Hyundai
86
176,834
Sumitomo Excavator SH210-6 SH210LC-6 SH210F-6 Service Manual WLSM2106-00KY
Brand: Sumitomo
Type of Machine: Excavator
Model: Sumitomo SH210-6 SH210LC-6 SH210F-6 Excavator
Part Number: WLSM2106-00KY
Publication Date: 2017
Number of Pages: 1554 Pages
Safety
Safety, general information and standard torque data​
General Information​
Standard Torque Data For Cap Screws And Nuts​
Specifications And Special Torque Settings​
Abbreviation​
Specifications
Specifications​
Main Equipment Table​
Overall View​
WORK RANGE DIAGRAM​
Main Unit Weight​
FLUIDS AND LUBRICANTS​
Circuits and Operation explanation
Main Equipment Structure and Operation Explanation​
Hydraulic Pump​
Travel Motor​
Swing Motor​
Control Valve​
5 Stack Solenoid Valve Operation Explanation​
Upper Pilot Valve (remote control valve)​
Travel Pilot Valve (remote control valve)​
Option Pilot Valve (remote control valve)​
Cushion Valve​
3 Stack Proportional Valve (for pilot)​
Engine Summary​
Hydraulic Equipment Layout​
Overall view​
Port Diagram​
Hydraulic Device​
Electrical and Engine Functions and Service Support​
Basic Functions​
Service Support​
Maintenance precautions​
Electrical Equipment Layout Diagram​
Connection Connector Pin Layout​
Sequence Circuit Diagram​
Removal / Installation and Assembly / Disassembly
Pressure Bleeding Operations​
Removal and Installation of Track​
Removal and Installation of Shoe Assembly​
Removal and Installation of Shoe Plate​
Removal and Installation of Roller​
Removal and Installation of Upper Roller​
Assembly and Disassembly of Upper Roller​
Removal and Installation of Lower Roller​
Assembly and Disassembly of Lower Roller​
Removal and Installation of Drive Sprocket​
Removal and Installation of Take-up Roller​
Assembly and Disassembly of Take-up Roller​
Removal and Installation of Grease Cylinder​
Assembly and Disassembly of Tension Shock Absorber​
Removal and Installation of Center Joint​
Assembly and Disassembly of Center Joint​
Removal and Installation of Travel Motor​
Assembly and Disassembly of Travel Motor​
Removal and Installation of Swing Unit​
Assembly and Disassembly of Swing Motor​
Assembly and Disassembly of Swing Unit​
Removal and Installation of Hydraulic Pump​
Removal and Installation of Pump Coupling​
Procedures for Assembly and Disassembly of Hydraulic Pump Main Unit​
Pump Main Unit Maintenance Standards​
Removal and Installation of Control Valve​
Procedures for Assembly and Disassembly of Control Valve​
Removal and Installation of Engine Assembly​
Removal and Installation of Fuel Cooler, Engine Intercooler, Radiator, and Oil Cooler​
Removal and Installation of Turbocharger assembly​
Inspection of Air Filter Element​
Removal and Installation of Inlet Cover​
Removal and Installation of Engine Hood​
Removal and Installation of Muffler​
Removal and Installation of Cylinder Head Cover​
Removal and Installation of Idle gear​
Removal and Installation of Cylinder Block​
Lubrication System​
Cooling System​
Removal and Installation of Crankshaft​
Removal and Installation of Piston​
Removal and Installation of Camshaft​
Removal and Installation of Flywheel​
Removal and Installation of Crankshaft front oil seal​
Removal and Installation of Crankshaft rear oil seal​
Removal and Installation of Rocker Arm Shaft​
Removal and Installation of Valve spring​
Removal and Installation of Valve stem oil seal​
Removal and Installation of Front Cover​
Removal and Installation of Exhaust Manifold​
Removal and Installation of Fuel Supply Pump​
Removal and Installation of Common Rail Assembly​
Removal and Installation of Injector​
Removal and Installation of Fuel Filter​
Removal and Installation of Relief Valve​
Removal and Installation of Fuel Filter Element​
Removal and Installation of Starter Motor​
Removal and Installation of Alternator​
Preheating System​
Removal and Installation of Suction Control Valve​
Removal and Installation of Fuel filter pressure​
Removal and Installation of Engine coolant temperature sensor​
Removal and Installation of CKP sensor​
Removal and Installation of CMP sensor​
Removal and Installation of Oil pressure sensor​
Removal and Installation of Pressure sensor/boost temperature sensor​
Removal and Installation of Intake Air Temperature Sensor​
Removal and Installation of Barometric Pressure Sensor​
Removal and Installation of Fuel Tank​
Removal and Installation of Hydraulic Tank​
Removal and Installation of Pilot Blocs​
Removal and Installation of Travel Remote Control Valve​
Procedures for Assembly and Disassembly of Travel Remote Control Valve​
Removal and Installation of Option Remote Control Valve​
Assembly and Disassembly Procedures of Option Remote Control Valve​
Removal and Installation of Operation Remote Control Valve​
Procedures for Assembly and Disassembly of Operation Remote Control Valve​
Removal and Installation of 5 Stack Solenoid​
Removal and Installation of Cushion Valve​
Assembly and Disassembly of Cushion Valve​
Removal and Installation of Operator's Seat​
Removal and Installation of Cab Assembly​
Removal and Installation of Wiper​
Removal and Installation of Wiper Controller​
Removal and Installation of Wiper Motor​
Removal and Installation of ECM​
Removal and Installation of Computer A​
Removal and Installation of Computer B​
Removal and Installation of Monitor​
Removal and Installation of Cab Front Glass​
Window Lock Adjustment Procedures​
Tightening torque​
Removal and Installation of Counterweight​
Removal and Installation of Rear View Camera​
Removal and Installation of Side Camera (right)​
Removal and Installation of Side Camera (left)​
Removal and Installation of FVM Controller​
FVM Setup Method​
Removal and Installation of Bucket​
Removal and Installation of Bucket Link​
Removal and Installation of Arm​
Removal and Installation of Boom​
Removal and Installation of Bucket Cylinder​
Removal and Installation of Arm Cylinder​
Removal and Installation of Boom Cylinder​
Procedures for Operation/Assembly and Disassembly of Hydraulic Cylinder (made by KYB)​
List of special tools​
Maintenance standards and Measurement procedures
Pressure Measurement and Adjustment Procedures​
Hydraulic Pump Flow Measurement Procedures​
Drain Volume Measurement Procedures​
Air Bleed Procedure​
Bolt Size and Torque Table​
New Machine Performance Judgment Table​
Air Conditioning
Air Conditioner Overall Diagram​
Assembly and Disassembly of Unit​
Removal and Installation of Compressor​
Removal and Installation of Condenser​
Removal and Installation of Receiver Dryer​
Work Precautions​
Troubleshooting
Trouble Diagnosis Guide​
Engine-side Diagnostic Trouble Code List​
Main Unit-side Diagnostic Trouble Code List​
Engine-side Trouble​
Main Unit-side Trouble​
Symptom​
