Subaru Legacy and Outback 2020 Service Manual
Brand: Subaru
Type of Machine: Automotive
Type of Manual: Service Manual, Wiring Diagram, Diagnostic, Getting Started Guide
Model: Subaru Legacy , Outback 2020
Number of Pages: 12295 Pages
Service Manual
Brand: Subaru
Service Manual
General Description
Foreword
SPECIFICATIONS
Precaution
Repair Contents
Identification
Recommended Materials
Pre-delivery Inspection
PERIODIC MAINTENANCE SERVICES
FUEL INJECTION (FUEL SYSTEMS)(H4DO)
EMISSION CONTROL (AUX. EMISSION CONTROL DEVICES)(H4DO)
INTAKE (INDUCTION)(H4DO)
MECHANICAL(H4DO)
EXHAUST(H4DO)
COOLING(H4DO)
LUBRICATION(H4DO)
SPEED CONTROL SYSTEMS(H4DO)
IGNITION(H4DO)
STARTING-CHARGING SYSTEMS(H4DO)
FUEL INJECTION (FUEL SYSTEMS)(H4DOTC)
EMISSION CONTROL (AUX. EMISSION CONTROL DEVICES)(H4DOTC)
INTAKE (INDUCTION)(H4DOTC)
MECHANICAL(H4DOTC)
EXHAUST(H4DOTC)
COOLING(H4DOTC)
LUBRICATION(H4DOTC)
SPEED CONTROL SYSTEMS(H4DOTC)
IGNITION(H4DOTC)
STARTING-CHARGING SYSTEMS(H4DOTC)
Body & Electrical
Blind Spot Detection-Rear Cross Traffic Alert
BODY CONTROL-COMMUNICATION SYSTEM
BODY STRUCTURE
ENTERTAINMENT & MONITORING
EXTERIOR BODY PANELS
EXTERIOR-INTERIOR TRIM
EyeSight
GLASS-WINDOWS-MIRRORS
HORN
INSTRUMENTATION&DRIVER INFO
LIGHTING SYSTEM
POWER REAR GATE SYSTEM
Reverse Automatic Braking
SEATS
SECURITY AND LOCKS
SUNROOF&T-TOP&CONVERTIBLE TOP (SUNROOF)
WIPER AND WASHER SYSTEMS
Brakes
VEHICLE DYNAMICS CONTROL (VDC)
BRAKE
PARKING BRAKE
Driveline&Axle
DIFFERENTIALS
PROPELLER SHAFT - DRIVE SHAFT - AXLE
Steering
Suspension
FRONT SUSPENSION
REAR SUSPENSION
WHEEL AND TIRE SYSTEM
Transmission&Transaxle
CONTROL SYSTEMS
CONTINUOUSLY VARIABLE TRANSMISSION(TR580)
CONTINUOUSLY VARIABLE TRANSMISSION(TR690)
Heater & Airconditioner&Ventilator
Airbag System & Seat Belt System
AIRBAG SYSTEM
SEAT BELT SYSTEM
Wiring DiagramsContent
How To Read Wiring Diagrams
List of Signal Name
Harness Repair Kit
Fuse And Relay
Power Supply Circuit
Ground Circuit
Active Grille Shutter
Airbag System
Air Conditioning System
Audio and Navigation System
Auto Start Stop
Back-up Light System
Blind Spot Detection/Rear Cross Traffic Alert
CAN Communication System
Charging System
Clearance Light and Illumination Light System
Combination Meter System
CVT Control System
Daytime Running Light System
Door Lock Control System
Driver Monitoring System
Electric Power Steering System
Engine Electrical System
EyeSight System
Front Accessory Power Supply Socket System
Front Fog Light System
Front View Monitor
Front Wiper and Washer System
Headlight Beam Leveler System
Headlight System
Horn System
Immobilizer System
Interior Light System
Keyless Access With Push Button Start System
Keyless Entry System
Mirror Heater System
Occupant Detection System
OP Connector System
Parking Brake / Brake Fluid Level Warning Light System
Power Rear Gate System
Power Seat System
Power Window System
Radiator Fan System
Rear Accessory Power Supply Socket System
Rear Defogger System
Rearview Camera System
Rearview Mirror System
Rear Wiper and Washer System
Remote Control Mirror System
Remote Engine Start System
Seat Belt Warning System
Seat Heater System
Seat Ventilation System
Security System
Shift Lock Control System
Starter System
Steering Heater System
Stop Light System
Sunroof Control System
Telematics System
Tire Pressure Monitoring System
Trailer Hitch Connector System
Turn Signal Light and Hazard Light System
Vehicle Dynamics Control System
Wiper Deicer System
Harness Components Location
Front Wiring Harness
Bulkhead Wiring Harness (In Engine Compartment) RH
Bulkhead Wiring Harness (In Engine Compartment) LH
Bulkhead Wiring Harness (In Compartment)
Engine Wiring Harness and Transmission Cord
Instrument Panel Wiring Harness RH
Instrument Panel Wiring Harness CTR
Instrument Panel Wiring Harness LH
Steering Wheel Cord
Roof Cord
Rear Wiring Harness RH
Rear Wiring Harness LH
Front Seat Wiring Harness RH
Front Seat Wiring Harness LH
Door Cord RH
Door Cord LH
Rear Wiring Harness and Trunk Lid Cord
Rear Wiring Harness and Rear Gate Cord
Antenna Cord
Diagnostic ManualAIR CONDITIONER(DIAGNOSTICS)
AIRBAG(DIAGNOSTICS)
AUTO START STOP (DIAGNOSTICS)
Blind Spot Detection-Rear Cross Traffic Alert (DIAGNOSTICS)
BODY CONTROL(DIAGNOSTICS)
BRAKE CONTROL (DIAGNOSTICS)
CENTRAL GATEWAY (DIAGNOSTICS)
COCKPIT CONTROL (DIAGNOSTICS)
COMBINATION METER (DIAGNOSTICS)
COMMON(diag)
DOOR MIRROR (DIAGNOSTICS)
DRIVER MONITOR(DIAGNOSTICS)
ENGINE (DIAGNOSTICS)(H4DO)
ENGINE (DIAGNOSTICS)(H4DOTC)
EyeSight (DIAGNOSTICS)
EyeSight ASSIST MONITOR (DIAGNOSTICS)
FRONT RELAY CONTROL MODULE (DIAGNOSTICS)
HEADLIGHT - FOGLIGHT(DIAGNOSTICS)
IMMOBILIZER (DIAGNOSTICS)
KEYLESS ACCESS WITH PUSH BUTTON START(DIAGNOSTICS)
KEYLESS ENTRY(DIAGNOSTICS)
LAN SYSTEM (DIAGNOSTICS)
MULTI VIEW MONITOR (DIAGNOSTICS)
POWER REAR GATE(DIAGNOSTICS)
POWER SEAT MEMORY(DIAGNOSTICS)
POWER STEERING (DIAGNOSTICS)
POWER WINDOW(DIAGNOSTICS)
Reverse Automatic Braking(DIAGNOSTICS)
TELEMATICS SYSTEM (DIAGNOSTICS)
TIRE PRESSURE MONITOR(DIAGNOSTICS)
TRANSMISSION (DIAGNOSTICS)
VENTILATION SEAT (DIAGNOSTICS)
- Subaru - Forester SJ 2013 Service Manual [2013, PDF, ENG]
- Subaru - Forester SJ 2014 Service Manual
- Subaru Legacy B4 Wiring Diagram
- Subaru Forester 2003 Service Manual
- Subaru 2013 XV Service Manual
- Subaru Forester 2015 Service Manual + Wiring Diagram
- SUBARU XV Cross HYBRID 2014 USA Workshop Manual
- Subaru Repair Manuals Full Set DVD
- Saburu Forester 2007 Wiring Diagram
- Saburu Legacy GT 1996 System Wiring Diagrams
- Subaru Impreza Outback Sport 2015 (Includes XV and Hybrid) Service Manual + Wiring Diagram
- SUBARU FORESTER 2019-2020 Service Manual & Electrical Wiring Diagram
- Subaru BRZ Z10_2017 Service Manual
- SUBARU Technical Training Manual
- Subaru Forester 1999-2002 Service Repair Manual
