP
FUEL LINE
FUEL TANK
GREASE LINE
GROUSER SHOE 600 SEAL
GROUSER SHOE 700 SEAL
GROUSER SHOE 800 SEAL
HORN(ELECTRIC)
HOUSE
HYDRAULIC PUMP(2ND)
HYDRAULIC PUMP
JOYSTICK CONTROL
LOWER FRAME
LOWER ROLLER
LOWER UNDER COVER
MUFFLER(STANDARD)
MULTI-PURPOSE+3WAY VALVE
NAME PLATE(ENGLISH)
OPE NAME PLATE
OPERATOR'S CAB
OPT. LINE(BAR BASE)(2.5M ARM)
OPTION LINE(BAR BASE)
PAINTING
PILOT CONTROL LINE
PILOT CONTROL LINE(HBCV)
PILOT PRESS.& RETURN LINE
PLUG
PRESS SWITCH (INDICATOR)
PRESSURE LINE
RADIATOR(STANDARD)
RAIN REFLECTOR
REAR VIEW MIRROR
RECOIL SPRING
RETURN & OIL COOLER LINE
REVOLVING EQUIPMENT
REVOLVING FRAME
SECOND OPTION LINE (2.5M ARM)
SECOND OPTION LINE
SECOND W-ACTING CIRCUIT
SERVICE VALVE CONTROL (L)
SERVICE VALVE CONTROL (R)
SERVICE VALVE
SINGLE ACTING CIRCUIT
SPARE PARTS KIT
STAND REAR
SUCTION LINE
SUMP TANK
SWING LINE
TAKE-UP ROLLER
TOOLS
TRACK GUARD(TRIPLE)
TRACTION ALARM
TRACTION EQUIPMENT
TRACTION LINE
TRACTION MOTOR LINE
TURN TABLE BEARING
UPPER ROLLER
UPPER UNDER COVER
WINDOW WASHER
WORKING LIGHT
Brand: Sumitomo
List of Files:
Detail Content:
SH240-5 inner.pdf
CYL; ARM
CYL; BOOM
CYL; BUCKET
MOTOR; SWING
MOTOR; TRACTION
PUMP; GEAR
PUMP; HYD
RADIATOR
REDUCTION GEARS
VALVE; CONTROL
VALVE; CUSHION
VALVE; DIRECTION
VALVE; HOLDING
VALVE; RELIEF
VALVE; REMOTE CONT
VALVE; SHUT-OFF
VALVE; SOLENOID
SH240-5 main.pdf
ARM CYLINDER LINE
ARM(LONG)
ARM(SHORT)
ARM(STANDARD)
BATTERY
BOOM CYLINDER LINE
BOOM LINE
BOOM(BACK-HOE)
BUCKET & ARM LINE
BUCKET(0.80M3)
BUCKET(1.00M3)
BUCKET(1.10M3)
BUCKET(1.30M3)
CENTER GUARD
CENTER JOINT
CLAMP (2.5M ARM)
CLAMP (3.0M ARM)
CLAMP
CONSOLE BOX(100)
CONSOLE BOX(0)
CONSOLE BOX
CONTROL VALVE
CONTROLLER
COUNTER WEIGHT
COVER
DC-DC CONVERTER
DOG CHAIN
DRAIN LINE
ENGINE(ISUZU)
FLOOR MAT
FUEL FEED PUMP
FUEL LINE
FUEL TANK
GREASE LINE
HORN(ELECTRIC)
HOUSE
HYDRAULIC PUMP(2ND)
HYDRAULIC PUMP
JOYSTICK CONTROL
LOWER FRAME
LOWER ROLLER
LOWER UNDER COVER
MUFFLER(STANDARD)
NAME PLATE(ENGLISH)
OPE NAME PLATE
OPERATOR'S CAB
PAINTING
PILOT CONTROL LINE
PLUG
PRESSURE LINE
RADIATOR(STANDARD)
RAIN REFLECTOR
REAR VIEW MIRROR
RECOIL SPRING
REVOLVING EQUIPMENT
REVOLVING FRAME
SECOND OPTION LINE
SERVICE VALVE
SPARE PARTS KIT
STAND REAR
SUCTION LINE
SUMP TANK
SWING LINE
TAKE-UP ROLLER
TOOLS
TRACK GUARD(TRIPLE)
TRACTION ALARM
TRACTION EQUIPMENT
TRACTION LINE
TRACTION MOTOR LINE
TURN TABLE BEARING
UPPER ROLLER
UPPER UNDER COVER
WINDOW WASHER
WORKING LIGHT
- Sumitomo SH240-5 error code 7003 and 0335
- Need Part Book Sumitomo SH210-5
- Sumitomo SH125-3 SH135X-3 Service Manual
- Service manual for Sumitomo Sh700 excavator
- I need Sumitomo SH200 A-1 Service Manual
- Sumitomo SH 330- 350-5 Service Manual
- Sumitomo SH200-3G Shop Manual
- Sumitomo SH290 Shop Manual
- Sumıtomu SH200,220 -3 Shop Manual Diagram
- Sumitomo SH330-5,SH330LC-5,SH350HD-5,SH350LHD-5 Parts Manual
- Sumitomo Hydraulic Excavator SH210-5 Series Parts Manual _EN
- Sumitomo Hydraulic Excavator SH330-SH350HDLC-5 Shop Manual _EN
- Sumitomo SH290 Service Manual
- Sumitomo R450LC-7 Shop Manual
- Service text Sumitomo SH330/350-3B
