Martin Welker
104
230,310
Sumitomo Excavator SH210-5 Spare Parts Catalog
Brand: Sumitomo
Type of Machine: Excavator
Model: Sumitomo SH210-5 Excavator
List of Files:
SH210-5 inner.pdf (Pages: 168)
SH210-5 main.pdf (Pages: 762)
Detail Content:
SH210-5 inner.pdf
CYL; ARM
CYL; BOOM
CYL; BUCKET
MOTOR; SWING
MOTOR; TRACTION
PUMP; GEAR
PUMP; HYD
RADIATOR
VALVE; CONTROL
VALVE; CUSHION
VALVE; DIRECTION
VALVE; HOLDING
VALVE; RELIEF
VALVE; REMOTE CONT
VALVE; SHUT-OFF
VALVE; SOLENOID
SH210-5 main.pdf
AIR CLEANER(W ELEMENT)
AIR CONDITIONER (CAB)
AIR CONDITIONER (FRAME)
AM/FM RADIO HIGH BAND
ARM CYLINDER LINE
ARM(SHORT) (2.4M)
ARM(STANDARD) (2.9M)
ARM(SUPER SHORT) (1.9M)
BATTERY
BOOM CYLINDER LINE
BOOM LINE
BOOM(BACK-HOE)
BUCKET & ARM LINE
BUCKET CYLINDER LINE (2.4M)
BUCKET LINKAGE(BUILD-UP)
BUCKET LINKAGE(STANDARD)
BUCKET(0.50M3)
BUCKET(0.80M3)
BUCKET(0.90M3)
BUCKET(1.00M3)
BUCKET(1.10M3)
BUCKET(HEAVY DUTY0.80M3)
CAB GUARD FOPS LEVEL2
CENTER GUARD
CENTER JOINT
CLAMP
CLAMP0
CLAMP1
CONSOLE BOX(100)
CONSOLE BOX(0)
CONSOLE BOX
CONTROL VALVE (STD)
CONTROL VALVE(2ND)
CONTROLLER
COUNTER WEIGHT
COVER
DC-DC CONVERTER
DOG CHAIN
DRAIN LINE
ELEC.PARTS & WIRE HARNESS
ELEC.PARTS & WIRE HARNESS(FRM)
ELEC.PARTS & WIRE HARNESS(HBCV
ENGINE(ISUZU)
FLOOR MAT
FUEL FEED PUMP
FUEL LINE
FUEL TANK
GREASE LINE
GROUSER SHOE 600 SEAL
GROUSER SHOE 700 SEAL
GROUSER SHOE 800 SEAL M
HORN(ELECTRIC)
HOUSE
HYDRAULIC PUMP(2ND OPTION)
HYDRAULIC PUMP
JOYSTICK CONTROL
LOWER FRAME
LOWER ROLLER
LOWER UNDER COVER
MUFFLER(STANDARD)
MULTI-PURPOSE CIRCUIT
NAME PLATE(ENGLISH)
OPE NAME PLATE
OPERATOR'S CAB
OPTION LINE(BAR BASE) (2.4M)
PAINTING
PILOT CONTROL LINE(STD)(100)
PILOT CONTROL LINE(STD)(0)
PILOT CONTROL LINE
PILOT PRESS.& RETURN LINE
PLUG
PRESS SWITCH
PRESSURE LINE
RADIATOR(STANDARD)
RAIN REFLECTOR
REAR VIEW MIRROR
RECOIL SPRING
RETURN & OIL COOLER LINE
REVOLVING EQUIPMENT
REVOLVING FRAME
SECOND OPTION LINE (2.4M)
SECOND OPTION LINE
SECOND W-ACTING CIRCUIT
SERVICE VALVE CONTROL (L)
SERVICE VALVE CONTROL (R)
SERVICE VALVE
SINGLE ACTING CIRCUIT
SPARE PARTS KIT
STAND REAR
SUCTION LINE
SUMP TANK
SWING LINE
TAKE-UP ROLLER
TOOLS
TRACK GUARD(TRIPLE)
TRACTION ALARM
TRACTION EQUIPMENT
TRACTION LINE
TRACTION MOTOR LINE
TURN TABLE BEARING
UPPER ROLLER
UPPER UNDER COVER
WINDOW WASHER
WORKING LIGHT
